Go Back   ADVrider > Bikes > Hacks > Hack Vendors
Old 12-02-2012, 11:47 PM   #31
Agent Wayward OP
Oddometer: 375
Apologies, not been here for ages.
Yes, these are still available. But they are expensive to send to the US or Australia as a single tyre. 2 tyres makes a big difference.
I have not fitted one to a R1200GS rear, but others have.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Agent Wayward is offline   Reply With Quote
Old 12-07-2012, 12:18 PM   #32
Dickie
Seasoned Sidecarist
Dickie's Avatar
Oddometer: 48
If you need to know which rim size is needed for a tyre, here's an easy checker for you. http://www.carbibles.com/tyre_bible_pg4.html A 175/55/17 tyre should be mounted on a 5" up to 6.5" rim.
Dickie is online now   Reply With Quote
Old 12-08-2012, 02:58 AM   #33
Agent Wayward OP
Oddometer: 375
That's the theory.
In practice, fitting a car tyre to a bike rim works out differently. These tyres struggle to fit on anything wider than a 5.5" bike rim and will happily fit much narrower section wheels.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Old 12-08-2012, 04:42 AM   #34
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,032
Rod - Can you provide the diameter of the tires? I'm pretty sure it would mount on my R12GSA rim, but it's the clearance with the swingarm that has me worried. To spend that much $$$ for the tire and shipping only to find it rubbing, well, let's just say my wife would probably beat me.
Pete
I got a sidecar to travel with my dog. He never complains, is delighted to be with me, approves of my dietary choices, is a social butterfly who helps me meet folks, appreciates a good beer, snuggles better than my wife, and hangs on my every word as if it's the most profound thing he's ever heard. TravelsWithBarley.com
Boondox is offline   Reply With Quote
Old 12-08-2012, 06:07 AM   #35
Agent Wayward OP
Oddometer: 375
Pete
No problem, they are 610mm diameter, that's 24" for you guys!
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Old 12-08-2012, 01:01 PM   #36
kailuasurfer
Dreamer
kailuasurfer's Avatar
Oddometer: 379
Group buy?
I have one on my Rocket 3 and planning to order another. Anyone interested in a group buy? It looks like it will be around $250 delivered to GA.
kailuasurfer is offline   Reply With Quote
Old 12-08-2012, 01:15 PM   #37
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,032
Interested, but then I have the expense of shipping from GA to VT.
Old 12-10-2012, 09:59 AM   #38
Pugsley/Hobbfather
Oddometer: 415
To vt!
Unless there are others in VT, willing to drive to York, PA in the next few weeks, or any time!
If shipping to York, PA is a lot cheaper.
If not, I'll split it with you and leave from Barnard when you call.
Greg
Pugsley/Hobbfather is offline   Reply With Quote
Old 01-21-2013, 05:17 PM   #39
RF900Hack
Oddometer: 1
Thumb just got two
Bought two tires from Rod. Five days to SW Ohio.Overall positive experience.
RF900Hack is offline   Reply With Quote
Old 06-27-2013, 05:12 PM   #40
Csemaj
Oddometer: 4
Need the tire you sell !!!
I have a 2003 K1200RS sidecar tug wearing 185/55R17 rear rubber that i need to replace with the Bridgestone Potenza RE040 175/55R17 tire you can ship to the USA, please.
Contact me at cal.pounds@gmail.com to arrange the sale.
Thanks,
Cal (Csemaj)
Csemaj is offline   Reply With Quote
Old 09-11-2013, 07:04 PM   #41
Subrosa
Oddometer: 10
Anybody out there still discussing this topic?
Hello all. I've been stealing all your thoughts for years and just too lazy to sign up. Well I took the big jump last night did it.
I know the above conversation occurred in 2012, but did y'all ever find any resolution. In particular, is there a way to mount a car tire on my stock 2005 R1200 GS 17" spoked wheel? Or will a 17" car tire mounted on an aluminum or steel car wheel be made to fit?
I'm tugging a Dnepr sidecar that Bob of Texas Sidecars mounted for me with DMC Jay's mounting gear. And I've got a Heidenau on the bike now...and it only took 3000 miles to bring the steel belts to the surface.
I ain't crazy about the look of a smaller tire/wheel setup.
Also while on the subject, anybody got any suggestions about front fork conversions? It rides pretty well now, but at 70 it wears me out with the pull to the right getting progressively stronger the faster I go. And once I put the windshield on the boat the resistance got even stronger.
Ok, I'm firing off my first post. Hope y'all are out there.
Subrosa is offline   Reply With Quote
Old 09-12-2013, 08:49 PM   #42
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,024
Since you're a member now, you can use the Private Message system to contact other inmates directly about this. I'd start with Boondox--he prolly knows. Also BMWZenRider is an excellent source. Also, try DHoladay.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 03-17-2014, 12:12 PM   #43
Csemaj
Oddometer: 4
Found 'em in the USA... supposedly
http://www.ebay.com/itm/331144798462...84.m1423.l2649
Tire price is $66.51 with free std shipping in the USA. Above is a URL for an eBay seller in the USA has that tire. I was assured by seller that it is, indeed, 17" and NOT 16" as had been mistakenly advertised by another seller. Check for yourself before ordering, however. This works to replace a 180/55/17 motorcycle tire for a 5.0", 5.5", or 6" rim.
Fits the rear of BMW K-bikes running the 180/55/17 and, supposedly, clears the radius curve of their single swingarm, too.
I have a BMW K1200RS w/Hannigan sidecar and it is a breeze for steering at any cruise speed I have done up to to 75MPH because it has electric camber control that raises/lowers the outboard chair wheel by a range of about 4.5 to 5". See if there is a way to adapt such to your sidecar and your constant pull just to go straight will disappear. I'm 65 years old and getting too lazy to work so hard just to cruise straight down the road.
Old 03-17-2014, 04:55 PM   #44
the1mavin
Oddometer: 82
Any chance you have a different URL? This one is showing "This page may have moved or is no longer available".
Found it I think -- Tire on eBay
the1mavin screwed with this post 03-17-2014 at 05:03 PM
the1mavin is offline   Reply With Quote
Old 12-02-2014, 07:14 PM   #45
silvergoose
Oddometer: 52
Car tires to fit 17 inch mc wheeles
I just found a site: tires-easy.com Phone: 1-877-253-6191. They claim to have this tire in stock, in the US. Tire size is 175/55r17XL 88v BSW, Price:$44.80+ shipping.
I have never heard of the brand: Achilles, but it is DOT certified.
I will do some more research.
Good Luck
2002 BMW K1200LT
2003 Indian RoadMaster Chief
2008 Can Am Spyder(s) two times
2009 Moto Guzzi Stelvio
2007 Moto Guzzi Norge
silvergoose is offline   Reply With Quote
Times are GMT -7.   It's 03:02 AM.
