Old 06-02-2011, 03:35 PM   #151
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
It's the Happy Harley
johnwesley is offline   Reply With Quote
Old 06-02-2011, 05:56 PM   #152
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
thanks to Jimmy the Hog I have a set of rearsets that work better for the ds conversion. I little massaging of the brake lever and removal of the spring it's a great fit. The peg position is spot on. I like the tapered head bolts on the mounts as that gives more clamping force for the mount. I think it is a beefier set up all the way around and will work out great
johnwesley screwed with this post 06-02-2011 at 06:17 PM
Old 06-02-2011, 11:28 PM   #153
JimmyTheHog
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 714
Glad it worked John! - thats good to know. Even know we have the same exhausts, theres dimensional tolerance differences, so I wasnt shure the lever would not interfere with your exhaust. Mine was close, but all it would take is a little material removal and no problem.
If I get some free time this weekend, I'll sketch up the new shift lever and get em going.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 06-03-2011, 06:32 AM   #154
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
A new shifter will be sweet!!!
I think my exhaust sits farther away from the engine than yours. And therefore the top of the tube is in line with the brake lever. Also my exhaust could be tweaked as it is used
Old 06-09-2011, 08:11 PM   #155
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
Got a little work done that took alot of time. Fuel cell done, now I have a total of 7.5 gallons. I am going to build a custom rear fender but do not have the time before heading to Inuvik. So I have a spare under fender piece that I pulled in to do the job. A little KLR cheap scate coming out here I bought an off set air cleaner to give more room for standing, plus it gives a narrower feel to the bike. I have an issue with the rear wheel bearing spacer, it is too long. It's out at the machine shop to get 141 thousandths taken off. It's going to be close on having this done before I leave. If its not finished then the trusty old klr will have to be the work horse
Old 06-11-2011, 06:56 PM   #156
JimmyTheHog
Oddometer: 714
Nice ! - That should get you 250-300 miles ??? or more....
How do you transfer the gas to the main tank when needed ?
Hope you get it done for the trip - Id like to see the ride report.
Jim
Old 06-12-2011, 08:11 AM   #157
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
should get a good 300 miles with a .5 gallon left. It is all bolt on so when just running short trips or with the family I can go back to a Harley fender like this
For the fuel it is plumbed in to the main fuel line with a manual shut off. So I leave the main tank off and run the back tank out first. The use the main so I keep the res warning on low fuel.
Old 06-14-2011, 10:10 AM   #158
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
getting the pannier mount set up this position seems to work well
Old 06-14-2011, 07:53 PM   #159
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
on the road with a little seat time. bike is going to be a hoot
need to adjust shocks and change sprockets for more swingarm clearance. It is just a touch loose feeling above 80mph, but one the rear shocks are adjusted right I think that will smooth out.
Old 06-14-2011, 08:01 PM   #160
ohiofathead
Oddometer: 308
Awesome!
Can't wait to see some off-road video.
ohiofathead is online now   Reply With Quote
Old 06-14-2011, 08:13 PM   #161
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,600
I'll have to work out the gearing and swingarm clearance before getting to aggressive off-road. May need to shortent he shocks some to get the swingarm angle in check.
Old 06-14-2011, 09:54 PM   #162
Czechsix
Slower than you....
Czechsix's Avatar
Oddometer: 315
Damn, that bike looks tall. What's the seat height?
FYCYFF (Dakar 2011)
'98 XR400R, Rokon , '81 GL1100, '15 TW200
SDAR, CORVA
Go, Antonio, go!
Czechsix is offline   Reply With Quote
Old 06-14-2011, 10:04 PM   #163
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,547
How about moving the shock mount back on the swinger ?
It'll lower the bike to a degree and get the angle where it needs to be also. You'll have to experiment with spring rates again but, the whole progect is a experiment, right?
Old 06-14-2011, 11:17 PM   #164
JimmyTheHog
Oddometer: 714
Looks awsome !
I want to see some air !!!
Really interested to see how you are attaching the panniers.
Jim
Old 06-15-2011, 06:04 AM   #165
ULY-RPG
cool hands adv
ULY-RPG's Avatar
Oddometer: 297
I love it,too bad HD dosen't have that in their line up!!!
ULY-RPG is offline   Reply With Quote
Times are GMT -7.   It's 05:29 PM.
