Go Back   ADVrider > Bikes > Hacks > Hack Vendors
Old 04-20-2011, 02:21 PM   #1
Sparrowhawkdesign OP
Sparrowhawkdesign's Avatar
Oddometer: 132
Thumb New wheel style
New wheel style available for the BMW 1200 GS.
DMC SIDECARS
General Manager, designer, installer, test rider, problem solver. Generally whatever needs doing.
37 YEARS PLAYING WITH SIDECARS
Myths and misinformation are more seductive than the truth.
Sparrowhawkdesign is offline   Reply With Quote
Old 04-21-2011, 04:03 AM   #2
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 5,972
yep...
that's the one we are getting...
very excited about it
love the look
so glad ou and jay found this one
so much nicer than the plain "disc".... IMHO, of course
thanks for the thread, barry
i appreciate it
Greg
'11 R1200 GS Adventure with a DMC M72DX Sidecar
'14 R1200 GS & '14 R nineT (march, 2014)
Live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW screwed with this post 04-21-2011 at 04:26 AM
ClearwaterBMW is offline   Reply With Quote
Old 04-21-2011, 04:57 AM   #3
ClearwaterBMW
The Examiner
Oddometer: 5,972
Barry -
1. what size is that tire, please?
2. are there options for "better" tires?
i know that few manufacturers make tires in that size (i suppose)
but... just wondering about "upgrading" the rubber, if that is something which is possible
thanks, as always, in advance
Greg
Old 04-21-2011, 05:56 AM   #4
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Is There Any Way . . .
While the new wheel is significantly BETTER, please don't stop the quest to find a WIRE WHEEL for the sidecar and REAR wheel. I've scoured the Internet for a wire wheel, and have come CLOSE, but no cigar!
2007 R1200GS Adv DMC Hack
2014 R1200WCGS
jpalamar is offline   Reply With Quote
Old 04-21-2011, 07:17 AM   #5
Oddometer: 132
I think the answer may be to look at having an appropriate rim laced to a stock hub if possible. Poor picture but this one is on an old 650 Yamaha. Barry
DMC SIDECARS
Old 04-27-2011, 05:57 PM   #6
Oddometer: 132
New wheel for 1200 GS
Here is a picture of the wheel mounted. Barry
DMC SIDECARS
Old 04-27-2011, 07:17 PM   #7
ClearwaterBMW
The Examiner
Oddometer: 5,972
ooooooooo La La
great picture
nice bike..
Greg
Old 04-28-2011, 10:42 AM   #8
BMWzenrider
The Road Scholar
BMWzenrider's Avatar
Oddometer: 1,130
Do you know the weight of that wheel?
Also, is the backside of the wheel machined and polished as well, or is it still in the as-cast finish?
(photo?)
Finally, is it clear-coated, or will it require frequent polishing to maintain?
TIA.
I'm not weird; I'm gifted.
BMWzenrider is offline   Reply With Quote
Old 04-28-2011, 12:00 PM   #9
ClearwaterBMW
The Examiner
Oddometer: 5,972
(photo?)
TIA.
here they are.....
this is the ones jay/barry are putting on our hacks:
http://www.jegs.com/i/JEGS-Performan...ductId=1211758
Greg
Old 04-28-2011, 01:10 PM   #10
BMWzenrider
The Road Scholar
Oddometer: 1,130
Originally Posted by ClearwaterBMW View Post
here they are.....
That really doesn't give much information about the wheels.
I don't see any info about the weight, backside finishing, etc...
And at that price, I am guessing that there is no clearcoating.
Old 04-29-2011, 08:47 AM   #11
Oddometer: 132
Thanks for the reminder. I've been meaning to weigh these wheels for about two months now. Just put them on the digital scale and also the stock wheel, both with tires on of course. Stock 1200 GS wheel/tire came out at 27 1/2 lbs. The new automotive wheel/tire came out at 30 1/4. Closer even than I thought it would be. A difference of 2 3/4 lbs.
As far as I can see there is no clearcoat on the wheel. In a strictly street application I might be more inclined to use a clearcoated wheel. My past experience with clearcoated aluminum, starting with 60's motorcycles up to present, has not been good. Part of this might be because I tend to keep my bikes a long time and they get used harder than most. I started restoration of a 74 Moto-Guzzi Eldorado a couple of years ago. I had the rear wheel torn apart and the hub bead blasted and clear coated and reassembled the wheel. It has been on the shelf for a while now waiting to be put back on. Recently I took it down off of the shelf only to discover moisture has begun to seep under the coating and I'm back to square one. The issue is that clearcoating chips easily, specially if used on gravel roads. It looks awesome on a new bike but a couple years later not so good.
Aluminum wheels are not hard to maintain with all the products available to do this now. For those wanting a more show than go finish a wheel without clearcoat will probably require a proper polishing once a year.
The back sides of automotive wheels are never polished like the front for obvious reasons. When used on a motorcycle with sidecar, for the most part, the same applies. I am including a picture of one recently installed on a 1200 GS. Sorry for the picture quality. Only have my little pocket camera handy today. This picture shows the back side of the wheel without the saddle bags or sidecar in place. Actually, even in this more open situation the brake rotor, swing arm and the small fender piece pretty well cover it up anyway. Once the bags and sidecar are in place it won't show at all.
Barry
DMC SIDECARS
Old 04-29-2011, 08:54 AM   #12
Oddometer: 132
And here's the picture.
This is what happens when I get distracted while doing something.
Barry
DMC SIDECARS
Old 04-29-2011, 01:42 PM   #13
ClearwaterBMW
The Examiner
Oddometer: 5,972
love that wheel, barry
BOTH SIDES
Greg
Old 05-02-2011, 12:05 PM   #14
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,574
Check with Woody;
http://woodyswheelworks.com/
Excuse the insert there please, Barry.
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Times are GMT -7.   It's 08:16 PM.
