Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 33 votes, 4.97 average. Display Modes
Old 02-21-2012, 07:03 PM   #241
natedog39
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,569
Originally Posted by TwilightZone View Post
Many diesels require anti-cavitation additives for coolant. Wonder if it was coolant ?
While a PH balanced coolant is good for any engine, it's wet liner blocks that "require" additives.
Usually via a coolant filter change.
2014 FE 501
2012 990Adv
Team Ghetto does a hot lap of America
natedog39 is offline   Reply With Quote
Old 02-21-2012, 08:10 PM   #242
Joz OP
What could go wrong?
Joz's Avatar
Oddometer: 1,898
I'll have to look into the pH balanced coolant.
From the research I've done, cavatiation seems quite prevalent on PowerStroke diesels. While it's possible on others it doesn't really seem to be a reoccurring theme.
As for the oversize (extra thick) head gasket - I'm not really concerned since Cummins offers them and tons of the high-power guys use them. I'm only at the first oversize head gasket and there's one more to go. There was no indication that anything was wrong with the deck, head or head gasket surfaces. I think this problem was the original issue before I even got the engine. There was no indication of head gasket failure but the #4 piston was worn. Most likely from the bore being washed clean of oil by coolant.
Milling the block and or head seems to be a quite common and acceptable practice on these engines. The o-ringed head gaskets and fire rings are for the super power guys - not what I'm doing.
Don't know if they're going back to stock cylinder/piston sizes or staying with the .020 over. I didn't ask. Honestly, I don't really care so long as the engine is reliable, fuel efficient and powerful.
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 02-22-2012, 03:24 AM   #243
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,621
So all that goo in the oil was combustion gasses and there was never coolant in the oil?
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 02-22-2012, 03:34 AM   #244
seriousracer
be a man dodge tree bark
seriousracer's Avatar
Location: i am not f***ng stupid,but i used too. niles mi.
Oddometer: 7,434
no there was a small hole in the 4 cylinder...A pin hole that was leaking coolant in to the oil. below the piston at TDC and above the piston at BDC.
seriousracer is offline   Reply With Quote
Old 02-22-2012, 05:59 AM   #245
madeouttaglass
The AntiHarley
Oddometer: 3,621
got it. damn.
Old 02-22-2012, 09:31 AM   #246
showkey
Oddometer: 1,997
Congratulation on finding the problem...................and sticking with testing/investigation vs parts replacing...........new head would have been one expensive failed test.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 02-23-2012, 05:32 PM   #247
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,222
you sir are Job. The Biblical Job
cheers
Carlo Muro is offline   Reply With Quote
Old 02-23-2012, 09:32 PM   #248
zgfiredude
Oddometer: 873
Good read.......start to finish this evening and I'm not a diesel guy!
Joz, I gotta buy you a beer sometime just cuz!!
Cheers
zgfiredude is offline   Reply With Quote
Old 02-23-2012, 09:37 PM   #249
Cycle61
wannabe
Cycle61's Avatar
Oddometer: 348
Damn, of all the places I would have never looked for a leak...
Cycle61 is offline   Reply With Quote
Old 02-24-2012, 05:43 AM   #250
AtlantaViking
AtlantaViking's Avatar
Oddometer: 983
Curious about the fix...Do you just re-sleeve the cylinder or is it a block issue??
I'm here to chew bubblegum and kick ass....and I'm all out of bubble gum
06 Suzi DL1K
99 Suzi DR350SE
AtlantaViking is offline   Reply With Quote
Old 02-24-2012, 07:37 PM   #251
Joz OP
Joz's Avatar
Oddometer: 1,898
Resleeved all 6 cylinders just for good measure.
The block is in my garage now; reassembled and ready to be installed tomorrow. Hope everything works perfectly.
Old 02-26-2012, 10:25 AM   #252
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,577
Better to be safe.
Unless you enjoy limping home from long trips and pulling motors every couple of months.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 02-26-2012, 10:30 AM   #253
seriousracer
Oddometer: 7,434
seen it on ford engine and some others..not "super " common..
Old 03-01-2012, 10:07 PM   #254
Joz OP
Joz's Avatar
Oddometer: 1,898
Well, the engine went in last weekend but as soon as I got it warmed up a new problem presented itself. The gasket sealing the push rod gallery was leaking. And the only way to replace it is to remove the injector pump. Which means a ton of other stuff had to be removed.
Well, after a few hours work each night she's all back together and running tonight - with NO LEAKS and NO SMOKE (well relative for a diesel). AWESOME! Everything checked out okay on a short test drive tonight so I'll be taking her to work tomorrow. I hope all really is good now.....
Old 03-02-2012, 03:45 AM   #255
c.herman126
c.herman126's Avatar
Oddometer: 529
I hope she runs great today!
"Dream as if you'll live forever. Live as if you'll die today" James Dean
1993 XR650L
2008 530 EXC-R
c.herman126 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 10:39 PM.
