06-04-2012, 10:57 PM
#166 |
Oddometer: 2,148
But less humidity.
However...yet another dyno which says nothing since there is no AFR curve. |
06-05-2012, 01:45 AM
#167 |
06-05-2012, 04:13 AM
#168 |
Oddometer: 2,148
My friend, I believe that the reason why you took the effort to go to a dyno twice and post the results here is to compare your setups, 2-2 vs 2-1. All I said is that there is no conclusion to be had without an AFR curve if one wants to compare two exhaust setups. If you interpreted this as 'bitching', I hold no responsibility. Take care now.
06-05-2012, 10:57 AM
#169 |
Oddometer: 215
Dyno Curves
Since horsepower is a function of torque x rpm, torque and horsepower dyno curves intersect at 5252 rpm, at least here in the US. The graphs posted by Korruptio show the intersection around 7100 rpm. Is this due to the use of metric numbers or is there some other explanation? I'd like to learn something today.
4 metal plates, 28 screws, titanium shoulder & surprisingly little talent. |
06-06-2012, 03:25 PM
#170 |
Oddometer: 2,170
0-2 sensor only works in closed loop. And really, not that well even then. The A/F ratio needs to be pretty close for it to compensate enough. Most seem to be below 12-15%TPS and under 4K on stock maps.
06-16-2012, 10:08 PM
#171 |
Oddometer: 159
Remus Ti 2 into 1
After reading the entire thread, it seems some remap, some don't. I have an 09 990 with 2 into 1 remus Ti. I have run the original map, the Akro, and a 2011 stock map, there is very little difference. The reason I was trying the different maps is I get a lot of popping on deceleration, with each. Is that the normal with this set-up? thanks
06-17-2012, 03:43 PM
#172 | |
Back Home
Oddometer: 1,545
06-17-2012, 09:17 PM
#173 |
Oddometer: 159
thanks
thanks moto-treks, my roxx 2 into 1 pipe has no provision for clamping or gaskets of any kind, maybe I need to try and seal those joints better to see if that is the cause. thanks for the tip, it would be nice if that cures the prob.
06-19-2012, 12:41 AM
#174 |
nine dot com
Oddometer: 1,094
anyone with the 2 into 1 and the FMF Q4 Titanium able to record a video & post it here? (similar to the one earlier in this thread with the remus) trying to decide between the two, and i'm not sold on the more expensive 2 into 1 roxx.
thanks!
bike: 07 990S Dakar | journal: kaianine.com | photos: SmugMug | SmugMug save $5: PeYEyWo3aVaYk |
06-19-2012, 07:28 AM
#175 | |
getting there
Oddometer: 381
Emoticons are like puke on the page. |
06-19-2012, 07:50 AM
#176 | |
was Steve Lavigne
Oddometer: 418
http://www.motorcycle-superstore.com...t-Sealant.aspx Makes installation quite easy and seals without issue.
'07 KTM 990 Adventure Long Road to Dug Bar |
06-19-2012, 09:48 PM
#177 | |
Oddometer: 17
06-19-2012, 10:29 PM
#178 | |
Oddometer: 159
installation complete, will report results Wed. thanks all! |
06-20-2012, 05:50 AM
#179 |
More wag; less bark
Oddometer: 11,801
I have the standard aluminum Q4. Don't think the material affects the sound that much.
06-20-2012, 07:58 AM
#180 |
was Steve Lavigne
Oddometer: 418
Not the material that makes the difference. The collector on the 2 into 1 on the Roxx merges to a much larger smoother diameter. Look earlier in this thread. I posted photos and measurements. I have had a FMF Q4 with the adv 2 into 1 and also the Roxx. Big difference between the two.
