Old 03-14-2011, 02:13 PM   #1
Platypus-3in1 OP
Fluid Journey
Platypus-3in1's Avatar
Oddometer: 724
2 into 1 Exhaust ... Q
Linked from BlackDog - AdventureTank sells a 2 into one pipe and states that it drops 16lbs - Improves torque from 2500 - 7500
KTM 990 Adventure 2010 - 11
>>>>>AND NO Rejetting or Reprograming is required <<<< IS THAT TRUE?
Does anyone have this with the Remus TI?
Would this be too loud for forest roads? (Tennessee ... Not SoCal)
Platypus-3in1 is offline   Reply With Quote
Old 03-14-2011, 06:56 PM   #2
CharlieFox
Oddometer: 195
Wicked
I have the 2-1 mid pipe with the Remus titanium can on my 2008 990A. It is louder than stock but not too bad.
There might be marginal improvement in the mid range, the big benefit is the weight savings and the reduction in temp of the can(s). Plus it frees up space for the adv tank. It is plug and play no programming required.
Do it!
CharlieFox screwed with this post 03-14-2011 at 07:01 PM
CharlieFox is offline   Reply With Quote
Old 03-14-2011, 07:21 PM   #3
Jay Robson
Oddometer: 34
This is going to be my very next mod exactly.
Jay Robson is offline   Reply With Quote
Old 03-14-2011, 08:35 PM   #4
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,197
Don't know the exact weight figure, but it is noticeable while riding, as is the torque bump at the low end. I also don't know about forest roads, but my Remus is indeed loud enough to annoy people in trailhead parking lots, which in turn annoys me.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 03-14-2011, 10:29 PM   #5
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,968
We've found that no jetting was needed when adding just a 2-1 to 950s, I can't see why it would make a huge difference for the 990's.
Loss of heat and Weight is a great thing. Be sure to use a High quality silencer w/ a 2-1 as you are running more heat and pressure through it. I've had a couple ALUM silencers fail on me, before I new more about the Remus silencers, but my TI Remus is still going strong after many miles. I have about 50,000 on our 2-1 system and about 30,000 on my TI Remus.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is online now   Reply With Quote
Old 03-21-2011, 11:31 PM   #6
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,406
How to install 2 into 1....
Dropped off my CJRacer 2 into 1 at the shop while they were doing a valve service and carb rebuild.... they said later over the phone they think the rear shock needs to be removed to get the two into two off? Any one know what truly gives on this?
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 03-21-2011, 11:49 PM   #7
randel
randel's Avatar
Oddometer: 315
I removed rear wheel mudguard to get my 2-into-2 off. Removing rear shock was definitely not necessary.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is online now   Reply With Quote
Old 03-21-2011, 11:52 PM   #8
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Not true. Worst case, they might have to remove the lower subframe bolts and swing the subframe upwards to make (more) room for the removal of stock H-pipe and fitting the 2-into-1.
If they are convinced that they need to remove the rear shock to fit a 2-into-1, take your bike elsewhere OR better yet, DO IT YOURSELF. You will learn more about YOUR bike.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 03-22-2011, 02:33 PM   #9
scottmctag
Well travelled
scottmctag's Avatar
Oddometer: 156
I just did my one using this method
Originally Posted by vicks View Post
not true. Worst case, they might have to remove the lower subframe bolts and swing the subframe upwards to make (more) room for the removal of stock h-pipe and fitting the 2-into-1.
If they are convinced that they need to remove the rear shock to fit a 2-into-1, take your bike elsewhere or better yet, do it yourself. You will learn more about your bike.
+1 I just removed my own using this method
Orange Ones are more Juicy
KTM was founded in 1934 by Hans Trunkenpolz and was initially known as Kraftfahrzeuge Trunkenpolz. later, in 1953, an Austrian businessman named Ernst Kronreif bought a large share of the company which was the renamed to Kronreif & Trunkenpolz Mattighofen (KTM).
scottmctag is offline   Reply With Quote
Old 03-22-2011, 02:52 PM   #10
Qwik
Adrenaline Addict
Oddometer: 6,712
Ditto
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 03-22-2011, 03:31 PM   #11
XX4me
Oddometer: 42
What are some other good options for cans?
I don't mind a little bit louder but don't want a drone at freeway speeds.
Staintune?
Supertrapp?
2010 KTM 990
2002 Honda CBR1100XX Turbo
XX4me is offline   Reply With Quote
Old 03-22-2011, 04:09 PM   #12
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,228
If you are riding the forest, don't forget your USDA approved spark arrestor.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 03-23-2011, 03:24 AM   #13
Kenbike
Oddometer: 692
I fitted a 2 into 1 from HT Racing. The kit included a FMF slip on that was made for a Yamaha R6. It fit perfect and it is louder than stock but I feel ok riding with out ear plugs. It does come with a spark arrestor that I have not installed yet.
Kenbike is offline   Reply With Quote
Old 03-23-2011, 10:33 AM   #14
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
I'm running the FMF Q can on mine. Sold off my no longer used left can. It sounds about the same as my 525 does with a little more R's. I noticed no real jetting diffs. I happen to have the flex mixture screws and have adjusted them some for other tweaks. If anything, I feel like I gained more bottom & mid and gave up some on top. Since I mostly rid under 6000 rpm's no loss to me.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 03-23-2011, 11:38 AM   #15
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,470
Originally Posted by SFKLR View Post
What's the quietest aftermarket pipe you can put on if you have a 2-into-1 on a 950SE?
I think "FUEL" which is a UK brand are pretty quiet.
I would have thought that if you get any can with a removable baffle, you could probably make a larger baffle to reduce the sound some more? Worth experimenting for the cost of a bit of pipe, perhaps :)
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Times are GMT -7.   It's 03:34 PM.
