Old 04-03-2013, 07:50 AM   #436
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,255
Originally Posted by karlsons View Post
1995.
Are you going to run a stock airbox?
BIG ED XT FAN is offline   Reply With Quote
Old 04-03-2013, 07:59 AM   #437
karlsons
Oddometer: 18
at the moment looks that it will work with some modifications.
karlsons is offline   Reply With Quote
Old 04-03-2013, 08:32 PM   #438
BIG ED XT FAN
Oddometer: 1,255
What carb is that on your bike?
Old 04-03-2013, 10:13 PM   #439
karlsons
Oddometer: 18
This is Keihin CR SPECIAL, 35 mm, modded by http://www.flowpro.org/
Old 04-15-2013, 01:01 PM   #440
karlsons
Oddometer: 18
some news
http://www.youtube.com/watch?v=3SwYy868mv4
Old 04-15-2013, 01:51 PM   #441
BIG ED XT FAN
Oddometer: 1,255
Looks and sounds good!!!!
Old 04-15-2013, 01:56 PM   #442
karlsons
Oddometer: 18
yeah and eats fuel with speed of light
but hope next week will receive missing joint and then will have a hard test drive ::
Old 04-15-2013, 07:59 PM   #443
BIG ED XT FAN
Oddometer: 1,255
Thumb Gas mileage?
Thats what happens with a bigger carb!!
Old 04-15-2013, 09:16 PM   #444
De250r
De250r's Avatar
Oddometer: 74
Originally Posted by Lc8er View Post
I had the exact same bike until it was sadly stolen last year, the red white and black beast, great bike. I had a very similar problem with no spark and asked at a Yamaha garage, spoke to one of the mechanics thinking it was the cdi as well. He said I had gotten something in the fuel and fouled the plug, I realized it might have been from a jerry can on a camping trip...
Drain the carb, fit new plug and boom, started first kick and really surprised me. I ran a few tanks of carby / engine cleaner and then fitted a fuel filter, I highly recommend one. Any trouble starting then adjust the auto decomp, hold the lever just off max and adjust the cable, it slowly stretches and gets harder to start.
Another great tip I learned from at a guy at a garage when I flooded the engine which I sometimes did was- fuel tap off, lower the bike on it's side to drain the carb, with the ignition OFF and the throttle wide open give the bike one light kick over to clear the cylinder then start as normal. Always remember to NEVER EVER touch the throttle when starting or it could kick back and hurt you allot. And never start with the fuel tap on, turn it on when it starts, I used to regularly adjust the idle for cold mornings.
Hope this helps, good luck!
That's why mine used to kick back on me. The reason I got rid of that beast. At 145lbs didn't have enough arse to kick it after it broke in after a rebuild.
Sent from the back woods of vt via patchy Internet
Live free and ride hard
De250r is offline   Reply With Quote
Old 04-16-2013, 10:36 PM   #445
AfricaWim
AfricaWim's Avatar
Oddometer: 330
My '83. Sadly sold now.
This was my 3rd TT600....you can say I have a "thing" for these thumpers...
What good am I, if I know and don’t do, If I see and don’t say - Bob Dylan
AfricaWim is offline   Reply With Quote
Old 04-17-2013, 06:50 PM   #446
BIG ED XT FAN
Oddometer: 1,255
Wink TT600 Power!!
I had 3 TT600s it one time. Now i am down to 2 TT600s. One has no motor, and the second has a xt 550 motor in it.This is a 85-86 model?
Old 05-24-2013, 05:11 PM   #447
amf4399
amf4399's Avatar
Oddometer: 63
Very nice. I just started striping down my 85 TT600. How hard was it to add the lights or make it an Xt? Any threads on that? Thanks
amf4399 is offline   Reply With Quote
Old 05-26-2013, 08:33 PM   #448
BIG ED XT FAN
Oddometer: 1,255
TT 600 to XT 600?
You can get a electic parts from a XT 600. It will most be "bolt-on" deal. You need to mount a battery box.
i have seen them mounted right by the oil tank. Or right above the air box. You have to mount a key switch too! Hope this is a help!
BIG ED XT&TT& SRX 600 FAN!!!!
Old 05-27-2013, 05:15 AM   #449
thumpthumpthump
Thumpthumpthump
Oddometer: 214
You could put an xt oil tank on it on the back and mount and xt battery box. You will have to make mounting tabs either way. However I would just put a battery eliminator under the seat after you put the electric parts to run your light and save the weight of a battery. Some question the ability to run blinkers , but if you use led turn signals and adjust the idle up a little it should be fine. I do not run blinkers and have no problem. The eliminator is about the size of a d battery. Accell makes them. Its just a capacitor. Let there be light. thumpthump.
thumpthumpthump is offline   Reply With Quote
Old 05-27-2013, 01:33 PM   #450
amf4399
amf4399's Avatar
Oddometer: 63
Times are GMT -7.   It's 09:07 AM.
