Old 11-05-2011, 12:29 PM   #196
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
Dual Sport Trailers
C2, what a coincidence! I just ran across the Dual Sport Trailer thread this past week and was immediately drawn to the Moto-Mule. I saw the video of one of the other trailers doing some fairly serious dual sporting and was very impressed. I think a trailer like the Moto-Mule would be awesome for hauling camping gear to the campsite, unhook, set up camp and do day rides. It could be good for road trips too and it appears that the bike would handle better without having all the weight on the bike as you said. I'm looking forward to seeing/hearing some trip reports with the Moto-Mule. It looks like an excellent design.
Aleeoop70
Aleeoop70 is offline   Reply With Quote
Old 11-05-2011, 01:10 PM   #197
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
Pelican IM2620 Top Case
Top View of case. Yes you can get a helmet inside in a pinch (and that's exactly what happens). You have to lay it on its side and close the lid on it and the lid makes contact and flexes a bit, but it will close and latch.
Aleeoop70
Old 11-05-2011, 01:12 PM   #198
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
Pelican IM2620 Case
Another view of the case.
Aleeoop70
Old 11-05-2011, 01:22 PM   #199
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
Pelican IM2620 Case
Bottom view. This is a rolling case with the telescoping wheel frame removed. I used Happy Trail's pannier mounting system which clamps nicely onto the rear rack frame. They make mounts that attach to 5/8" and 3/4" tube. Be sure you get the kit for the proper tubing size. I made the 90 degree tabs and attached them to the bottom of the case with pop rivets so the case wouldn't slide around on the rack. All that stuff on the bottom of the case is well protected enough or robust enough that you can remove the case from the bike and use it for a camp stool. The duct tape was backing for a couple of holes I plugged with epoxy putty and the tape was later removed. The Moab mud is for authentic Adventure Rider effect.
Aleeoop70
Aleeoop70 screwed with this post 11-05-2011 at 01:28 PM Reason: to add info.
Old 11-05-2011, 01:27 PM   #200
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
Originally Posted by Aleeoop70 View Post
Bottom view. I used Happy Trail's pannier mounting system which clamps nicely onto the rear rack frame. They make mounts that attach to 5/8" and 3/4" tube. Be sure you get the kit for the proper tubing size. I made the 90 degree tabs and attached them to the bottom of the case with pop rivets so the case wouldn't slide around on the rack. All that stuff on the bottom of the case is well protected enough or robust enough that you can remove the case from the bike and use it for a camp stool. The duct tape was backing for a couple of holes I plugged with epoxy putty and the tape was later removed. The Moab mud is for authentic Adventure Rider effect.
The best ride I've ever been on is usually the last one and the next one.
Aleeoop70
Old 11-05-2011, 09:50 PM   #201
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,432
Question LED's ??
Hey Aleeoop ...
Like others have already mentioned - Nicely Set-up DR !
Curious to how bright the LED's are ?? In both the tail and brake light modes ??
Thanks ...
I got rear ended by a little old lady while sitting at a stop sign which resulted in a broken arm. Since then, I have installed flashing stop lights and stop/tail lights on my Pelican cases. I also wear a neon yellow jacket on the street.
Honda
GsVs is offline   Reply With Quote
Old 11-06-2011, 09:42 AM   #202
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
The LED tail lights and brake lights are very bright. One comment I received was "that thing is lit up like a semi".
Aleeoop70
Old 11-06-2011, 09:51 PM   #203
planemanx15 OP
planemanx15's Avatar
Oddometer: 1,007
Finished my switch holder today, and new cockpit layout. Switch holder bracket is made from 1" Angle Aluminum. Both the bracket and 12v outlet are bolted to the headlight shroud. I think I will buy the screw cap covers, to hide the bolt heads.
The one switch controls my headlight low beam. Eventually, I will install heated grips, and aux lighting, and those switches will also find there home on the bracket.
Sorry about the crappy cell phone pic, thought these Iphones are supposed to have good cameras
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 11-07-2011, 08:04 AM   #204
Aleeoop70
EX-MX Adv Tourist
Aleeoop70's Avatar
Oddometer: 95
Control surface
Looks good so far.
Aleeoop70
Old 11-07-2011, 11:28 AM   #205
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
They still need good light to work.
DR650 Wiki
NordieBoy is online now   Reply With Quote
Old 11-07-2011, 01:27 PM   #206
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Originally Posted by c2c4c View Post
I'm ordering a 20" CR in Dark Gray this week, ironically. Mark told me if 20" isn't enough for me he will swap it out without question, so that's reassuring.
Nearly $300 is a lot for me to spend on a windscreen but I think it will completely change the way the bike feels to ride, especially since i'm commuting on it year round!
As you mentioned, this seems to be well suited for the DR, just as extremely versatile.
I'll report back with pics and experience.
Ordered it Monday last week directly from Mark, who told me everything was in stock and it could go out immediately. Still hasn't shipped. Not thrilled with the service but very anxious to get the product. Hopefully it will ship out this week...
Current Steeds: '08 FJR1300 | '02 DR650
Former Steeds: '99 DR650 | '02 DR650 | '09 DL650 | '07 B1250
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
First Trip on 2 Wheels. 10,000 miles. 21 years old.
NC to Maine for Lobster Dinner
EvanADV is offline   Reply With Quote
Old 11-07-2011, 01:53 PM   #207
Nikolya
Rider
Nikolya's Avatar
Oddometer: 95
It's my cross-country setup
2010 Moto Guzzi Stelvio
2013 Suzuki V-Strom 650
IBA# 45281
Nikolya is offline   Reply With Quote
Old 11-09-2011, 10:42 AM   #208
GypsyWriter
Sarah
GypsyWriter's Avatar
Oddometer: 1,483
For those of you who use the Pelican cases, where do you get the racks for them? Does Pelican make their own or should I GL through another company like SW Motech?
2012 R1200GS Rallye - Gypsy
2003 R1150GSA with DMC sidecar
Ask A Self-Publisher
Originally Posted by FotoTEX View Post
Life is dangerous. Not doing what you love makes life even more dangerous...
GypsyWriter is offline   Reply With Quote
Old 11-09-2011, 11:26 AM   #209
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,589
moto-sport paniers used to make racks. fatchance's bike has those w. 1520 pelicans. twisted throttle has motech racks that will work. turbo city makes racks and also moose rebrands them & includes pelicans as a kit. that setup also includes a rear rack. the new wolfman v2 side racks now have 4 mount points the ability to use pelicans.
i'd say the turbocity/moose OR wolfman setup would be my 2 choices.
i like how the pelican 1520 fits on the DR but the bigger 1550 will also work.
carribou cases has pelicans with intergrated locks or use pad locks.
carribou use to offer a dr rack but no longer.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 11-09-2011, 12:24 PM   #210
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
I think Happy Trails will work too.
Times are GMT -7.   It's 02:09 AM.
