04-13-2011, 03:38 PM
#61 | |
Uber Cyber Loafer
Oddometer: 2,926
Err.. potentially anything and everything
... As far as I can tell it's the main ground for the entire wiring loom. The dash wasn't connected. and bulbs fuses I can replace... I'm just freaking out that I may have fizzled the ECU. fingies x'd. ![]() Quote:
![]() It'll do for now, but when I have more time, I might have it cut off and re-done.
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz |
04-13-2011, 03:42 PM
#62 |
Uber Cyber Loafer
Oddometer: 2,926
Done:
Headlight mask - 5821100120070 (sorted thanks Mcguyver!!) Left radiator - 58335008000 done Radiator fan - 58435041000 done Radiator hose - 58435025800 FAN CAP - 58435044000 FAN CPL. 12V LC4 - 58435041000 Front wheel/rim (from woodies wheel works Spare indicators. Not original but will get me a WOF On its way: hurryupgoddammit!.Front subframe - 5821401010030 (ordered, on it's way.) New front tire. Dunlop 606 Ahhhhhmmmmmmmmmm... mebbe/on hold/Finkin abahtit: ![]() 5820701333370B FUEL TANK LC4-ADV. CPL. 06 (Mmmm on hold for now.) 58211001160 MASK BRACKET L/S ADV. 01 (will get this if/when I get a new tank) 5851209200030 BRACKET 30LT TANK BLACK 06 (have straightened my one.. but I really want a straight one.) HEADLIGHT LOW BEAM DUKE94 - 58311010000 (might try some Mikey-bodge/macguyvering.. ) 58412020000 SUITCASE CARRIER SYSTEM (might repair/straighten the existing pannier frames. apparently these are no longer available.. really )FLASHER CPL.FRONT L/S REAR R/S - 5841402500030 (missing a blinkykator... will include in next order.) Not essential but nice to have: 150002 BOLT HARDWARE KIT/TRACK PACK (a couple of mixed kits of common ktm bolts.)
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 04-13-2011 at 06:29 PM |
04-13-2011, 07:04 PM
#63 |
AKA Deanohit
Oddometer: 292
Great job so far.
![]() But heck that welding is a bit rough, I could have done a better job with my ARC welder, I hope he didn't charge you too much for that.
It's more fun to ride a slow bike fast, then a fast bike slow. \m/ (>_<) \m/ My XT225 Build |
04-13-2011, 11:18 PM
#64 | |
Oddometer: 30
Kokusan CDI CB7506 KTM #584 39031 700 Ignition Coil IG3826: KTM #584 39006 000 Hopefully you won't need them tho |
04-14-2011, 01:23 PM
#65 | |
Uber Cyber Loafer
Oddometer: 2,926
See below why...
04-14-2011, 01:48 PM
#66 |
Uber Cyber Loafer
Oddometer: 2,926
I spent another 5 hours in the shed last night.
It started with me trying to find where the main wiring loom ground wire. I knew it could just go pretty much anywhere on teh subframe, but wanted it in the right place so that I didn't have to pull it all off and do it again later. "Uhhh i'm a dumb arse so... can I phone a friend?" On the phone to KTM tech support (Clint in Rotorua. ) Clint popped out to his shed to tell me it should screw to the subframe on the big obvious thread right in front of me.. ok job done.So I carried on, reconnect the battery... switch on, press starter.. click... nothing... Time to start hunting leccy gremlins... ![]() I found an old testing light, and started going through the tracing process... Power at the battery... power at the ignition... power on/off back at the fuse box so can see the ignition switch is working, but there's nothing at the starter solenoid... According to the diagram there is another relay and diodes somewhere in the circuit... where the hell are they? And how do I test them? It was about this point I was running out of steam when Kelly my work mate come over to give me hand, and brought a Fluke circuit tester. (Kelly was a electrical repair tech in a previous life)![]() I showed where I had got to, power here, here and there, but not there.. I showed him the wiring diagram. I stood back and watched as Kelly got down to business with his circuit tester verifying what i had said and indvidually tested diodes, relays, grounds switches power... It was amasing to watch... he went at it like a starved chihuahua on a pork chop. Lots of on/off, try now.. ok, stop, do it again... Kelly had traced the power back to the Clutch switch and/or the gear/neutral indicator but it wasn't making sense. The bike was in neutral but the switch wasn't earthing out. ![]() I thought "hang on a sec..." I pulled the clutch in and hey presto... it turns over... ![]() A bit more testing and we find the culprit... The neutral indicator isn't working. Even though the bike was in neutral, the electrics think it is in gear. There are 2 safety switches on the KTM in the starter circuit to stop you from starting the bike in gear. One in the gearbox and 1 on the clutch. If the bike is in neutral no problem. If it's in gear you can bypass it by pulling in the clutch. Well since the switch is faulty, the bike thinks it's constantly in gear. So until I get that fixed, I just have to pull the clutch in... Once we had diagnosed that, we continued bolting the bike back together so I can get it to the Bike shop to have the brakes certified. This morning, on the way to the bike shop: ![]() I'm away for the weekend, and won't have bike back till next week.
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 05-17-2011 at 02:01 PM |
04-14-2011, 03:05 PM
#67 | |
Trans-Global Chook Chaser
Oddometer: 2,735
Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
04-14-2011, 03:52 PM
#68 |
Uber Cyber Loafer
Oddometer: 2,926
Dude...
Yup, confirmed. Have continuity from diode to where wire meets switch. touching tester on switch with bike in neutral doesn't get a ground. We could have double checked it by grounding the wire directly but didn't bother at the time.
Seriously... ![]()
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 04-14-2011 at 04:44 PM |
04-14-2011, 05:28 PM
#69 |
In need of repair
Oddometer: 1,459
Jaybo did some work on disabling the safety lockouts which you could look at. It was covered in the LC4 index, but I can't find that quickly yet.
04-19-2011, 01:38 PM
#70 |
Uber Cyber Loafer
Oddometer: 2,926
Last night.
I dropped by the bike shop to see how the patient was doing...
![]() And the prognosis is all good I hope to pick it up at lunchtime today and be working on it again tonight. The front subframe arrived last week while the bike was away, so now I have all the key pieces to start reassembling it.
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 05-17-2011 at 02:04 PM |
04-19-2011, 04:50 PM
#71 | |
Oddometer: 2,735
Cheers Clint
04-19-2011, 08:19 PM
#72 |
Uber Cyber Loafer
Oddometer: 2,926
Err.. almost but not quite.
It won't be Reg'd and WOF'd until next week at the earliest. (fingies x'd) I wish it was though.. would have loved a bit of trail riding..
And I don't know quite how it's happened but it's come home from the bike shop with a flat rear tire, and they left the key on and drained the battery.
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 04-19-2011 at 09:24 PM |
04-20-2011, 01:21 AM
#73 |
Oddometer: 24
Awesome project
Really sad how you came to have this bike but im sure your mate would be over the moon with what you are doing,looks like you are doing an excellent job of rebuilding. I also had issues with getting a bike back from the shop, took my vf to the local honda shop to get some new tires and they actually SCRATCHED arrows into my nice gold rims(directional arrows presumably).Of course the apprentice denied anything. well done mate.Awesome project.
04-20-2011, 04:10 AM
#74 |
Uber Cyber Loafer
Oddometer: 2,926
Another busy night in the shed.
I managed to get the new front subframe on and have untangled most of the wiring. Lots of fiddly little jobs, stripping wires & replacing connectors and straightening little bent bits and pieces. Oh... and cable ties... lootts of cable ties... oh how I love thee... let me count the ways...
![]() The new subframe didn't quite line up correctly with the tank mount. Suggesting that the tank mount isn't quite straight, so we adjusted it a little with a cunning application of a crowbar. Dad wanted to bend my nice new subframe to make it fit the bent tank mount. "No dad... we're not bending the straight bit... how about we straighten the already bent bit eh?" Ok.. thats not exactly what I said. But thats what I was trying to say. ![]() The dash lights up, the horn now works, and the rear indicators work too. (still need to add/reconnect the front ones.) There's still lots of little jobs to go but a few more nights in the shed should have sorted.
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 04-20-2011 at 04:22 AM |
04-25-2011, 01:56 PM
#75 |
Uber Cyber Loafer
Oddometer: 2,926
I suck at fishing
I spent Easter weekend in Rotorua with the inlaws, trying my hand at fly fishing. Not a sausage... or a fish for that matter. Personally I think the fish where doing it wrong.
Jess and I caught up with Clint and Rosie for a few beers and a great lunch. thanks guys Got back mid-day Monday and got back out to the shed, trying to get the beasty back in one piece. It's coming together nicely. I glued the headlight back together, but have to wait for the glue to set and harden properly before reinstalling the headlight. I fit the temporary indicators in the fairing and am almost ready to install it except I have wait for the glue on the headlight to dry. ![]() I've called the Engineer and penciled in his inspection for tommorrow.. and I've called VTNZ, and have booked in certification for Friday. (Fingies x'd)
Kiwipeet and Kiwirob on the South Island Tractor Trek for Cancer Kids!! | Mike & Simon: London to Capetown! | M1K3Y | http://www.ecmot.org.nz kiwipeet screwed with this post 04-25-2011 at 04:30 PM |
