Old 03-24-2011, 08:00 PM   #46
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,777
Originally Posted by Visigothic View Post
Maybe this will work 110x90x25mm
Thank you for your constructive input, Goth. I don't think 25 mm is quite wide enough. Perhaps someone manufactures a plastic cigarette case, or something similar.
Spud
Old 03-25-2011, 07:03 AM   #47
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Nice writeup, Maybe just die electric grease the fuses excessively and cover it with a balloon, or a bag cinched down with a zip tie. The XR600 sideplate really looks so much better than that L sideplate, and a 9lb savings is great...
bobbed06 is offline   Reply With Quote
Old 03-25-2011, 10:22 AM   #48
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by Spud Rider View Post
I agree; it certainly appears the fuse box was designed to accept a lid. However, if the fuse box lid exisits, I don't know where to find it.
Spud
Spud,
You may owe me something......
Go here Select: Honda : NX250 AC (90) MOTORCYCLE, JPN, VIN# JH2MD211-LK200001
Select Wire Harness & Look at item #9
SKU: 38210-KW3-000 COVER, FUSE BOX $7.94
I think that is it....
Let me know.
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 03-25-2011, 10:53 AM   #49
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,520
Originally Posted by Cumbacheech View Post
...I think that is it.......
Pretty darn good sleuthing there, Cc
Costs about $8 to find out if it works
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 03-25-2011, 11:30 AM   #50
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Very nice work, what an improvement! I'm sure the bike is noticeably lighter feeling with the weight reduced and centralized
It might be worth putting some sort of insulating stuff (rubber, wire harness loom, whatever) around the frame near the positive terminal so that in the vent the battery twists in there the pos term can't short against the frame.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 03-25-2011, 12:29 PM   #51
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,777
Spud,
Let me know.
Cheers,
Cumbacheech
That looks like it will work, CC! Thank you for your excellent sleuthing.
Spud
Old 03-25-2011, 12:38 PM   #52
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,777
Thank you, Bobbed. Shedding 9 pounds from the bike feels great! It seems to me that removing 10+ pounds from the bike's left hip even makes the pig easier to lift from the kick stand. In tight quarters the slimmer pig is definitely easier to push around. I agree; the XR650L looks much leaner, and much better without the battery "goiter" hanging off its left side.
I think you are correct; some grease and a balloon would work just fine to weatherize the fuse box. However, I believe Cumbacheech researched the best solution!
Spud
Spud Rider screwed with this post 03-25-2011 at 07:31 PM
Old 03-25-2011, 12:43 PM   #53
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,777
I'm going to give the Honda, fuse box cover a try, OnO. After applying a little grease around the lip, this cover should do a great job weatherizing the fuse box.
Spud
Old 03-25-2011, 12:48 PM   #54
Spud Rider OP
Spud Rider's Avatar
Oddometer: 3,777
Thank you for the tip, and the kind words, BP. I am very pleased with the results from my Shorai battery relocation. Based upon my experience, I can heartily recommend the Shorai battery relocation without any reservations whatsoever.
Spud
Old 03-25-2011, 01:29 PM   #55
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Here's how I did Mike Wattners battery relocation, pretty close to how Spud did his.
I powder coated a piece of sheet metal and cut the ridge off around the air inlet hole and then pop riveted the metal plate over the inlet hole.
I then placed some velcro on the plate and a piece to the back side of the battery and stuck it in place, it's as solid as the rock of gibraltar with no movement, it's actualy hard to pull off the bracket.
I'm still going to place some foam and ti-straps around the battery cuz I know how hard Wattner rides his bike.
I also drilled some new holes in the air box for air since I blocked the inlet.
I left the plate back a tad so some air could still be pulled in around the battery..
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard screwed with this post 03-25-2011 at 02:04 PM
cyclewizard is offline   Reply With Quote
Old 03-25-2011, 01:31 PM   #56
cyclewizard
Oddometer: 4,814
Here's some more.
C-dub......
Old 03-25-2011, 01:32 PM   #57
cyclewizard
Oddometer: 4,814
more
C-dub......
Old 03-25-2011, 01:34 PM   #58
Cumbacheech
XRated
Oddometer: 823
Spud
Spud make sure you keep us posted!! That was the only thing that didn't give me the warm a fuzy feeling. I think we figured it out!!!!
Old 03-25-2011, 01:34 PM   #59
cyclewizard
Oddometer: 4,814
another oic
C-dub......
Old 03-25-2011, 01:35 PM   #60
cyclewizard
Oddometer: 4,814
last one...
C-dub......
Times are GMT -7.   It's 05:58 AM.
