Old 04-25-2011, 01:36 PM   #1
polar8 OP
Oddometer: 48
How would you restore this '85 CB700?
Got this bike on Craigslist and after a carb cleaning she was running great. I have some free time this summer and I'd really like to make it look nice again. It's rough, but everything is in good shape (owner just put a new seat on it) and there are only a few things to replace.
If this was your bike, what would you do to it? I was thinking of blacking out the engine completely, and repainting the tank in the original red/black color scheme. Then adding straight bars and a round headlight up front, as the stock gauges and headlamp are really beat up.
Thanks for the advice!
polar8 is offline   Reply With Quote
Old 04-25-2011, 02:28 PM   #2
wmax351
Oddometer: 740
Just Ride it for now. Its the summer after all. Put some bags on it and take a trip.
In the winter, I like your idea. Clean it up a bit, make the tank look nice, black out the engine. While doing that, do an inspection on the engine to make sure everything is in good order. Might as well, since you will have the engine out. Bead blast, sand, fill, and paint the scuffed up engine covers.
Maybe pick up a cluster and light from an old CB750. They look pretty good. Upgrade to an H4 light. Check the electrical system, they can be a weak spot on old Japanese bikes (or any old bike for that matter)
wmax351 is online now   Reply With Quote
Old 04-25-2011, 02:38 PM   #3
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 796
I wouldn't restore it. Just make it reliable and turn it into a mad max rat bike. It's halfway there.
2004 Harley Sporster 1200C, 2001 Ducati M900, 2001 Honda XR650L, 1994 Harley Heritage, 1978 Honda CB750K with sidecar, 1977 Moto Guzzi 850 LeMans, 1976 Honda CB750K, 1965 Honda 305 Dream, 1973 Norton 850 Commando, 1971 Triumph Trophy 650, 1970 Honda Trail 90, 1970 Triumph Tiger 650, 1973 Honda Z50, 1984 Yamaha Virago 1000, 1981 Honda Passport 70, 1970 Suzuki T250, 1971 Yamaha RT1 360
lrutt is offline   Reply With Quote
Old 04-25-2011, 02:42 PM   #4
south
Oddometer: 176
Well, first off, if it was me, I wouldn't do anything with it for awhile 'cause it'd be at the back of the project line, but my plan would go like this:
First, source replacements for the missing bodywork--side covers, tail, headlight nacelle (perhaps not OEM, maybe graft something else that looks good), etc.--from ebay, local junkyard, wherever. Paint it to suit your fancy.
Next, speaking of paint: less is more--no paint for the engine, etc. Painting aluminum, especially oxidized aluminum, ain't what I'd call a "long-term" solution. Rather, take advantage of the fact that big chunks of the bike are aluminum; I'd strip, sand, and polish every (aluminum) bit of the thing I could. Not only will it look great, but it's cheap, requires no special skill (just some time and effort), and it's low-maintenance from there on out--just a quick freshen-up wipe with some metal polish now and again will have the stuff right back to full bright. Do the valve cover, the engine side-covers (clutch and gen), fork lowers, rear brake drum/drive hub, brake and clutch MCs, perhaps the front calipers, etc. Ideally, I'd pull the engine and media--i.e., "sand"--blast it. If you have access to compressed air, hobby media/sand blasters sufficient to do the job can be purchased for well under $100, and they can be very handy things to have--just be sure to seal up the motor real good before blasting.
Along with all that, give it a good cleaning/detailing, replace the 25yo front brake lines with some braided stainless lines (new fluid is a given) and mount up some decent (new) tires.
Of course, if it was me, ultimately, most of all, I'd want to restore the missing 50ccs.
'88 KLR650 Project Thread: http://www.advrider.com/forums/showthread.php?t=667727
'01 VFR800, '03 CBR600RR, '78 CX500, '04 EX250, '82 XJ650L, '75 CB360.
Projects: '89 GS500, '86 ZX1000R, '85 XL350R, '71 CB750, '78 GL1000,'90 CH250
south is offline   Reply With Quote
Old 04-25-2011, 02:50 PM   #5
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,534
First thing....valve adjustment
Old 04-25-2011, 03:14 PM   #6
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,121
No need with the CB700, aka Nighthawk S, all hydraulic.
Restored to original, the bike is worth a lot more. Clean examples, even with high miles bring $3000+. The model was only offered for three years, 1984-1986.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 04-25-2011, 04:39 PM   #7
polar8 OP
Oddometer: 48
I don't have any blasting equipment, so I'd probably have the blasting done by a local shop. I take it using aircraft stripper on the engine fins isn't as easy as with flat surfaces, but is it possible to do it that way?
Old 04-25-2011, 04:50 PM   #8
Houseoffubar
fine beer sampler
Oddometer: 1,534
-Joe
Sorry, just trying to be funny!
Old 04-25-2011, 11:24 PM   #9
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
The only problem I can see is getting hold of the proper body work.
Don't hate me, but as much as I like those bikes in stock condition, a really nice paint job and switchng to a round HL kind of appeals to me-
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 04-26-2011, 12:31 PM   #10
bk brkr baker
bk brkr baker's Avatar
Oddometer: 4,160
Fab your own sidecovers from leagaly harvested free-range road signs.
No paint unless it's matt black. Round headlight will be O.K. , go for one of the 9' jobbies from a GS Suzuki or early 80's Yamaha.
Build a luggage rack to cover the space behind the seat. Preferably with a hidden stash box.
Old 04-26-2011, 08:12 PM   #11
squish
Out of the office.
Oddometer: 4,948
Unlike lots of folks I don't hold these bikes in very high regard
Heavy, slow, shaft drive, wonky handling, and styling that's not quite sportbike UJM and not quite UJC
Personally I'd get some side covers and tail cowl for it.
Source up a round headlight, ditch the monster instrument panel
Slap a decent rattle can paint job and ride the snot out of it.
Years a ago I bought one from the son of some bigwig at Honda R&D
Low miles great shape, and I was very happy to have sold that bike.
On vacation for a spell
squish is offline   Reply With Quote
Old 04-26-2011, 09:06 PM   #12
Steve G.
Steve G.'s Avatar
Oddometer: 5,917
Do not turn this bike into a money pit! It will never be worth much, even if you do a concours restoration. Get it running, and treat it like a car, just run it.
Steve
Garage Residents:
'72 Norton 750 Combat, '74 Honda CT70,
'74 Norton 850 Interstate, '81 Laverda Jota
'89 Honda RC30, '91 BMW R100GS
'08 BMW R1200GS
Steve G. is offline   Reply With Quote
Old 04-27-2011, 05:00 AM   #13
vernon dent
vernon dent's Avatar
Oddometer: 559
Steve
agreed. i see nice original, low mileage examples locally advertised for under $2k.
I only ride 'em. I don't know what makes 'em work.
Oddball
vernon dent is offline   Reply With Quote
Old 04-27-2011, 05:12 AM   #14
bones_708
Oddometer: 560
I can't think of why anyone would unless it had some special meaning. I would get it running and maybe do little things to fix it up. When you pull a tank and side covers paint is cheap enough, but to do a full resto? I don't see it
bones_708 is offline   Reply With Quote
Old 04-27-2011, 07:11 AM   #15
Kurt V
Oddometer: 225
I'd worry about the mechanics before the cosmetics. First off change that brake fluid. Looks brown in the reservoir.
Kurt V
1976 R75/6
1976 Honda CB400F Original Survivor
Kurt V is offline   Reply With Quote
Times are GMT -7.   It's 12:54 PM.
