Old 12-09-2011, 12:21 PM   #106
AZuwere
AZuwere's Avatar
Oddometer: 389
Originally Posted by grinder96 View Post
I got the jumper but it is in a bag. Don't even know where it goes How much improvement does it provide?
I believe it plugs in to the connector on the leads up above the O2 sensor coming out of the right side of your exhaust. Some people remove the O2 sensor and replace it with a bolt. I left mine attached, as it is out of the circuit anyway.
My dealer did this for me, so I never saw how it ran before the jumper. I understand they don't run all the good before the mod though.
2014 BMW R1200RT
'11 Husky TE449
2014 Polaris Ranger Crew XP
2009 Vespa GTS 250
AZuwere is offline   Reply With Quote
Old 12-09-2011, 12:31 PM   #107
grinder96
grinder96's Avatar
Oddometer: 1,413
I thought I read that puts it in race mode and voids the warranty? of coarse I read that on the internet so
Turin
11' Husky TE630, 06-Husky SM610, 02'Honda VFR800, 04'Honda xr80r
"Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves." - Albert Einstein
grinder96 is offline   Reply With Quote
Old 12-10-2011, 06:54 AM   #108
grinder96
grinder96's Avatar
Oddometer: 1,413
yes we know what they look like, but this one is mine!!!!
Turin
Old 12-10-2011, 07:09 AM   #109
datol
n00b and improved!
datol's Avatar
Oddometer: 93
Its all blurry
Your photographer sucks!
Congrates bro!
Dane
Buy it, use it, break it, fix it
We learn nothing from the things we do right the first time.
datol is offline   Reply With Quote
Old 12-10-2011, 09:55 AM   #110
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,741
Nope, it's immediately in front of the ECU tucked down under the seat,....in front of the battery when seat is off. By plugging in this jumper you effectively disable the O2 sensor and it would be recommended to remove the sensor and to install an aftermarket exhaust as having the jumper in place for Race Mode will clog the catalyst prematurely, not sure if that's 1000 miles or 5000 miles but none the less with stock exhaust in place you are not reaping all of the benefits of race mode.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 12-10-2011, 10:15 AM   #111
grinder96
grinder96's Avatar
Oddometer: 1,413
I dont mind the grainy picture...I just have to figure out how to get on it with no legs!!!!
Congrates bro!
Dane
Turin
Old 12-10-2011, 10:17 AM   #112
grinder96
grinder96's Avatar
Oddometer: 1,413
Thanks...I was wondering about the cat if you enriched the fuel...Thanks for the input!!
Turin
Old 12-10-2011, 02:22 PM   #113
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,647
Question for you. I have a TXC449 with the semi-stock Husky Akropovic exhaust. Can I use this mode with that can? It also comes with the stock can like the TE has
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 12-10-2011, 06:39 PM   #114
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,477
I freaking LOVEA the idea of using an alternate exhaust can for an aux fuel tank. That is genius.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 12-10-2011, 07:51 PM   #115
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,775
I was told, by a Husky dealer, that the PowerUp mods convert the 6 or 12 month TE warranty to the 30 day Competition warranty.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 12-10-2011, 10:06 PM   #116
Some Dude
Some Dude's Avatar
Oddometer: 4,741
Yes, the TXC Akra does not have a catalyst in it to my knowledge.
Old 12-10-2011, 11:02 PM   #117
grinder96
grinder96's Avatar
Oddometer: 1,413
My biased (biased cause i already paid for it!) review:
Took my new 2011 TE449 out to break in the engine some today. My local mountains are windy with lots of room to accelerate softly and use engine breaking to slow down. I rode from 2000 to an elevation of about 7000 feet. I did all asphalt today as my arm is healing and cannot take off-road abuse just yet. To me that’s fine as it gives me some time to get to feel how this TE will behave on the pavement and to break in the engine. I left my house with 11 miles on the odo and returned with 186, for those not quick at math that’s a total of 175 miles traveled today.
Engine (4.5 / 5)
The engine is bone stock and performed very well. I got 50 miles to the gallon and as stated in the manual the fuel light (albeit microscopic!) came on with about 1/2 gallon remaining. Coming off of a XR400R and then a DRz400s I could always snap the throttle and pick up the front wheel. The front wheel never felt like it wanted to lift with the TE. This may be due to the longer swing-arm on the TE but It just felt that the engine needed a little more umph. This may change when I put the "race mode" plug thing in, but I haven't yet and as tested, needs more punch. The engine is smooth and pulls from the bottom through mid range very consistently with very little vibration. A little more vibs the faster it spins, but its a single, what do you want, a 30 pound counter balance? I never wrang it out as I am still breaking in the engine (and not by the floggin method!)
Transmission: (4.5 / 5)
When I went for a few short runs to get to 11 miles before today's ride I noticed I could not get the trans in to neutral with the engine running. Engine off it would 1/2 click above 1st as expected but as today progressed and break in did its magic, neutral became easier to find. As a matter of fact the trans shifted better and better as the day went on. There were no false neutrals and the trans dropped right into any gear I poked at, almost forecasting my next move. I do have some concern about how close the transmission ratio is as I kept trying to shift one more time only to find I was already in 6th gear[IMG]file:///C:/Users/BLUEJA%7E1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/IMG]. This little TE will have a hard time on any So Cal freeway as it seemed to work harder then I wanted to push on a new engine to do 60-65. I will ride it in dirt before changing anything but will be paying close attention!
Chassis: (5/5)
Aawww what can I say… by the end of the day I was coming down the local mountain road called Sand Canyon and I think I could have taken on an army of sport bikes shodding their pilot powers or battle axes…it wouldn’t have mattered because I was in a groove and the bike was integrated into me!!! The TE has a firm feel with no unexpected or unwanted chassis shakes or shimmers!! The bike from the start instills confidence. As is dirt bike fashion, the seat is hard and starts to hurt depending on how fat your ass is. Mine is medium fat so it started hurting mid day. As some internet reviews mentioned the pipes will burn your riding pants, they did mine as well and left a couple of black smudges on my new pipe, so a P3 guard is high on the list.
Noteworthy:
Display: (3.5/5)
Can't see it because the brake/throttle/speedo cables block my view and the turn signal/high beam/low fuel lights are tiny and hidden by the front plastic as well. The small mode button is nearly impossible to press with gloves on.
Storage: (1/5)
No, none, nada…I was scared my registration wasn’t going to fit taped to the underside of the seat (it barely made it)! Then wondered where to put my proof of insurance….
Headlight: (3.5/5)
My ride home ended up being at night. The headlight gave good light and threw a descent pattern. There is room for improvement but since I do very little night dirt riding I see no reason for upgrading.
Tires:
The factory installed Metzeler karoo tires performed just fine, now remember this was asphalt only!! I will report when I get this to the dirt!!
Summary:
Regardless of the bias remark because of finances invested, I would purchase this bike again tomorrow. It is tight, smooth and predictable. It builds immediate confidence and can only get better as it gets tuned a bit, dialed in and completes its break in process!!!
Turin
Old 12-11-2011, 09:44 AM   #118
grinder96
grinder96's Avatar
Oddometer: 1,413
Oh yeah..the auto-up kickstand blows. There will be a redesign there
Turin
Old 12-11-2011, 10:14 AM   #119
pbreisch
Oddometer: 85
you can disable the auto up by cutting off a bit at the pivot. They did it at the dealership otherwise I could give you more details.
Can anyone tell me what the black rubber strap is that hangs down on the left rear is? Looks like some kind of kickstand retention loop but I can't get it to stretch that far without feeling like I am going to brake something.
pbreisch is offline   Reply With Quote
Old 12-11-2011, 04:18 PM   #120
AZuwere
AZuwere's Avatar
Oddometer: 389
Yep, it's for the kickstand.
2014 BMW R1200RT
'11 Husky TE449
2009 Vespa GTS 250
Times are GMT -7.   It's 02:23 AM.
