Old 03-31-2014, 09:48 PM   #691
boxertwin
Oddometer: 1,022
When Thing Two and I got back from CDA in 2012, Madam BT saw this one and said, "Who is that?"
boxertwin screwed with this post 03-31-2014 at 09:54 PM
boxertwin is offline   Reply With Quote
Old 03-31-2014, 10:48 PM   #692
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,759
Yeah, who is that girl sitting in your rig? Could it be that Thing Two was getting an early start? I guess you're never too young to learn that a guy really ups his potential when he's driving his Dad's hack!
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 04-01-2014, 08:18 PM   #693
claude
Sidecar Jockey
Oddometer: 3,714
Cool little sidecar with a PRETTY WILD STEERING DAMPER SETUP.
Claude
http://freedomsidecars.com/
Old 07-04-2014, 05:26 PM   #694
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,759
Back on p. 33 of this thread I described the mechanical failure I had in Wyoming that caused me to wreck (11 months ago). That post led to a number of comments and observations and suggestions from various inmates. Well, today, I finally got around to disassembling the front end and cleaning up the parts to take a closer look. What I found was fairly interesting, but not being too schooled in these things, I'm not really sure what I'm seeing.
First, the ball joint. There was plenty of anti-seize still in the threads so at least I know that the assembly instructions were followed for that. I was expecting to find lots of metal from the fork bridge threads embedded in the ball joint threads, but I did not find any! Instead, I found that the steel threads of the ball joint were deformed and partially flatted. To make certain, I used a steel dental pick to dig into the threads but all I got was the anti-seize remains. The first 6 pics below show the six sides of the ball joint (in sequence) so you can see that ALL the threads are flatted all the way around, with one place worse than the rest--
I don't understand how the relatively softer metal of the fork bridge could deform the steel threads of the ball joint.
And by the way, the other end of the ball joint--the part that attaches to the swingarm and gets the red loctite treatment--that's still tightly mounted and undamaged.
So what does the DMC fork bridge look like? The threads are destroyed from the top down to 14mm deep. And the ball joint is 14mm deep, so the ball joint was seated all the way down at some point. But again, what I found interesting, is there was no loose metal or stripped threads. Instead, the threads appear to be mashed down or "flatted". But all the metal seems to be there.
I don't mean to start any new controversy here, but I am curious as to what sort of motion caused the threads on both pieces to get deformed like this. Rather than supposition (guessing), I'd really like to hear from folks who've seen this before and know what causes it. Especially if they are not from Minnesota.
Old 07-04-2014, 07:58 PM   #695
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,515
The ball joint came loose. Once that occurred the threads are no longer locked together on one edge so they can now move up and down. Time, and the hammering that resulted, did the rest.
14 mm ain't a lot, rough rule of thumb is 1.5 x diameter.
Welcome to your vibration.
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 07-04-2014, 08:02 PM   #696
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,535
But wait lets here from MN anyway.
Why would there be anti seize on those threads ? Are you sure it's anti seize and not aluminum turned to powdery consistancy.
When BMW assembles them they use a grey loctite takes about 3-400 degrees to get it apart, perhaps the previous owner who may have installed the trail reducer partially cross threaded it backed it out and started over, in trying to assemble it correctly he added a bunch of anti seize to ease the threading .
If you didn't assemble it someone did you a great dis service, your only failure was in not finding it and believing the nonsense your youthful BMW tech told you that sometime things have to break to figure out what's wrong.That's as kind as I can be .
On the other hand intentionally misaligned fork tubes be it DMC or Freedom sidecars trail reducers is a bad idea ! I don't care how many either of them have sold and adding another joint to raise the front back up just doubles the chances for trouble.
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 07-04-2014, 09:27 PM   #697
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,759
The BMW Service Manual actually calls for anti-seize on those threads. After all, it's steel on aluminum, with a lot of torque -- 230 Nm.
I know that some of you guys think the ball joint is where my vibration was coming from. But when I finally get this bike rebuilt and back on the road (as a 2-wheeler) I'm totally expecting the vibration to still be there. I will be shocked if the vibration is gone. But then again, I've been shocked before. And wrong before!
Old 07-04-2014, 09:41 PM   #698
norton(kel)
vintage
norton(kel)'s Avatar
Oddometer: 1,159
I thought you sent the bike to the breakers. Post 621 ?
norton(kel) is offline   Reply With Quote
Old 07-04-2014, 10:15 PM   #699
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,759
Insurance company did that. I bought it back for $1400 a couple of months later when it went up on auction.
Old 07-05-2014, 06:12 AM   #700
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,535
Not unusual at all for an anti seize formula to have thread locking qualities, custom bicycle wheels often use such a product on spoke threads,after taking 8-10 ball joints apart while building trail reducers they seldom come apart without heat, then quite easily.Looking at the images again it wasn't cross threaded just loose.DB
Ambrose Bierce
davebig screwed with this post 07-05-2014 at 06:19 AM
Old 07-05-2014, 07:45 AM   #701
rg, sw wa.
Oddometer: 250
Ned, thanks for your followup observations, comments and pictures.
And, Dave and FR thanks for your insight and comments.
Ron,
rg, sw wa. is offline   Reply With Quote
Old 07-05-2014, 08:56 AM   #702
norton(kel)
vintage
Oddometer: 1,159
Old 07-05-2014, 09:41 AM   #703
cluedog
Oddometer: 62
Ned
Thanks for taking the time to post the pictures.
cluedog is offline   Reply With Quote
Old 07-05-2014, 03:25 PM   #704
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,300
Thank you Drone for these excellent pictures.
I full agree with Davebig's commentary here . Davidovich is right that one needs to heat BMW's glue to a certain temp to loosen it. Done it before and did it the BMW way-(Hitze > Heat) . Forcing the ball joint off without heating would seriously damage the treads!
As for the elongated crooked ball joint, me thinks that the brute force inflicted on the joint on the way of separation caused the deformity .
cheers...
Abenteuerfahrer screwed with this post 07-05-2014 at 07:13 PM
Abenteuerfahrer is offline   Reply With Quote
Old 07-05-2014, 07:35 PM   #705
Melrone
Oddometer: 945
When I put my Dauntless reduced tree on. I didn't use the old balljoint I replaced it with a new one. So I knew everything was new. But by the way your look somebody really screwed up...The hardest part I had was touquing right. DiDn't like the way my front end dropped but sure like the way it steered.. When we put it together the way the manual said used the right type of Lock tite, Haven't had a problem... After your accident I checked my front end and everything was tight... In my opinion I'd check with the person who installed it and go after his ass...
Melrone is offline   Reply With Quote
Times are GMT -7.   It's 01:38 PM.
