Old 02-28-2011, 10:18 AM   #1
jestre OP
BanditRider
jestre's Avatar
Oddometer: 95
Are you happy with Ammo Box Panniers.
I'm looking to add hard bags to my Suzuki Bandit. Just got a great deal on a NIB SW-Motech quick-lock siderack kit and installed it.
The idea of the Ammo cases is the right price point for me as well as the security. A new work promotion has me riding a 150 mile round trip twice a week. I can't handle my backpack for that long.
Can the ammo cases swallow a laptop case decently and stand up to daily use? are there any true downsides?
jestre is offline   Reply With Quote
Old 02-28-2011, 10:40 AM   #2
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,847
Ammo cans are very heavy - ~20lb a side for the 30/40mm ammo type
You can pick-up the pelican knockoffs on line cheap (Fry's here had some off brand in there store this weekend for $40bucks each) or used on Ebay
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 02-28-2011, 11:52 AM   #3
gmiguy
You rode a what to where?
Oddometer: 1,297
I tried ammo cans on an old CB750.
They're plenty tough - almost indestructible, really. But they're awfully heavy.
I wound up taking them off the bike in short order because I hated the weight. I'd recommend finding something else.
Can you just bungee your backpack to the passenger seat?
gmiguy is offline   Reply With Quote
Old 02-28-2011, 04:50 PM   #4
cloudshaver
marcusorass
cloudshaver's Avatar
Oddometer: 124
Yes they are a bit heavy, cheap, indestructible and I like em. I made a little vid-half way in the short vid shows how I did mine with quick release slap latches, check it out. http://www.facebook.com/video/video....87790&comments
Life is your souls vacation.
cloudshaver is offline   Reply With Quote
Old 02-28-2011, 06:17 PM   #5
betasigscoot
Palaverer
Oddometer: 151
Ammo cans are alright, but I wanted something lighter, already waterproof & with keys. I bought the Plano AW case #108030. It weighs ~10lb & can be bought for under $100/ea.
The downside are the plastic latches...I overloaded the box in 16F temperature with 2 drums & shoes for the cage + some winter gear & broke a couple latches. Plano sent me 4 for free.
betasigscoot is offline   Reply With Quote
Old 02-28-2011, 09:04 PM   #6
theWolfTamer
Lupie on a Mission
theWolfTamer's Avatar
Oddometer: 395
What about this?
With the foam removed, the inside dimensions are 9 3/4" by 15 3/4" by 2 7/8" per each side.
Used something similar on my Vx800.
Training to slay theWolf
Check out theWolfTamer Chronicles, my blog about my motorcycle life
theWolfTamer screwed with this post 08-09-2011 at 02:45 AM
theWolfTamer is offline   Reply With Quote
Old 03-01-2011, 05:52 AM   #7
romeo one
retired
romeo one's Avatar
Oddometer: 28
I have put two ammo boxes on my Transalp 43cm x 36cm x 20cm,they weigh 5 kilos each there a little bit smaller then my alloy cases which I have on my Africa Twin but they weigh the same,the ammo cases had 20mm rounds in them,as they are steel I have welded brackets to them to fit onto the pannier racks which I also made on the bikethey just need to be painted and I`ll try and post pictures.
http://www.xrv.org.uk/photopost/show...nniers/cat/500
romeo one is offline   Reply With Quote
Old 03-01-2011, 07:08 AM   #8
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Put a 30mm set on my KLR with HT racks and KLR650.com support brackets.
Pros
  • Cheap ($20-30 each)
  • Large size (37 liters)
  • Bullet proof steel construction (small calibers only)
  • Waterproof
  • Carry handles double as strap points
  • Field repairable (anyone can weld steel)
  • Very durable OD paint
Cons
  • Heavy (20-22lbs per side)
  • Did I mention they're heavy?
Overall I'm very happy with them. I chiseled a side support off each box to provide a flat mounting surface and added eye bolts so they can be locked. Only other "mod" I'm thinking off is to put a metal shim between the mounting bolts and pannier surface, spread the load around better.
Only pic I have online at the moment. Let me know if you'd like others.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 03-01-2011, 04:10 PM   #9
cloudshaver
marcusorass
Oddometer: 124
Simple lockable and easy on and off in seconds.
Old 03-01-2011, 04:13 PM   #10
cloudshaver
marcusorass
Oddometer: 124
I have a vid. too that shows how I put them together. 7 min vid in the middle if you want to skip to it. http://www.facebook.com/video/video....87790&comments
Old 03-02-2011, 05:04 AM   #11
newcastleadam
Artful Tagger
Oddometer: 3,455
Thanks for the vid and music. Could you provide more details on the quick release setup for your ammo cans? That looks like a very tempting mod.
Adam
Old 03-02-2011, 06:58 AM   #12
Superfish
Oddometer: 137
Got to change something
I mounted 20mm boxes (20# each) and then I weighed them with the stuff I wanted to carry. The 20# box had 15# of gear in it. So that is just not right.
I'm looking for some plastic boxes. They seem either too expensive or to flimsy. I have a bunch of dry bags that I've used before with smaller boxes but I'd like to have everything inside. Some people have accused me of using the Jedd Clampet method of packing.
If anyone has a specific source of serviceable boxes (DeWalt cases, etc) I would appreciate a reference. I know how to get $200 Pelicans -- ain't going to happen.
bob
"Live while you're alive"
1983 V65 Magna
1984 700cc Magna
1982 V45 Sabre (Project)
Superfish is offline   Reply With Quote
Old 03-02-2011, 08:09 AM   #13
Rider_WV
Rider_WV's Avatar
Oddometer: 2,325
Have you looked at the Sea Horse cases? I have used them as panniers on my Vstrom for a couple of years. They are fairly light, very durable, totally waterproof and easy to mount to existing racks. I use the 720s and can fit more than I need to in a pair. I have ridden in some major rain for extended periods and I have never had a drop of water in one. I forgot to lock one down one day on a dirt road and it bounced down the road at 30+mph and ended up in the ditch. Other than some superficial scratches and mud it was fine. My bud runs a set of grey ones on his Uly and they are holding up well. Shoot we used one as a center stand last fall when he lost a rear wheel bearing. Tough cases and a lot more affordable than Pelicans.
The 720's are $44/ea at this site, they have them on sale a lot for lower than that. PLus they have a few other sizes to choose from.
http://www.seahorsecasesonline.com/p...e720-Case.html
Rider_WV is offline   Reply With Quote
Old 03-02-2011, 12:32 PM   #14
Superfish
Oddometer: 137
Thanks, Rider:
They look good and the price is fair. However, I looked at the Weight and it's 17#. That's a saving of only 3 pounds -- they do look a lot better than the Ammo cans though.
I'm beginning to wonder if it's just that there are no plastic boxes that are as strong and lighter. My big Magna is a road bike so I don't need to worry about banging into trees or rocks. If I do that I've got bigger problems than a broken pannier. LOL
bob
1983 V65 Magna
1984 700cc Magna
Old 03-02-2011, 12:42 PM   #15
Snowbound
Oddometer: 877
Someone has cases for sale in the Rockies flea market .
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound screwed with this post 10-22-2011 at 09:20 AM
Snowbound is offline   Reply With Quote
Times are GMT -7.   It's 10:05 PM.
