Old 11-01-2011, 08:11 PM   #181
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,251
Wicked Yamaha TT 600 in Chev ADD?
Watching the tube over the weekend, and theres a add for a new chev truck. Person is ask "what do you do with your Chev?? Shows all sort of things, one is towing a bike trailer. Looks like a TT600 on the trailer. Not sure, but its a yamaha for sure. Do you see it?? ED
BIG ED XT FAN is offline   Reply With Quote
Old 11-01-2011, 09:08 PM   #182
Kelly_O
Oddometer: 321
Yup, that's a TT600 for sure.
Kelly_O is offline   Reply With Quote
Old 11-04-2011, 08:56 AM   #183
stteve
Oddometer: 371
Originally Posted by nikroc View Post
Hi,I've just joined the forum after lots of internet searching for info on the ttr 600e.
She's a 2003 model with just over 6 k on the clock. Been stood for 3 years before I bought her but after much fettling (iridium plug,oil and filter service,air cleaner cleaned and re oiled and new battery) shes running fine.
Does anyone know if the oil filter is the same between the ttr and xt etc?..also wana change the front sprocket and again querying if xt sprockets fit?..I can get the filters and sprockets at silly prices for the xt but double the price for the ttr..
TTR has an XT600 engine, so a lot of parts will fit. Check KEDO in germany for all the parts you need
Now-1977 YAMAHA XT500 - 1996 HONDA XR400R - 1991 YAMAHA XTZ660
Sold-1983 XT250/1991 TT350/1996 TT600E/1985 XT350/1999 TT600R/2002 TT600R
stteve is offline   Reply With Quote
Old 11-08-2011, 09:28 AM   #184
kyle
kyle's Avatar
Oddometer: 82
does anyone know what weight oil and what level i need for the kayaba forks on a 93 belgarda? have to change the seals and i'm having a tough time findin info...thanks big ed for reply ref exhaust
kyle is offline   Reply With Quote
Old 11-09-2011, 12:36 AM   #185
nikroc
Oddometer: 26
kedo
Appreciate the heads up stteve,turns out that the uk franchise of kedo is based about 3 miles from me..result!!
nikroc is offline   Reply With Quote
Old 11-18-2011, 03:21 PM   #186
Kelly_O
Oddometer: 321
Kick Starter
I know I saw a post in here somewhere about putting an XT kick starter on a TT. I can't find it. Is the XT kicker more durable than the TT? My TT kicker is starting to bend a little and I'm considering my options. Anyone? Thanks, Kelly.
Old 11-18-2011, 11:23 PM   #187
Fantuzzi
Fantuzzi's Avatar
Oddometer: 184
The kicker of a late generation European TTS or TTR from the bay should work:
Belgarda Yamaha TTR600
Yamaha XT660Z Tenere
Fantuzzi is offline   Reply With Quote
Old 11-20-2011, 01:01 PM   #188
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,663
Cool2
I had to look for this ad ED. Havent' seen it on tv yet but it's on Youtube. It's called "The Question."
"The Question" | 2012 Chevy Silverado | Chevrolet http://www.youtube.com/chevrolet?x=us_showcase_1539
An ad for the 2012 Silverado.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-20-2011, 08:12 PM   #189
BIG ED XT FAN
Oddometer: 1,251
Well, Thanks!! Thats a TT600 and a DR 350 !! Thanks Chev!! And you to D. T.!!
Old 11-21-2011, 01:26 AM   #190
Francesco2
Oddometer: 17
pic from my disassembled tt
I torn appart my tt last weekend to fix the rattle in the engine caused by a bad airfilter which caused a worn piston+cylinder.
Engine amputation:
Cylinder :(
My next step is refurbishing a spare xt cylinder and placing it with new gaskets and a new piston. If the bike is than technicly o.k. I'll start with an optical facelift.
Francesco2 is offline   Reply With Quote
Old 11-21-2011, 04:08 AM   #191
brucifer
brucifer's Avatar
Oddometer: 2,532
Isn't the bike on the far left a TT600 as well?
Engine amputation:
Cylinder :(
That's exactly how my cylinder looked when I tore my top end down.
Had another cylinder with an iron liner and went with a 621cc JE piston.
I don't like the air filter design on these bikes. They don't like to seal well it seems.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 11-21-2011, 11:30 AM   #192
Francesco2
Oddometer: 17
How does it run with the extra 26cc? did you also replace the engine bearings and did you do a rework of the head? I'm considering to do so.
Regarding the arfilter, is seems like it's combining a housing and the foamfilter from two different bikes, the two don't match it seems:
I allready asked within another offroad forum if this is normal, because I think this will cause my next cylinder/piston to wear extremely fast too.
Improvement options anyone?
Old 11-21-2011, 06:53 PM   #193
brucifer
brucifer's Avatar
Oddometer: 2,532
I haven't really gotten a chance to pour the coals to it yet.
I reused a base gasket because I tore the new one I had and being impatient I just HAD to get the thing running that day. It leaks.
Also as I was checking the cam timing, I noticed some play in the main bearings. So, I'm going to pull it back down and fix my screw ups.
Besides the 11.5:1 621cc piston, it has a ported head, Web motocross grind cam, K&N filter and a Cobra muffler.
Plus I just got back my old Kei Hin 31mm CR Special carbs.
I had these carbs on a similar '84 TT600 back in about '94-'95 and that bike was a rocket.
It had a 11.5:1 standard bore piston, ported head, I believe the same grind Web Cam camshaft, K&N filter and Supertrapp muffler.
These engines respond quite well to hot rodding mods.
Old 11-21-2011, 07:54 PM   #194
BIG ED XT FAN
Oddometer: 1,251
Cool2 TT600s on the Tube!!
Wow Theres 3 bikes on the trailer.!! Have to clean my glasses. Yes thats a 2nd TT600!! ED
Old 12-06-2011, 08:00 AM   #195
RMRAIDER
Guest
Oddometer: n/a
TT600S 1996 Belgrada - specifications
Gentelmens,
Need your help,
I about to buy TT600S 1996 Belgrada and noticed that the dry weight of this lady is about 350 pounds (160kg).
Does any one have specification of this bike (couldn't find one) and is it really that heavy?
Any help will be appreciated.
Attached is the photo.
Thx
Roman
Times are GMT -7.   It's 12:53 PM.
