Old 06-25-2012, 10:10 PM   #1591
helotaxi
Oddometer: 380
Originally Posted by TeamJunk View Post
The stock chain lenght on the 500exc is 114 pins with 15/45 gearing, runnnig a 14/48 gearing the rear tire rubs the
the rear shock guard mud flap with stock chain lenght, I run a 116 pin chain with 14/49 gearing.
I have 14/48 gears right now with the stock chain and I'm not having an issue with the tire rubbing on the flap.
helotaxi is offline   Reply With Quote
Old 06-25-2012, 11:55 PM   #1592
oldx
oldx's Avatar
Oddometer: 1,094
Originally Posted by ABYSS View Post
Removed the disk and use a DA and hit it good with 36 grit paper. you need to get the GLAZE off and also its needs to have a surface in it 36 Grit used opn a Da makes it perfect. It only takes a few minutes.
Next replace the factory metalic pads with non metalic ones.
What is happening is the metalic pads are glazing the rotor.
Once you do that Squeek will be gone for good.
Cool thanks
oldx is offline   Reply With Quote
Old 06-26-2012, 05:51 AM   #1593
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,220
cool, I'll give this a try.
What is a DA?
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 06-26-2012, 06:17 AM   #1594
snow
snow's Avatar
Oddometer: 63
What is a DA?
Dual Action Air Sander
2012 GS 1200
IBA#16641 ride every chance you get.
snow is offline   Reply With Quote
Old 06-26-2012, 06:21 AM   #1595
Lulu7404
Oddometer: 276
random orbit
Not suggesting it is a replacement, but would a random orbit electric sander work for those that don't have the compressor capacity to run a DA? Say from Porter Cable or DeWalt.
14 Triumph Tiger 800
13 KTM 350XCF-W -- new hotness
13 KTM 250XCF-W -- hers
Lulu7404 is offline   Reply With Quote
Old 06-26-2012, 07:06 AM   #1596
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,423
I have preformed a similar fix on the rear breaks using medium sand paper and my hand... ya know... the old way. Wrap sand paper over disk and spin tire.
The real trick I think it the right shoe material. Non metalic is the way to go...
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is online now   Reply With Quote
Old 06-26-2012, 11:15 AM   #1597
ABYSS
KTM
Oddometer: 1,198
any orbital sander
should work just fine
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 06-26-2012, 12:36 PM   #1598
helotaxi
Oddometer: 380
For those that have the HDB hand guards, how are you keeping the clutch line off the spacer that goes between the top clamp and the guard. Mine is jammed right against that bolt and I can't imagine that's going to be good long term.
Old 06-26-2012, 12:41 PM   #1599
ABYSS
KTM
Oddometer: 1,198
Eh? Hmmm
I don't have that issue. Do you have a pic?
Maybe = NO
Old 06-26-2012, 12:47 PM   #1600
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,746
go under the connection, not over the connection.
Otherwise I do not know what the issue is. Pics?
toddler is offline   Reply With Quote
Old 06-26-2012, 02:51 PM   #1601
helotaxi
Oddometer: 380
It won't fit under the fitting and I can't rotate the lever perch far enough down to clear without the fitting hitting the bar. The clutch perch is as far toward the end of the bar as I can get it without the adjuster nut hitting the switch assembly (0.5mm of clearance).
Old 06-26-2012, 09:09 PM   #1602
avconnect
Oddometer: 119
I have the same issue and am looking for a solution...tried a EE clutch cable and it was a bit longer but did not solve the problem.
avconnect is offline   Reply With Quote
Old 06-26-2012, 10:17 PM   #1603
helotaxi
Oddometer: 380
Cable length isn't the issue. The issue is that the fitting that comes out of the clutch master cylinder is straight and too long as opposed to a brake style banjo fitting. I've got a feeling that I'm going to have to switch over to and aftermarket narrow switch set that will let me slide the clutch lever perch farther out.
Old 06-27-2012, 12:30 AM   #1604
Thumperconvert
Oddometer: 1
The SICASSracing switch is half as wide as the stocker
...and allows you to tun off the headlight. I put one on my 530 after a fall destroyed the stock unit as dirt got in it. I tried for hours to clean it but it was never the same. When these bikes go down, they go down hard. I destroyed the stock throttle tube (replaced with KTM Powerparts throttle cam system) and just bent a Cycra center reach mount brush guard. That same spill broke the throttle cable plastic where it enters the throttle assembly. Expensive tumble not to mention a bruised rib. Ouch.
http://sicassracing.com/store/produc...ion_bar_switch
Thumperconvert is offline   Reply With Quote
Old 06-27-2012, 01:43 AM   #1605
LukasM
Oddometer: 5,426
What switch do you have now?
The stock Euro KTM CEV one is super compact and also very durable. I've got an extra if you need one.
Times are GMT -7.   It's 07:52 AM.
