Old 05-27-2011, 11:47 PM   #76
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,774
Originally Posted by BIG ED XT FAN View Post
I say yes. The TT 600 gas tank has a big backbone. You just have to fit the front mounts. Also, the early XR 500 plastic tanks fit a TT 350 too. Come in red too!!ED
The '81-82 XR tank, or the RFVC?
NordieBoy is offline   Reply With Quote
Old 05-28-2011, 05:40 PM   #77
Kelly_O
Oddometer: 301
Kelly, I no longer do paypal. send me a M/O Post office has them. For $25.00. O.K.? Ed
1 Postal M/O headed to the Finger Lakes region. Thank You Ed. BTW, do you fish? I've always wanted to fly fish for smallies in your neck o' the woods. Kelly.
Kelly_O is offline   Reply With Quote
Old 05-28-2011, 06:40 PM   #78
biggurn
Yes, it is BIG.
biggurn's Avatar
Oddometer: 94
It's amazing to see that you guys still run these! I had one back in highschool, it was fun until the CDI went out, pulled the engine and chopped up the frame, still have the engine (12 years later) wish now I had kept it after seeing everything still do with them!
The Kawasaki KLR 650, sure it will do that! Hell, it'll do anything ... just not necessarily well.
biggurn is offline   Reply With Quote
Old 06-05-2011, 01:56 PM   #79
Kelly_O
Oddometer: 301
Put a few miles on....
...my 84 TT600 yesterday. I have a few questions for you experienced TT riders. The float on my main carb seems to be sticking. Fuel out the overflow. Tapping on float bowl helps. Best place to buy carb parts? The bike will not rev properly in 3rd gear or higher. It'll rev hard in 1st and 2nd. More carb trouble? Whatcha think? Thanks, Kelly.
Old 06-07-2011, 04:36 PM   #80
Kelly_O
Oddometer: 301
Hey Big Ed, I got the air filter parts today. Thank You SO much!!! Exactly what I needed, Kelly.
Old 06-07-2011, 05:59 PM   #81
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,126
Make sure everything is clean and inspect the needle. I have had this happen to me and a good cleaning solved the problem.
Mike
When in doubt, give it Gas!
Center Stands, XR650L/XR600, NX650, TE/SM610, TE630, XR400, XR250 and XT225.
http://www.advrider.com/forums/showthread.php?t=537336
http://www.cigarmikes.com/
Cigar Mike is offline   Reply With Quote
Old 06-07-2011, 07:40 PM   #82
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,039
TT600 Motor will be happy now!!
Thanks, ED
BIG ED XT FAN is offline   Reply With Quote
Old 06-07-2011, 07:43 PM   #83
BIG ED XT FAN
Oddometer: 1,039
TT 600 Roller?
Hi, Need a roller for that motor? Have a roller, just need a new cdi box , carb, and exhaust. ED
Old 06-08-2011, 07:12 PM   #84
dnnyrckts
Oddometer: 8
Try Dillon Bros http://www.powersportspro.com/pages/...(TT600L_-_1984)
In the process of rebuilding the carb on my '83. Just got the parts this week from these guys. Make sure you tear into the carb first to make sure what you need, otherwise you'll end up placing multiple orders and incurring more shipping charges.
dnnyrckts is offline   Reply With Quote
Old 06-08-2011, 08:53 PM   #85
Kelly_O
Oddometer: 301
Thanks, I've also bought a few parts from PowersportsPlus.Com. Low prices and cheap shipping on the parts I got, Kelly.
Old 06-10-2011, 10:35 PM   #86
Simosez
Simosez's Avatar
Oddometer: 253
hi all, sorry not a TT owner but i did have a TT250 years ago.
anyway a question for TTR belgarda owners with the ohlins shock. what is the eye to eye length of the shock?
cheers in advance.
fear causes hesitation and hesitation will cause all your worst fears to come true.
DR750 BIG
KTM 450 EXC
Simosez is offline   Reply With Quote
Old 06-11-2011, 12:46 AM   #87
ilsardo
ilsardo's Avatar
Oddometer: 4
cheers in advance.
398 mm
http://www.ohlins.com/Our-products/M...-sport/YA-626/
click on mounting instructions under documents
ilsardo is offline   Reply With Quote
Old 06-11-2011, 11:33 AM   #88
dvgonzo
dvgonzo's Avatar
Oddometer: 331
Kelly_O,
Look at the little tip on your needle and seat. Sometimes if stored with gas in them they will build up some deposits on there and it will almost but not quite close off the fuel flow due to it.
It is barely visible and you can usually just scrape it off all the way around with a fingernail to get the seat to seat!
Even had this happen to a lot newer dirt scoot recently!
dvgonzo is offline   Reply With Quote
Old 06-11-2011, 06:28 PM   #89
Kelly_O
Oddometer: 301
Originally Posted by dvgonzo View Post
Kelly_O,
Thanks, I'll give that a go while I try to figure out my newest carb problem. Went for a short ride today and now I have bigger problems. I came upon a slight uphill. I twisted the grip and the bike bogged badly and slowed. I downshifted and twisted again. It bogged again. It acted like it was starving for fuel so I reached down and pulled out the choke. It helped a lot! I was 5 miles or so from the house, so I turned around and pointed us for home. I noticed a few things on the ride home.
CLUES!!
The bike idled OK with the choke ON. The bike pulled OK with the choke ON. Midrange it stumbled HARD and would then take off like it should. Without the choke it wouldn't accelerate at all, but would idle. This is the first thumper I've ever had so I don't know much about them. It seemed to me that it acted like a really bad vacuum leak. I looked at the intake tract and it looks fine. I'll get some carb cleaner and hunt for a leak. Am I headed in the right direction? Can I access the needle and seat by removing the float bowl? Thanks for the help, Kelly.
Old 06-12-2011, 05:37 AM   #90
dvgonzo
dvgonzo's Avatar
Oddometer: 331
Those sound like classic plugged idle jet symptoms to me, which also come from having the bike sit with gas in the carb. I had this problem twice on different dirt scoots in the past year and I am GOOD at draining the gas out of the bowls when I park them. Problem (IMO) is this crap gas they are force feeding us.
On my KLR I had it start to miss and chug in just 5 weeks of sitting the winter before last, and the gas was treated with Stabil AND Seafoam!
Yes, you can remove the float bowl to access it. It helps to loosen the two hose clamps on each side of the carb's rubber boots and rotate the carb about 45 degrees, also put a squirt of wd40 on top of each boot and allow it to run down around the boot, it makes it lot easier to then rotate the carb). Also make sure you pull a little slack in the cables to allow it to turn.
Put a shop rag or towel accross the top of the cases just under the carb in case you drop anything (been there before!).
Remove the bowl, then you pull the little pin that slides through and holds the floats in. This will allow the float to drop out and the needle and seat come down with it, usually. Give a blast of carb cleaner or wd40 up into where the needle seats while you are there.
The idle jet is the small one that sits up into the well next to the main jet and it gets plugged real easy as gas evaporates up through it leaving behind a little plug of varnish. Most times you HAVE to push a real small wire throuh it to get it cleared out completely.
I use a small bread tie wire stripped of the plastic. I beleive it is like .016 or .013 hole so real small diameter. You can also use a real small # drill but push the shank end through it to prevent scratching the jet.
Re-assmble...RIDE!
Times are GMT -7.   It's 10:52 PM.
