Old 04-26-2011, 04:14 AM   #106
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
I got the tire from motorcycle superstore. It wasn't much.
Screw this shit. I'll meet you there.....
NachoRoto is offline   Reply With Quote
Old 05-16-2011, 07:33 PM   #107
coreymon
Oddometer: 7
how is your ruck doing i just ordered the kit today
coreymon is offline   Reply With Quote
Old 05-16-2011, 07:37 PM   #108
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
So far, so good. I ride it everyday. I ran the vacume lines wrong originally. Now I fixed it, but lost some speed. I need to rejet. It still does in the 50's. But not as easily.
Old 05-16-2011, 08:11 PM   #109
coreymon
Oddometer: 7
cool this will be my first time doing a conversion like this so i may need to bend your ear if that is ok. on an unrelated note i just pulled a power head off of a 2001 mercury 150 outboard, so i do know how to turn a wrench. if it is ok to ask you questions do you prefer pm's, or this, or some other forum.
Old 05-16-2011, 08:45 PM   #110
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
What ever you prefer. I am here if You need help.
Old 05-16-2011, 10:45 PM   #111
Bulldogs2k
Oddometer: 309
AWESOME! Just read your whole thread and I have to say I'm jealous of your scooter! Also, that's a big bulldog, mine barely tips the scale at 50 lbs and he's scared of anything that is large, metallic and loud. Rock on dude!
Bulldogs2k is offline   Reply With Quote
Old 05-17-2011, 09:22 PM   #112
btcn
btcn's Avatar
Oddometer: 2,880
Strange that you lost performance. What was wrong?
btcn is offline   Reply With Quote
Old 05-18-2011, 04:13 AM   #113
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
The short story.....
I ran the lines tight. And the line off the valve cover popped off. So I tuned it with a vacuum leak. Now it's getting much less air for the jetting. Feels restricted.
Old 05-18-2011, 07:50 PM   #114
coreymon
Oddometer: 7
aprox. what length of throtle cable did you end up using? rucksters is quoting me $40 for a brake cable and throttle cable.
Old 05-19-2011, 01:28 AM   #115
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
Not sure. I just used what they sent.
Old 07-10-2011, 11:10 AM   #116
coreymon
Oddometer: 7
i finally got my stuff from rucksters so the swap is getting closer. i still need a rear shock. where did you get yours/ what is the make and model? also as far as the wiring harnes goes did you use a schematic or just plug the stuff together. i started looking at it and i have the spark plug end identified and some of those connections around it. how is you ruck doing?
thanks
Old 07-10-2011, 11:25 AM   #117
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
I bought my shock in 2005. The ruckus bottoms out real easy above I am real fat. So it was the right move back then. I bought it from battlescooter.com.
Old 07-10-2011, 11:31 AM   #118
NachoRoto OP
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,738
The wiring I just plugged it all together. It was no big deal. As for my scooter, it's doing great. As it got warmer I had to readjust the air screw. But it feels good. I changed to Mr Pulley variator. It pulls good, but lost a little in top. It pulls strong thru 45 mph. After that it creeps. Top speed is no longer 60, but 56 mph. I find myself cruising in the high 40s most of the time with enough left for passing. The dog hates anything of 30. The wind is too much for him. I am working on winglets for him now.
Old 07-10-2011, 11:34 AM   #119
coreymon
Oddometer: 7
cool thanks!
Old 07-14-2011, 07:39 AM   #120
OBIWAN
OBIWAN's Avatar
Oddometer: 148
Doggles
Have you thought about getting him some Doggles?
__________________________________________________ _________
Far better it is to dare mighty things, to win glorious triumphs even though
checked by failure, than to rank with those poor spirits who neither enjoy
nor suffer much because they live in the gray twilight that knows neither
victory nor defeat. ------Theodore Roosevelt.
OBIWAN is offline   Reply With Quote
Times are GMT -7.   It's 03:35 AM.
