Old 02-20-2011, 07:11 PM   #1
allanbem OP
Oddometer: 1
Question bmw r90 starter relay wiring
Does anyone know the the proper wiring to the starter relay on BMW r90/6 . Mine was disconected when I got it.
allanbem is offline   Reply With Quote
Old 02-20-2011, 07:14 PM   #2
blaine.hale
blaine.hale's Avatar
Oddometer: 3,104
FULLSIZE:
http://farm4.static.flickr.com/3502/...052bbe6c_z.jpg
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 02-20-2011, 08:48 PM   #3
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Here, this should clarify things.
This from an original /6 factory manual from BMW
Sorry, but my scanner is busted so I drawed it.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-21-2011, 12:02 AM   #4
El Hombre
Oddometer: 1,536
Put some grease on the female terminals, all the crap coming off the front wheel seems to end up under the tank and corrode those leads.
I've had my tank off a couple of times in the last couple of years when it wouldn't start, cleaning the terminals fixed it. It impressed the guys I was with that I could whip the tank off that fast and fix it. Of course they had newish Jap bikes, so they don't get that vintage ownership vibe..
El Hombre is offline   Reply With Quote
Old 02-21-2011, 01:49 AM   #5
mfp4073
mfp4073's Avatar
Oddometer: 2,395
Its late, Ive seen 500 miles of racing, been up for 20 hours on 3 hours of sleep, drove 6 hours total.....but thats some kinda funny to me right now!
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 02-21-2011, 06:29 AM   #6
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,121
If the relay doesn't work once it's all wired up proper, there's no need to spring for the super expensive stock unit. The only difference between it and a normal (inexpensive) one is a couple of spades for connecting two totally disrelated leads - they have nothing to do with the relay with no connection internally.
Old 02-21-2011, 08:58 AM   #7
melville
melville's Avatar
Oddometer: 1,458
You have my attention. Which are the redundant ones? What sorta relay would do?
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Old 02-21-2011, 09:42 AM   #8
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
he's talking about the blue leads.
www.wirewerkes.com
wirewrkr screwed with this post 02-21-2011 at 11:52 AM
Old 02-21-2011, 10:39 AM   #9
Wirespokes
Wirespokes's Avatar
Oddometer: 8,121
I believe all the data is in the Airheads parts sticky thread at the top of the page. Without looking at the data, it's just a normally open relay, and the two blue wires (as wirewrkr said) just get connected together on their own.
Old 02-21-2011, 07:32 PM   #10
Overdog
'Burghherfer.....
Overdog's Avatar
Oddometer: 240
I'd just call Rick at Motorad elektric....he'll fix you up. I had found an article on line on how to replace the relay with a GM A/C relay...my parts store didn't have the exact part but I fould a similar relay. Wired it up and it worked fine.....for a month or two. Three times the bike started cranking on it's own....with the key turned off! Luckily I was near the bike each time it happened. I got a different relay from Rick and paid less than i did at the local parts store.....it's been fine since.
1983 Goldwing Interstate
1974 R90/6
1971 Honda CL 350 (shed queen)
Overdog is offline   Reply With Quote
Old 11-08-2014, 06:36 PM   #11
picinisco
Scottish Transplant
picinisco's Avatar
Oddometer: 473
Why are the terminal numbers here different from the wiring diagram?
D+, 15, 30, 31b, 87
as opposed to
85, 61, 30/15, 86, 87
Cheers...John - 2004 BMW R1150GS, 1978 R100 (G/S Frankenbike)
Bikes That have Moved On:
1978 Suzuki GS550E, 1978 Kawasaki KZ1000P, 1982 Honda XL500R, 1995 BMW R1100RSL
picinisco is offline   Reply With Quote
Times are GMT -7.   It's 05:36 PM.
