Old 04-17-2012, 01:26 PM   #136
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 418
Originally Posted by jnberr0 View Post
Good info!! Do you have a weight for the stock canisters? I think it's somewhere around 22 lbs.
I'll try to toss one of the stock cannisters and the 2 to 2 manifold on the scale when I get a chance. That way you guys can have the full picture.
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 04-17-2012, 02:46 PM   #137
chrish4ku
chrish4ku's Avatar
Oddometer: 533
Just completed the full 2:1 system with a single Remus Ti.
Has anyone remapped due to the single output or are you just using the same as prior? Not to make this a mapping thread, but wondering if the Akro map is still the most appropriate with a single can.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / 02' XR650R
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 04-17-2012, 09:04 PM   #138
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 418
I went ahead and weighed the oem exhaust:
07 990 Adventure oem can with mount
2 into 2 pipe (ignore the clamp, the scale was zeroed with it on there)
Old 04-18-2012, 08:51 AM   #139
jnberr0
10-Fiddy Pilot
jnberr0's Avatar
Oddometer: 378
Looks like a little over 23 lbs, no?
Thanks, Steve! Great to get some verified weights on these things. I plan on eventually doing the 2into1 exhaust thing and a lighter Shorai battery in my 990. That should shave (say that five times fast!) about 22 lbs in total. I've also lost about 15 lbs. myself, so the combination of the two should be a pretty big help in muscling the big girl around.
Not sure what other weight savings I can do to the bike that doesn't involve giving up something that I like about it.
jnberr0 is offline   Reply With Quote
Old 04-18-2012, 09:14 AM   #140
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 418
You'll never make it light enough to push it very far, so make sure to add the advtank to the left side to gain 2.2 gallons of fuel capacity.
Old 04-23-2012, 08:24 AM   #141
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,546
Originally Posted by steve lavigne View Post
you'll never make it light enough to push it very far, so make sure to add the advtank to the left side to gain 2.2 gallons of fuel capacity.
+1
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 04-23-2012, 11:14 AM   #142
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
Same setup, same old map & it seems to work just fine.
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 04-23-2012, 11:18 AM   #143
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,546
I'm not suing the Akro map just the standard map and I have the same setup on a 2010 990. I'd think the Akro map, which puts too much fuel into the system for dual exhaust would put way too much fuel in with the single exhaust.
Moto-Treks
Old 04-23-2012, 05:24 PM   #144
chrish4ku
chrish4ku's Avatar
Oddometer: 533
Map Changed:
I changed back to the stock map - no O2 and the bike runs fine. A little popping on decel, but so far so good otherwise. Gotta love it when you can flash your own maps in less than 5 minutes. Oh, and the bike isn't twice less noisy....ha. Still has a pretty loud growl coming through that one Remus can. Good for lane splitting in the morning while in the webster tube (Alameda - Oakland). Very Narrow!!
Chris
Chris' Sat Tracker
Old 04-27-2012, 12:03 AM   #145
duroturk
duroturk's Avatar
Oddometer: 211
Send a message via Skype™ to duroturk
Map Changed:
So if I understand correct, going into 2in1 from the stock doesn't need any mapping right? If so, I'll be happy as I am far from dealers.
And one more question: Is there something specific when selecting cans? I mean, I have an Akrapovic Ti can for a F800GS and wondering if it is ok if I fit it on my '06 990 Adv as a single can?
Thanks in advance for the replies.
Nurettin
duroturk is offline   Reply With Quote
Old 05-02-2012, 06:33 AM   #146
duroturk
duroturk's Avatar
Oddometer: 211
No response?
Nurettin
Old 05-02-2012, 06:58 AM   #147
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,546
Not on a 2010 990
I didn't remap my 2010 990. The shop I bought the setup from told me it wasn't necessary. I've not had any problems with the FI after going to the single exhaust.
Moto-Treks
Old 05-02-2012, 07:03 AM   #148
ian408
More wag; less bark
ian408's Avatar
Oddometer: 11,800
No response?
It would be better to ask an Akrapovic dealer that question.
ian408 is offline   Reply With Quote
Old 05-02-2012, 08:10 AM   #149
tahoeacr
tahoeacr's Avatar
Oddometer: 2,169
With the standard 2-1 your forcing two cylinders to breath through one exhaust can. If the inside diameter is roughly the same as one of the originals/aftermarket cans in general your bike will be a little richer. Nothing specific except mounting. If the Akra can off your F800 can be mounted up run it. I suspect you will need some type of custom mount and bracket made up.
tahoeacr is offline   Reply With Quote
Old 05-02-2012, 11:29 PM   #150
duroturk
duroturk's Avatar
Oddometer: 211
Thank you guys!
Yes, mounting is not a problem, I can do that. I was searching and thingking about this for a while and the mapping was my only concern.
Thank you all once again.
Nurettin
Times are GMT -7.   It's 06:27 PM.
