Old 04-08-2011, 08:57 AM   #76
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
Originally Posted by Kawidad View Post
A thought that has occurred to me is the foot peg mounts directly to the engine case. That is a serious weakness. BMW did that on the GS1100 and had issues with it. They fixed it with a steel plate that mounts to the frame and then redesigned it for the revised GS1150.
Do you think you can fabricate something like that?
yea its possible
johnwesley is offline   Reply With Quote
Old 04-08-2011, 12:35 PM   #77
JimmyTheHog
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
Originally Posted by johnwesley View Post
yea its possible
I think thats what this guy did....if you look closely, it looks like a bar attached to the frame bottom and footpegs attached. Master cylinder still attached to the motor...
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 04-08-2011, 12:55 PM   #78
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
the two baja bikes did frame mounts too
got a pic of the other side of that bike ?
Old 04-08-2011, 02:27 PM   #79
Jeff Watts
Oddometer: 52
Is there a build thread on this bike?
Jeff Watts is offline   Reply With Quote
Old 04-08-2011, 05:31 PM   #80
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
I have been waiting a while for this to come in. It is a lot smaller than the stock piece and looks nice as well.
I got some wiring done this afternoon. The plus side is it works . I started the bike and all was well no fire or sparks. I like the sound of the ss2r has a different sound than any Harley I've heard
So tomorrow I'll work on wiring the dash and blinkers, can't wait to see the HDB led blinkers. The switches they sold me work well. As does the klr throttle and cables. I had to add a piece to the carb to make it work but it works well and is smooth
Old 04-08-2011, 07:43 PM   #81
JimmyTheHog
Oddometer: 741
This is the only picture Ive seen of it. Havent seen any build thread. If I remember correctly, I think someone posted it here saying it was for sale in Australia - a while ago.
Jim
Old 04-09-2011, 08:15 PM   #82
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
got a little more wiring done today. I like to use the two layer heat shrink cause it forms a waterproof seal and adds a strain relief to the wires. All the joints are soldered to form a strong joint.
here is one use of the two layer heat shrink it has sealed these two wires
this is used as a strain relief
an additional strain relief as the small wires join together going back to the vapor
I won't bore you with all the ins and outs of the wiring to day, but I am getting close to buttoning up the front and having a tidy wiring harness
johnwesley screwed with this post 04-10-2011 at 11:31 AM
Old 04-10-2011, 12:44 PM   #83
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
I've got the bike where I can see the bottom well enough to look at that. It seems that one could attach the foot pegs to a square tubing going across the bottom frame rails and that would also work for a platform to attach the bash plate to. If there was one in front and another to the back for the pegs then the plate would be low enough to cover the exhaust and left side engine with a flat piece of aluminum. So that really makes the bash plate easier and solves the issue of standing position being correct, plus as you point out may save the cases
Old 04-11-2011, 06:13 PM   #84
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
Laugh
I've been thinking of names for this thing that have not already been taken by the few before me, So leave it to facebook to come up with the name "Dual Sporty" I like it and think it'll stick
Old 04-11-2011, 06:23 PM   #85
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,809
2006 - Triumph Tiger
1995 XR650L
atokad is offline   Reply With Quote
Old 04-14-2011, 08:49 AM   #86
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 718
Sportduro or Sportyduro.
Not to complain but it's been days since you and the other Sporty Build have posted. You two guys are the "Godfathers" of this conversion movement. Good luck, Don John
Les
Obsessive compulsiveness always trumps good sense.
lesman is offline   Reply With Quote
Old 04-14-2011, 12:30 PM   #87
JimmyTheHog
Oddometer: 741
Yah John ! - Get busy !!! We need progress !!!!!!
Jim
Old 04-14-2011, 04:02 PM   #88
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
ok here's a vid, but i am about to be out of the loop for a few weeks
Old 04-15-2011, 07:16 AM   #89
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 719
John thanks for the update, sounds good.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 04-15-2011, 11:35 AM   #90
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,636
Bad news is that the ttX shocks I was sent picks of are not in production yet and are not suppose to be done until the middle of may, then there will be shipping time and build time so I would not get them at best until middle of June. I just cannot wait that long so I have gone with Ohlins 36prxw. they should be ready next week
One concern that was brought up in this post is the steering stops being too weak. Just so you know I do listen to the suggestions it just takes awhile to get back to them. Anyway here is the new steering stop it should hold up
I like to use tank panniers as they are a very convenient storage place and help to keep the weight balanced front to back. The issue is trying to figure it out with such a small tank . the two set I have are the aerostich and the wolfman bags. Here is how they look on the bike.
wolfman
aerostich
I think the aerostich bags look and work better whats your thoughts
Times are GMT -7.   It's 02:32 PM.
