Old 03-27-2013, 04:25 PM   #31
hugemoth OP
hugemoth's Avatar
Oddometer: 3,032
My Lifan 200 dual sport bike has turned over 40,000 miles. The engine is running as good as ever and has never had a single problem. Oil changes, valve adjustments, centrifugal filter cleaning, and one spark plug over all those miles. It is among the most reliable bikes I've ever owned in 46 years of riding.
Had to tow my friend's Suzuki 400 with under 10,000 miles back to camp with it last week.
Old 04-11-2013, 02:46 AM   #32
SpannerX
SpannerX's Avatar
Oddometer: 87
That's pretty impressive, I have to say.
'05 KLR 650
'80 P200E
SpannerX is offline   Reply With Quote
Old 04-11-2013, 11:59 AM   #33
sintegua
Principiante
sintegua's Avatar
Oddometer: 21
I have owned 2 Lifan bikes. The first one, 100cc, 4T.... very reliable. I used it as a daily conmute, very cheap, fun to drive... a bit "small" for me, but at the end, a nice bike. I have made with it more than 40,000kms when I sold it.... no major repairs, just normal service, and electrical plant change at 38,000 kms more or less.
The other one is my scooter, 7 years with me and almost 50,000 kms with me. Almostg the same history, normal service, but with this I have put new cilinder, and pistons 15,000kms ago (the motor seize up). The spare parts for this motorcycles are very cheap in my country, I just spend $27.00 for the new cilinder, piston, rings, gasket kit.
sintegua is offline   Reply With Quote
Old 04-17-2013, 02:04 PM   #34
hugemoth OP
hugemoth's Avatar
Oddometer: 3,032
First problem to report on my Lifan 140cc engine. 11,000 miles on the clock now. Under hard acceleration in first gear it feels like the chain is jumping a link on the sprocket but its internal. I suspect the shifting fork is bent, letting the dogs slip under a big load. Its spent much of its 11,000 miles being ridden off road in first and second gears. I'll split the case and have a look when I get home next month.
Old 04-18-2013, 06:31 AM   #35
RLK
4,949
RLK's Avatar
Oddometer: 6,490
There's a great yahoo group with almost real-time questions and answers every day. I think its called honda_clone at y! groups. Theres lots of wiring diagrams detailing how to put which lifan into which C bike. 12v/6v conversions, AC or DC headlight, e-start, winkers, There's diagrams for all of it in the database.
It takes less time to do things the hard way than to be too nervous to even start at all.
-Juanito on the Yahoo!
RLK is offline   Reply With Quote
Old 04-19-2013, 03:43 PM   #36
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,387
A nice examination of what happens when you thrash a C90 engine across the world..
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 05-02-2013, 06:50 AM   #37
Sam Bateman
Oddometer: 18
Lifan 125 Exhaust Question
I've got a 1975 CT90 for which I've recently purchased a Lifan 125 semi-auto clutch to replace the destroyed original motor.
I'd like to keep this bike as stock appearing as possible and would like to use the original exhaust.
Do you think it would be too restrictive for the 125?
This is the square motor (54 bore and stroke).
Sam Bateman
Arvonia, VA
Sam Bateman is offline   Reply With Quote
Old 05-05-2013, 12:42 AM   #38
Sam Bateman
Oddometer: 18
Anyone have any thoughts on this?
Old 05-05-2013, 04:28 AM   #39
hugemoth OP
hugemoth's Avatar
Oddometer: 3,032
The stock exhaust won't fit the Lifan head because the flange is different but you can make it fit with some cutting and welding. It will be more restrictive than a pit bike exhaust but probably not too bad because the stock exhaust on the CT90 is a pretty good size.
Old 05-05-2013, 04:36 AM   #40
hugemoth OP
hugemoth's Avatar
Oddometer: 3,032
I've had my first problem with a Lifan engine, the 140 with just over 11,000 miles. Under hard acceleration in low gear it momentarily pops out of gear. Won't have a chance to pull it apart until late summer but I suspect either loose shift drum stopper or a bent shift fork.
Old 05-05-2013, 07:41 PM   #41
Sam Bateman
Oddometer: 18
OK Thanks, that was kinda what I was thinking as well.
I'm gonna try it and see how it works.
Really anxious to see how this 125 package will work on the CT90. I've read good things about the conversion and the Lifan seems like a super value.
Sam Bateman
Arvonia, VA
Old 05-06-2013, 08:26 PM   #42
Mini Trail
nb
Oddometer: 2,302
Great news about the incredible mileage you got from the 200. I understand that the 200cc engine will fit my CL100. I actually considered that option rather than splitting the cases (again) to replace the kick start shaft but I worried about the reliability of the Chinese engine.
Why is the Lifan engine a pushrod design? Is that a copy of a particular Honda? Every Honda mini bike, motor bike, 3-wheeler etc has been OHC. It almost seems like a downgrade to the CL100.
Your cycle had a bell on it.
Mini Trail is offline   Reply With Quote
Old 05-07-2013, 03:53 AM   #43
hugemoth OP
hugemoth's Avatar
Oddometer: 3,032
Lifan actually makes both OHC and push rod 200s but the push rod engine is the most reliable and biggest seller. It's an upsized clone of a Honda CG125 engine that was/is used in bikes that were never imported to the US.
http://en.wikipedia.org/wiki/Honda_CG125
The only drawbacks to push rod engines is the RPM can be limited by the weight of the valve train (valve float), and a bit of clicking from the rockers. Still the red line is somewhere above 8,000 RPM. The advantage is there is no cam chain and tensioner to adjust or fail.
hugemoth screwed with this post 05-07-2013 at 04:03 AM
Old 05-14-2013, 03:18 AM   #44
minimotos95
it's a KLR who cares
minimotos95's Avatar
Oddometer: 189
My lifan 120(1 down 3 up manual clutch) is running strong and starts up easier then any honda motor i've had... however like most lifans and some genuine Honda's the trans is clunky and is hard to find nuetral with, the transmissions with all the gears up seem to be more solid in my experience.
with my 3.00-12 rear tire and i think 16-32(i'll edit this next time i look if it's wrong) gearing it tops out at 53mph GPS on a good day limited by RPMs.... it really loves to cruise at ~38mph, it's fine at 45 but i don't like it revving that high for more then a few miles
Youtube channel
ttr50 sitting in the corner, sad and lonely
1995 klr650 do it all daily rider
minimotos95 screwed with this post 06-10-2013 at 03:50 PM
minimotos95 is offline   Reply With Quote
Old 05-18-2013, 12:42 PM   #45
hugemoth OP
hugemoth's Avatar
Oddometer: 3,032
I took the 140 engine apart to find out what was causing it to jump in 1st gear. Found the shift drum stopper bolt had come loose witch is a pretty common problem on the horizontal Honda engines. Being the curious type I went ahead and split the case to check the gears, shifting forks, etc., and all was well. Ordered a gasket set for $12.50 including shipping.
One thing I did find is a bit of wear on he center ridge of the cam chain guide wheel (plastic) that fits inside the cylinder casting. I'll replace it although it would probably work fine as is.
Times are GMT -7.   It's 04:54 AM.
