Old 03-21-2012, 07:27 PM   #91
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Good point Road Crown and distance traveled. All very logical reasons for left side tire wear. Thanks...
rotten is offline   Reply With Quote
Old 03-21-2012, 11:41 PM   #92
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,706
Originally Posted by PFFOG View Post
A whole can of worms of opinions here, but it is a FACT that left turns are LONGER than rights, ALWAYS. So you are leaning longer and going faster thus scrubbing off more rubber.
Other factors may contribute, but this one is indisputable.
Yeah, but when I see tires like this, I think "track day":
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas)
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 03-22-2012, 06:24 AM   #93
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,013
I would hope that the trackday organizers would boot you off the track long before your tire looked like that.
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 03-22-2012, 08:38 PM   #94
duck
duck's Avatar
Oddometer: 10,403
Beats the hell out of "freeway day."
It's a dual compound tire and that tire saw a lot of twisties. I'd rather wear out the sides than the middle.
duck is offline   Reply With Quote
Old 03-22-2012, 10:01 PM   #95
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,808
Mission accomplished.
Good luck wearing through the center of a PR2 that you keep up with the pressure on though. I think mine made it something like 10,000 miles commuting 90 miles a day straight up and a down on a divided four lane.
I chew the right side of my track bike tires faster than the right, that is because both tracks at NJMP are all right turns.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 03-23-2012, 08:26 AM   #96
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,706
I'm with you.
My point was simply that when I've seen tires worn heavily on one side, that tire had seen a trackday.
When I've seen tires worn like that, they've seen a trackday.
I don't really buy the "left turns are longer than right turns" theory of left-side tire wear.
IBA #24873
Old 03-23-2012, 03:59 PM   #97
dduelin
Oh boy that was close
Oddometer: 1,411
Ever take high school math?
Consider two turns of 90 degrees, one left and one right, on a road where we ride/drive on the RH side. A 90 degree left turn has a larger radius compared to the right turn.
A circle of larger radius has a greater distance around the circumference. 90 degrees is simply part of a circle, hence the distance to turn 90 degrees is longer.
The complication of crossing opposing traffic is what increases the radius. The RH turn keeps us in one lane to turn 90 degrees. The LH turn has to cross the width of the opposing lane to complete a 90 degree turn, making the distance traveled further for the LH turn.
Any turn is part of a circle so the distance is always longer if the radius is greater - no matter if the turn is a barely discernable kink or a 360 circle as long as the roadway is divided and you must stay in one lane or the other. One rider travels a shorter distance to make the turn compared to the other.
If this does not still become clear, consider runners at a track meet where the course is an oval - two straights connected by two 180 degree turns. The runner that draws the inside lane starts further back from the runner that drew the far outside lane. During the first turn runners have to stay in their lane in order for all lanes to have the same distance to run. The inside lane has a smaller radius so the runner starts further back to even the distance compared to the outside lane runner.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 03-24-2012, 12:49 PM   #98
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,706
I guess I should dig out the old pictures of my Dragon GTS front tire, worn bald on the RIGHT SIDE...
IBA #24873
Old 03-25-2012, 12:12 PM   #99
duck
duck's Avatar
Oddometer: 10,403
I'm with you.
Part of it is the bike too. It's not perfectly balanced. My previous K100RS4V burned up the left side first as well.
Old 03-27-2012, 06:57 AM   #100
Snapper
Snapper's Avatar
Oddometer: 2,500
The left sides of my tires always wear faster than the right - road crown and the fact that lefts have a greater radius, are two inherent reasons.... There are other "preference" reasons for me (and I think also for others, if subconsciously) that allow me to push left handlers much harder than right handers.
In right hand side drive countries, comparing the same corner taken as a left hander, and from the opposing direction as a right hander, the right hander:
- is always sharper
- is almost always blinder
- much more likely to have opposing traffic crossing the double yellow
- more likely to have sand/gravel in it
- more likely to result in death, if I should be so luckly as to go down and slide across opposing traffic
In short..... Don't FUCK with right handers.
Course, YMMV
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 03-27-2012, 08:00 PM   #101
PalePhase
Humour Noir
PalePhase's Avatar
Oddometer: 824
I tell all my southpaw acquaintances that!
“Fools learn from experience. I prefer to learn from the experience of others.”― Otto von Bismarck
1995 Honda VF750CD
2002 Honda VFR800
PalePhase is offline   Reply With Quote
Old 03-30-2012, 07:31 AM   #102
dashredder
Just go.
dashredder's Avatar
Oddometer: 68
Every time I stray from Michelins I wish I would have been faithful. Prob a personal preference, but every one I've used from the Pilot Powers on sport bikes to the PRs on the STs have been just awesome tires.
dashredder is offline   Reply With Quote
Old 03-30-2012, 01:47 PM   #103
deej
Deej (Deric)
deej's Avatar
Oddometer: 512
I just got a brand new set of Pilot Road II's installed, only have 50 miles on them so too soon to tell. But I have high hopes then last. :)
One out of four people in this country is mentally unbalanced.
Think of your three closest friends. If they seem normal
you're the one!
2005 ST 1300--2006 250S--2006 XT 225
deej is offline   Reply With Quote
Old 08-16-2012, 01:40 PM   #104
ediehl
Oddometer: 136
Sure wish there was a formal sport-touring tire review somewhere that had mileage as a primary focus. My Buell Ulysses is showing just over 12K on the odo, and it's well into its 4th set of tires (stockers, Pirelli Angels, PR2s and PR3s). I was figuring on getting 8, maybe 9K on the last set of PR2s, and was shocked to realize I'd worn it down to the cord after not much more than 3K! I ride briskly in the mountains a lot, but I'm not seriously fast and I don't slide tires or do wheelies or stoppies. Now I'm looking at the rear PR3 and wondering if it'd be OK for my planned 1K ride this weekend?
I'd read that the BT-023s were better than average for mileage, but I see contradicting stories here and there. There's a GT version of the 023s for heavier bikes, but I don't know if that would improve mileage. I get a lot better mileage out of the Avon Cobras on my thousand pound Goldwing---I'd spoon those on the Uly if they made them in the right sizes. Some folk report well over 10K on their sport-touring tires----I guess the asphalt must be 'softer' where they ride...
ediehl is offline   Reply With Quote
Old 08-16-2012, 01:50 PM   #105
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Just put a new PR3 on the front just have 800 miles so far and Zero complaint.
Times are GMT -7.   It's 01:09 AM.
