07-06-2011, 11:25 PM
#61 | |
Oddometer: 2,944
Indeed, my Primary Drive, rear sprocket is very worn, and I plan to replace it in the near future. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
07-07-2011, 09:01 PM
#62 | |
Oddometer: 459
Mike B
04' XR650L DIY: IMS Baja Install + Smog Removal, XR650L & Custom Oil Cooler + 12V Power Outlet, XR650L 108days. 17,048miles. XR650L USA Tour |
07-07-2011, 10:11 PM
#63 |
Oddometer: 2,944
I started replacing both my sprockets and my drive chain this evening, but I ran out of light, Mike.
I will finish the job tomorrow with the following parts:XR650R, 14-tooth, Primary Drive countershaft sprocket XR650L, 48-tooth, Primary Drive rear sprocket RK 520EXW drive chain, 110-links ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 07-11-2011 at 01:13 AM |
07-11-2011, 01:06 AM
#64 |
Oddometer: 2,944
Several days ago I installed a new drive chain, and new sprockets. Therefore, I took the opportunity to inspect my chain rollers. Here is a photograph of my chain slipper roller after 10,600 miles of wear.
![]() ![]() Here is a view of my mounting hardware, and the port side of my single Spud Roller after 5,700 miles of total wear, and 600 miles of wear as the solo roller in my chain guide. ![]() Here is a top view of my single Spud Roller after 5,700 miles of total wear, and 600 miles of wear as the solo roller in my chain guide. ![]() When I installed my new drive chain, I switched from a 13T/45T sprocket combination to a 14T/48T sprocket combination. Since the larger rear sprocket has lowered the bottom of my drive chain, I am glad I switched to a single Spud Roller. The single, forward roller allows more clearance from the rear sprocket, and facilitates removal of the rear wheel, et cetera. ![]() ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 07-11-2011 at 02:09 AM |
07-12-2011, 11:12 PM
#65 | |
Oddometer: 459
Mike B
07-13-2011, 12:17 AM
#66 | |
Oddometer: 2,944
After riding with this chain slipper roller for over 10,600 miles, I have noticed the drive chain seems to merely, lightly tap this roller. ![]() Unlike the stock "chain slipper," which wears quickly, and needs to be removed to be inspected, this chain roller is very easy to inspect for wear, and proper operation. The surface of the roller is easily visible for convenient inspection, and you can quickly spin the roller to ensure its operating properly. The mounting hardware is also very easy to inspect. Just give a tug on the nyloc nut to ensure it's still tight. I have never had this chain roller loosen on me in over 10,600 miles of riding. As you noted, the drive chain never touches the frame, so the roller is performing its job superbly. The only downside to this chain roller is a slight increase in noise from the drive chain as it intermittently, lightly taps the roller. The stock chain slipper costs about $14, plus shipping, and it wears much faster than this chain roller.Incidentally, I think all the commercial chain rollers need more grease in the bearings, even when they are brand new. I didn't grease this roller before I installed it, but I wish I had. Here is a photo of the original grease left in the bearing after 5,000 miles of wear. ![]() ![]() Therefore, I recommend that XR650L owners grease the bearings before they install this roller, and add new grease to the bearings once a year. ![]() ![]() Spud
07-24-2011, 10:08 PM
#67 |
Oddometer: 2,944
I'm pleased to report my single Spud Roller is performing very well in my chain guide.
![]() ![]() Here is a photo of the top view of my Spud Roller after 7,200 miles of total wear, and 2,100 miles of solo wear in my chain guide. ![]() ![]() Chain rollers offer several advantages over chain sliders. 1) The open, bottom end of the chain guide collects less dirt and mud with a chain roller, rather than a chain slider. 2) The rotating chain roller induces less friction on the drive chain than a chain slider. 3) My Spud Rollers are less expensive than the OEM chain slider. 4) My Spud Rollers appear to wear longer than the OEM chain slider, especially in dirty, or muddy environments. 5) A chain roller is easier to inspect for wear, and therefore requires less maintenance than the OEM chain slider. To be fair, a possible disadvantage of chain rollers is they produce more noise than the OEM chain slider. However, as my Spud Roller "breaks in" after 7,200 miles of use, I'm pleased to report it is becoming much quieter. If you are interested in purchasing either a single Spud Roller, or a pair of Spud Rollers, please refer to my thread in the Vendors Forum. ![]() http://www.advrider.com/forums/showthread.php?t=694545 Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 07-25-2011 at 07:37 AM |
11-10-2011, 01:04 PM
#68 |
Oddometer: 34
Rollers
Hello Spud Rider will the rollers fit on the XRR?
03-19-2012, 08:18 AM
#69 |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,390
Hey Spudman! How's it going?
I'm finally getting around to replacing the shift shaft in my XRL - what a job! In looking for further trouble, I've found the swingarm slider and chain slipper about shot. I was thinking of a slipper roller as in your mod here, so I came checking your thread trying to find a specific part to order. I went to find the part as you said for a 2000 XR650R and it shows that bike using the same static slipper as the XRL. The XR400R DOES use a roller there but it doesn't specify what diameter. Is that the part for the front roller to use? (52158-HC0-000 ROLLER, CHAIN $8.76 $7.71 In-Stock) My rear slider looks plenty serviceable yet so I don't plan to mess with that yet. Thanks!
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
03-19-2012, 06:38 PM
#70 |
Oddometer: 2,944
Please excuse my belated response, Islano.
I guess my notifications were turned off for this thread. ![]() I only own an XR650L, so I can't verify the chain rollers will fit other Honda XR models. ![]() Spud
03-19-2012, 06:42 PM
#71 | |
Oddometer: 2,944
![]() I replaced my "chain slipper" with a Primary Drive, lower chain roller designed for the 2000, Honda XR600R. This chain roller is 38 mm in diameter. I purchased the Primary Drive chain roller from Rocky Mountain ATV/MC. ![]() http://www.rockymountainatvmc.com/p/...E+CHAIN+ROLLER Spud
03-20-2012, 05:19 AM
#72 | |
Oddometer: 4,390
Rocky Mountain must be in error. When I brought up the above link, it says: 1096220001 Primary Drive Chain Roller Large 38 mm Black – Fits: Honda XR600R 1990–2000 $9.99 1096220001 Primary Drive Chain Roller Large 38 mm Black – Fits: Honda XR650R 2000–2007 $9.99 However, when I look at the fische for the 2000, Honda XR600R, I don't see it. I see the static slipper - #7 ![]() Which is why I couldn't find a Honda part number. I appreciate you getting back to me Spud-man as now I have a MFG (Primary Drive) and a part no. (1096220001). I was about to order one for an XR400R - problem is (if I can believe what I'm reading in Rocky Mountain), that's a 31mm wheel (instead of 38mm which you have vetted for our XRLs): 096220004 Primary Drive Chain Roller Small 31 mm Black – Fits: Honda XR400R 1996–2004 $9.99 I may have to cross something else to the primary drive number in order to get all my parts from the same vendor. We'll see... (I'll let you know) Always a pleasure! Best wishes!
03-20-2012, 12:40 PM
#73 | |
Oddometer: 2,944
Oh well, just order the Primary Drive chain roller I mentioned. Don't worry about the Honda parts compatibility. That Primary Drive chain roller will work perfectly for you. ![]() Spud
03-20-2012, 06:24 PM
#74 | |
Oddometer: 4,390
Should be interesting... Thanks!
03-20-2012, 10:02 PM
#75 | |
Oddometer: 2,944
Any of the large chain rollers which has a diameter of 38-42mm should work just as well. Spud
