Old 08-31-2013, 11:26 AM   #571
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,015
Ned - I also just switched to the K-60 (all three corners) and was immediately impressed! I'd tried Tourance up front before, but only got 5k out of it. Tried Anakee II next and it was bald in 3500 miles! On the run to Oregon I used an ME880 on the front and while it still had tread left after 8800 miles its ability to initiate a turn on dirt or gravel was marginal at best.
Fall is coming up here in New England and with it my need for traction on the back roads gets bumped up a notch or two. So I decided to try the Heidies in the standard GSA sizes. My impressions:
Rear and Hack 150-70/17: The continuous center strip will probably result in decent life, but it also has much less grip on curvy dirt roads. Since I like power slides that's not a bad thing, but it did take me by surprise the first couple of times. After a few hours practicing my new found ability to slide, it's actually kinda fun. But my bet is that strip will severely impact my traction in mud and snow.
Front 110-90/19: I really like this tire! It grips in the dirt even when the rear has broken loose. It's just a tad squirrelly on pavement, but our roads are so bad anyway that it really doesn't matter. Others have complained that they howl at 70mph, but I didn't notice it today while slabbing at 80. The truly surprising thing was this tire has completely eliminated the low speed headshake on my rig, and steering up to about 60mph is easier!
I experimented with various tire pressures on the Tourance, Anakee II and ME880s but never completely eliminated the shake. The 880 required a lot more steering effort than the other two even when brand new, possibly because it was a 120-80/19. But the Heidi was steady from the start, and steering is far more nimble than I've experienced since starting the hack thing 44,000 miles ago. If they wear well I might just have discovered my new fave!
I got a sidecar to travel with my dog. He never complains, is delighted to be with me, approves of my dietary choices, is a social butterfly who helps me meet folks, appreciates a good beer, snuggles better than my wife, and hangs on my every word as if it's the most profound thing he's ever heard. TravelsWithBarley.com
Boondox is offline   Reply With Quote
Old 08-31-2013, 12:35 PM   #572
walkingbear
walkingbear's Avatar
Oddometer: 3,540
get well !
Just took the R1150GS on her first trip from the house.
Got Thurs. worked on a few things. The first 2 miles down the road was fine. Carrying 100 lbs of sand. Was going to make a right turn and I forgot to steer and it went left fast. Learned a lesson and there is a sticker on the the windshild in bold letters STEER .
I have the same set up as you .. what did you do with the abs. Did you leave it on. I felt the side braking and it was pulling right. I guess I will get use to it.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 08-31-2013, 12:42 PM   #573
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,529
Many years ago I had a Dymo label maker and but COUNTERSTEER on the top clamp.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 08-31-2013, 01:34 PM   #574
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,788
Crawl then walk then trot then run. It'll come.
No ABS. Brakes are conventional. Completely removed the ABS modulator.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 08-31-2013, 02:39 PM   #575
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 5,972
i've just returned to the forum after some time
i just read of your mishap
YOUR RIG was one of the main reasons i got mine
everyone here knows that
so...
i'm sorry about your crash
i'm thankful you were not hurt more seriously
i'm happy your shared this with us, but sorry you had to, obviously
i'm just now trying to ingest and digest all that you've written here, my friend
in disbelief, quite frankly
Greg
'11 R1200 GS Adventure with a DMC M72DX Sidecar
'14 R1200 GS & '14 R nineT (march, 2014)
Live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is offline   Reply With Quote
Old 08-31-2013, 02:41 PM   #576
ClearwaterBMW
The Examiner
Oddometer: 5,972
please keep us informed with more updates such as these
thanking you in advance
Greg
Old 08-31-2013, 03:06 PM   #577
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,788
Oh My GAWD!! He's B-A-A-A-C-K!!!!
Welcome back, Doc!
I thought maybe you'd decided to emulate your daughter and take up paddling full time--
That's you kneeling in the Stroke position, yes?
WUMPA
Sidecardogs.com
Old 08-31-2013, 06:14 PM   #578
ClearwaterBMW
The Examiner
Oddometer: 5,972
where'd you get that picture of my family?
Greg
Old 08-31-2013, 08:54 PM   #579
walkingbear
Oddometer: 3,540
wiring battery
I sat looking at the car this evening figuring how to wire a 2nd battery into the back of the car. Like you I carry a cpap when camping. I think I will use a dual switch. Do you run the connecting wiring directly to the existing battery or do you a different frame ground and just run the hot ?
Old 08-31-2013, 09:31 PM   #580
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,788
I just have the one main battery. I'll send you a PM explaining my CPAP setup.
There are lots of threads discussing CPAP setups--try one of these.
Also lots of threads discuss dual batteries and isolators--here.
WUMPA
Sidecardogs.com
DRONE screwed with this post 08-31-2013 at 09:42 PM
Old 09-01-2013, 06:50 PM   #581
walkingbear
Oddometer: 3,540
shock
In 3 days of driving , I can tell the sidecar shock is really soft. What shock were you running
Old 09-01-2013, 06:56 PM   #582
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,675
It should have a rocker linkage and you should be able to lengthen or shorten an arm to increase preload pressure, they all use Performance shocks (inexpensive) Any head shake on your rig ? DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 09-01-2013, 07:22 PM   #583
walkingbear
Oddometer: 3,540
got the rig up to 65mph and ran pretty straigh. I can make u - turns really ez thanks to the new front end mods. Just going over bumps I can feel the car dip. Like to stiffen the shock.
Think sway bar also.. since most of roads here have holes in them.
Old 09-10-2013, 07:26 PM   #584
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,675
Drones trip and the size of the world !
I was sitting in a cafe in Frontenac MN when a older gentlemen came in after looking my sidecar and dog over.He was retired and lived in multiple states.His son in Seatle may have made him a slide show and or video of Drones trip complete with almost tragic ending.I found Drones youtube postings and it wasn't there so I suspect another inmate assembled and posted it.He was really enthused thought everyone who owned a BMW sidecar rig and a dog must be related, Drone your at least a national personality.DB
Ambrose Bierce
Old 09-11-2013, 04:03 AM   #585
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,015
We're not..?
When I met Burt in WI and Duncan in WA I immediately noticed a strong family resemblance
Times are GMT -7.   It's 01:11 AM.
