06-28-2012, 01:59 PM
#1636 | |
KTM
Oddometer: 1,196
If you are changing the line
Every question in life has an answer of YES OR NO Maybe = NO Keep life simple and enjoy it!
06-28-2012, 02:05 PM
#1637 |
Oddometer: 302
Ummm, you lost me. You mean mount the switch housing inboard of the clutch perch? If that's what you're talking about, it won't work because the cylinder itself has a section sticking out of the end and the switch housing won't clear that for certain.
06-28-2012, 05:48 PM
#1638 |
KTM
Oddometer: 1,196
ssorry man
I am not near my bike to look I thought from what I was reading that with the fitting removed it would be flush with the resovior. if that was the case then all you would have to do is a reverse 90 banjo fitting and you are golden.
06-28-2012, 06:47 PM
#1639 |
Oddometer: 302
If you look at the pic that Paul posted with the dust boot off, all the black is part of the master cylinder. It accounts for about half of what's under the boot.
06-29-2012, 05:04 AM
#1640 | |
Oddometer: 216
MY issue
It was just a matter of all of murphys stars lining up perfectly for me... that is where I like the lever to hit my hand... almost. I think the sicass or Pauls switch will fix it and allow me to put the lever where I am comfortable. Pitch is also an issue, as I try to stand as much as possible off road and don't like to extend my wrist too far. In the picture, you can see a rather large, bulge, where my lever hits as I engage the clutch. This is due to rotating the lever/clutch m/c, down for comfort. I leave in 3 hours for Ouray and since I won't need to reach my horn or blinkers (i commute on bike everyday) without needing to look for them, I am going to rotate the switch module and see if that allows full lever pull. And thanks Paul, for the effort. Class act. I wish all the 500 owners could meet up in the San Juans this week.... maybe in the future...
12 KTM 500EXC |
06-29-2012, 05:37 AM
#1641 | |
KTM
Oddometer: 1,196
06-29-2012, 06:13 AM
#1642 | |
Oddometer: 73
However, the clutch cable clearance issue is a different issue. Depending on which HDB top clamp you use you will have problems. Paul does not necessarily need to find a solution but should probably disclose the issue to potential purchasers and if we find a different clutch cable that fixes the issue (longer and a different connection at the master cylinder) he should tell folks about that cable or sell it through his website. My earlier representation about Paul was true but not necessarily critical. I spoke with him about the cable issue and sent several pictures at his request in the hope he would lend his expertise to the problem. I never heard back from him but I was probably the first and only person to point it out at the time and I know Paul is very busy. Paul was very accommodating and helpful on other custom requirements and my earlier statement in this forum that Paul is the Bomb remains the case despite my concerns about the cable clearance issue which arises when you use the HDB guards and certain top clamps. I will post more photos when I can get to my computer. The photos will show the cable clearance problem with both the stock cable and the EE cable which is longer and helps lessen but does not eliminate the problem. |
06-29-2012, 07:56 AM
#1643 | |
Oddometer: 73
[IMG] [/IMG]
06-29-2012, 07:59 AM
#1644 |
KTM
Oddometer: 1,196
Question
I have a question for you. If you were able to replace the cable do you think you could have got one with a banjo fitting and put inline 90 digree fitting the on it so it would lower the cable down below the top triple clamp? Or how about two 45s or 2 90's to lower the fitting below the top triple clamp.
Again this is not a criticism just a question?
06-29-2012, 08:20 AM
#1645 |
Oddometer: 216
not going to RMAR
Unfortunately the DR lady at work will be out of town that week, so I have to see all of her patients. I wanted to, even booked an RV spot, but had to cancel.
12 KTM 500EXC |
06-29-2012, 08:22 AM
#1646 | |
KTM
Oddometer: 1,196
ouch
sorry man I feel your pain. I wanted to go as well but work was not permitting. Heading up to CO at the end of August
06-29-2012, 08:54 AM
#1647 |
Oddometer: 302
It looks like that Woods high bend bar has helped him out a good bit compared to where I am.
I'm pretty sure that if the master cylinder is threaded correctly, a banjo style brake line will solve all the problems of cable clearance. |
06-29-2012, 09:46 AM
#1648 |
Oddometer: 1,022
Just picked one of these bad boys up. Obviously it needs a skid plate. What skid plates are people running? Any thoughts on one that people prefer?
KTM 500 XCW |
06-29-2012, 09:55 AM
#1649 |
Oddometer: 302
It seems that the KTM Hard Parts models (both aluminum and polymer QD), Flatland Racing and Enduro Engineering are all pretty popular. I have the Flatland and it works well but is a real PITA to install by yourself. A second set of hands is a real plus.
06-29-2012, 09:57 AM
#1650 | |
Oddometer: 70
http://shop.globetrottin.com/product...&categoryId=33
No Matter Where You Go, There You Are. |
