Old 07-26-2013, 03:15 PM   #61
hugemoth OP
hugemoth's Avatar
Oddometer: 2,853
Missed that post.
Yes, it will fit as well as any of the horizontal Lifan engines. That's not to say it's an easy change for someone without the proper tools or mechanical aptitude.
The engine in the eBay ad has minimal electrical output that will not power lights and charge battery for street use. For use on a street legal bike you will need to install a higher capacity stator and flywheel as well as a rectifier/regulator. Figure an additional $100 - $150.
Originally Posted by Dirt Road Cowboy View Post
Wow! Prices sure have gone up on those!
They were about $125 less last year.
To answer your question, yes they will work in a CT90 with some slight modifications. They will drop right in a CT200 (the older Trail 90).
Hugemoth would be someone to ask, since he has experience with a few of the Lifans.
The Yahoo group is a good source of info too, as well as Dr. ATV.
I'm building a CT200 with a Lifan 140 right now, completely from a big pile of spare parts from different bikes. I'll post a build report soon.
Old 07-26-2013, 08:54 PM   #62
bama jama
bama jama's Avatar
Oddometer: 21
My CT200 with a lifan 140.
Oil cooler is connected wrong!
Bill
Honda CT200 Lifan 140
bama jama is offline   Reply With Quote
Old 07-26-2013, 09:35 PM   #63
hugemoth OP
hugemoth's Avatar
Oddometer: 2,853
Clean looking old machine! You're going to need ear plugs.
Old 07-27-2013, 11:08 AM   #64
bama jama
bama jama's Avatar
Oddometer: 21
Thanks hugemoth.I have a baffle in it,not too bad.I rode Harleys so it is quiet compared to some of them.
Bill
Old 03-25-2014, 05:15 PM   #65
DoubleBit
DoubleBit's Avatar
Oddometer: 305
http://sacramento.craigslist.org/mcy/4391861181.html
Here's a perfect candidate for a lifan swap.
Just trying to find a good home for my abandoned project.
Thanks.
Current rides: DR650, CT90.
Riding whatever runs, wherever I want.
DoubleBit is offline   Reply With Quote
Old 05-01-2014, 12:57 PM   #66
trktwo
trktwo's Avatar
Oddometer: 5
subscribed
trktwo is offline   Reply With Quote
Old 05-27-2014, 06:41 PM   #67
4doora
Moped guy
4doora's Avatar
Oddometer: 26
Does anyone know where I can get a lock washer that will fit the nut that holds the centrifugal oil slinger on my 140 lifan? My motor never had one, and the nut's come loose twice now. The first time it happened I even used red loctite, and it still managed to back off.
I'm sure I could source an oem honda one, but I'm not sure which models had the same size nut... I know there were at least 2 different sizes.
On another note, after I tightened everything back together the other day, I took my ct200 for it's first off road excursion. I thought I may have killed her when I found myself stalled in a mud puddle over a foot deep (just up to the carb, mind you). After sloshing through it back to dry dirt, she started back up first kick! I love this bike.
4doora is offline   Reply With Quote
Old 05-27-2014, 07:07 PM   #68
deezildennis
Its a what?
Oddometer: 828
I have put Beveled washers on these. I got them from Tbolt usa. I Just called and told him the Size of shaft I wanted it to slip over and he sent me 2.
They worked fine but next time I will Peen them in 4 spots on the outer face near the threads once it's on and tourqed like I have done in the past. That keeps them on just fine even in the High revving pit bike engines.
deezildennis is offline   Reply With Quote
Old 06-12-2014, 10:04 PM   #69
papawhellie
Oddometer: 57
Vertical chinese 150/200 for xl125s
Spent a little time searching the net and wondering if anyone has experience putting a vertical Chinese engine in a 1985 XL125s. These were Brazilian made 2 valve Honda's. Picked one up for a 100 bucks with a silver dollar size hole in the piston from the intake valve. Thought the clone engine would be the cheapest route to a cool bike with e start and power. I will try and get a photo up.
papawhellie is offline   Reply With Quote
Old 08-04-2014, 11:02 AM   #70
2speed
Puching adventurer
2speed's Avatar
Oddometer: 850
Anyone know what the base jet sizes should be for a 110cc clone motor and a PZ19 carb?
Loud intakes save lives!
2speed is offline   Reply With Quote
Old 08-05-2014, 06:40 PM   #71
WECSOG
Location: Just past the pavement's end in North Alabama
Oddometer: 375
I think the main jet should be a 75. Not sure about the pilot jet.
'94 Sportster 1200
Junkyard Dog Franken-Trail 90
'72 XL250/CG200 (Project)
'74 Jialonda XL70/125
www.possumliving.com
WECSOG is offline   Reply With Quote
Old 08-06-2014, 08:46 AM   #72
2speed
Puching adventurer
2speed's Avatar
Oddometer: 850
Thanks....I'll start there.
Old 08-06-2014, 09:31 AM   #73
WECSOG
Oddometer: 375
Check out this thread and forum. It goes into some detail on the PZ19 carb.
http://hondatrailcts.yuku.com/reply/...b#.U-JJsKOEXrR
'94 Sportster 1200
Old 08-27-2014, 12:12 PM   #74
hugemoth OP
hugemoth's Avatar
Oddometer: 2,853
Update on Lifan 200
Somewhere over 50,000 miles on the 200 now and I have been noticing a slight rattle coming from the clutch side of the engine. Pulled the cover and found the clutch basket is a bit loose on the transmission input shaft splines. The clutch basket splines are aluminum and the transmission shaft is hardened steel. Ordered a complete clutch assembly new for $39. Also found the oil pump chain is stretched (actually worn at the pins) so I'll replace it along with the sprockets for a total of $20. Neither of these things would actually break soon but I like a quiet engine.
Old 08-27-2014, 06:53 PM   #75
WECSOG
Oddometer: 375
Hugemoth, how available are parts for the 200 and where do you get them? I'm considering the purchase of a Lifan 200 (163FML) to put in a Honda XL250 frame I have. Hopefully it is the pushrod motor, although the listing doesn't say.
'94 Sportster 1200
Times are GMT -7.   It's 06:09 PM.
