Old 08-31-2011, 09:19 AM   #76
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,965
neck kit for Ascots
http://www.advrider.com/forums/showt...7#post16753867
over in the flea market if anyone wants one.
plugeye is offline   Reply With Quote
Old 08-31-2011, 07:10 PM   #77
truck6driver OP
The Fireman
Oddometer: 7,563
Fiep,
Nice looking bike there. Have you bought it yet?
Ray
Life has F@#ked with the wrong man. I will come out on top. Just watch.
truck6driver is offline   Reply With Quote
Old 09-01-2011, 05:41 AM   #78
fiep
fiep's Avatar
Oddometer: 1,909
after checking with the tag office - no title + back taxes -
I called and said I'll take it
seller will not be available for pick up before Sunday
so yes and no
I hope I bought it
will need fork seals and stock turn signals
fiep is offline   Reply With Quote
Old 09-01-2011, 09:52 AM   #79
ThatOtherGuy
ThatOtherGuy's Avatar
Oddometer: 308
Anybody else have trouble finding parts for their ft? I've had to call all kinds of different salvage yards with no luck.
Anything's possible with screwdrivers, big hammers, and beer.
ThatOtherGuy is offline   Reply With Quote
Old 09-01-2011, 10:00 AM   #80
jake28
Riding to the horizon.
jake28's Avatar
Oddometer: 391
82 ascot 500 motor: overbored 1 mm with Wiseco Hi comp piston, stock cam.
83 XL500R frame
2002 CR250 front forks and triple clamps, stock stem pressed in.
A&A Racing 19" front rim on CR250 hub. black excel rim and stainless spokes.
CR125 MX brake rotor
classic double wall race header and Yosh GSXR muffler
project in process
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS
jake28 is offline   Reply With Quote
Old 09-01-2011, 03:15 PM   #81
truck6driver OP
The Fireman
Oddometer: 7,563
UH yea. It's over a quarter of a century old bike that was only made a couple years. That means there were not that many to begin with. However the engine is the old design XR/XL500 engine with a starter and bigger stator. So many of those parts will cross over. Some of the brake parts are shared with the CB650SC like the calipers, pads and front master cylinder.
What parts are you looking for?
Ray
Old 09-02-2011, 09:56 AM   #82
ThatOtherGuy
Oddometer: 308
Ray
I was looking for a rear master cylinder, but since I last posted I cleaned mine up and it's looking pretty good. Although it may be nice to have one on hand.
Old 09-02-2011, 10:33 AM   #83
truck6driver OP
The Fireman
Oddometer: 7,563
Do some cross checking. Seems that when they built the little bike the went to the current parts bin and took parts from other bikes and adapted them to the frame.
Like with the engine the took the XR engine and just adapted it for street use. Bigger exhaust head, kick start remove and starter cheaply added with external bracketry.
It works. I like my Ascot and ride it more than my Nighthawk.
Ray
Old 09-02-2011, 11:52 AM   #84
Malcolmlovesbikes
Oddometer: 26
Originally Posted by fiep View Post
I sure hope 'snow white' is a fine specimen
am prowd to own her
but she is to d#$% far away and importing her to the States would cost far more than the bike is worth
So just to clear this up, you own the white one but its not with you in the states ?.
Malcolmlovesbikes is offline   Reply With Quote
Old 09-02-2011, 12:41 PM   #85
fiep
fiep's Avatar
Oddometer: 1,909
correct
it 'lives' in a friends garage in Germany
gets out whenever I make it over there
if shipping would not by far exeed the bikes value
and I do not see a hazzle free way to get it registered in GA
*sigh*
Old 09-04-2011, 10:53 AM   #86
fiep
fiep's Avatar
Oddometer: 1,909
now it's in my garage
needs fork seals and front brake pads
the PO put the stock turn signals back on
question:
the flexible stalks go in the back, right?
they are in the front now and look strange wiggling in the wind
thanks
Old 09-04-2011, 11:46 AM   #87
truck6driver OP
The Fireman
Oddometer: 7,563
question:
thanks
I put the smaller ones like those on My Nighthawk. Made it look better to me.
the front ones on the FT500 are on the fork clamps and not on the headlight brackets so I'm not sure if it is right or not.
Ray
Old 09-13-2011, 09:46 AM   #88
roadrunnerADV
roadrunnerADV's Avatar
Oddometer: 32
FT500 Ascot Project Bike
Found an FT500 that had been sitting for about 17 years or so .. here is a picture of the bike when I picked it up.
To date, I have replaced the chain, treated the fuel tank for rust (but I think I still need to reline it), purchased replacement rear shocks from PartsNMore, rebuilt the starter solenoid mechanism (the PO had already rebuilt the starter itself), cleaned the carb (twice so far), ordered brake caliper and master cylinder rebuild kits (not done yet). Bought a replacement seat cover but haven't installed it yet (the seat pan and foam are good). I'm currently trying to figure out why it won't start. Need to check compression today and rule that out. Spark is there but I'm not sure it's strong enough. The petcock needs to be repaired as gas leaks out w/o vacuum being applied. The bike itself only cost me $150 and I've spent much more on parts already .. Hope to get it running soon so I'll feel better about my investment!
Ray
'98 NH 750, '82 FT500
roadrunnerADV is offline   Reply With Quote
Old 09-13-2011, 10:06 AM   #89
roadrunnerADV
Oddometer: 32
hose routing question
Can anyone verify if I have the carb/petcock hose routing correct? Just want to be sure. Currently, I have carb port 1 connected to petcock port A ... and carb port 2 connected to petcock port B. Also, I'm curious about the first connection's purpose ... is it an alternate fuel supply line to the carb? These port designations are my own.
Ray
Old 09-14-2011, 08:52 AM   #90
ExTex
Oddometer: 254
My understanding on Petcocks on Hondas is that there is 1 fuel line (1/4" to 5/16" ID)
and 1 vacuum line (3/32" ID). The 3rd. port on the petcock is left open to atmosphere.
In one case, I saw a filtered vent line on that 3rd. port, but it was still open to the atmospehere.
The fuel line connects to the floatbowl (s) and the vacuum line connects to the engine intake at 1 of the carbs.
From the drawing, I would guess that even though it has a hose on it, the outermost small nipple should be
vented to the atmosphere, not connected to the engine intake.
http://www.hbhonda.com/fiche_section...1982&fveh=3421
Note that the left most hose has only 1 hose clip on it and none on the "open" end.
Ride safely,
ExTex: 2015 CB500 FA, 1989 Inteceptor VTR 250
Sold: CB650sc, VF700s, VT500c, Ninja 500
ExTex is offline   Reply With Quote
Times are GMT -7.   It's 12:21 AM.
