Old 07-29-2012, 04:25 PM   #1996
pitbull doug
Oddometer: 214
Originally Posted by Stu View Post
You do have a valid point worth considering. If you have enough line the kink is not a factor and I would have that. If you have enough line you will have to have some way to restrict the line so it does not get caught by bushes. I will just relocate it with nylon ties.
Stu
Yeah when you get your new ride check it out as with a larger radius line to eliminate kinking, then you make it vulnerable,you could zipty as you say, but kinda hacky, when you get your bike and check the real estate parameters that that you have to work with which ain't much you will see. But if you come to a fix please PM me, hopefully a aftermarket high pressure replacement hose will become available? That would be happening eh! Cheers bottoms up!
06 Ktm 640 adv SOLD
04 Montesa Cota 315
07 Ktm 200 excw
13 ktm 500 exc
01 Honda cr500
pitbull doug is offline   Reply With Quote
Old 07-29-2012, 04:46 PM   #1997
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
Anybody know how difficult it is to replace valve shims? I just measured my valve play and noted that exhaust were right in spec, but the intakes were off. The right side (kickstand side) measured .15mm, and the left measured .13mm. .15mm is still in spec, but at the high end.
It appears the valves should be easy to adjust..... couple of locking nuts on top and slide out the arm....but, i could be wrong......
Any ideas?
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 07-29-2012, 05:44 PM   #1998
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
Any ideas?
Never mind, seems I'll answer my own question.....
I did some searching and came across this thread, which does a pretty nice job of explaining the process...
http://paochow.com/forum/index.php?topic=40.0
Old 07-29-2012, 07:34 PM   #1999
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
Don't pull the rocker arms to adjust the valves. Read farther down to the reply about pulling the cam. It's easy that way.
"Son, you can't do both"
Old 07-30-2012, 04:02 AM   #2000
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
Cool, thanks for the tip.
Old 07-30-2012, 06:27 AM   #2001
cross-country
cross-country's Avatar
Oddometer: 1,662
Any reason you couldn't just push the valve down manualy and suck the shim out with a magnet? If done this on other shim-over KTM's before.
cross-country is offline   Reply With Quote
Old 07-30-2012, 06:39 AM   #2002
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
What did you use to push the valve down.....compress the valve spring?
Old 07-30-2012, 07:15 AM   #2003
cross-country
Oddometer: 1,662
A forked piece of metal. I have some old tool that looks like a prybar with a forked end on it, I suppose you could just use a large screwdriver though.
Without prying on anything, I pushed down on the retainer/spring cap. It didn't take much. Putting them back in is a little harder, helps to have three hands.
Old 07-30-2012, 09:31 AM   #2004
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,599
What did your 500 do over the weekend?
Me - Yanked the little 17's for the dirt setup. I have the swap down to about 25-30 min.
Took it for a rip with the guys in Ocala National Forest. Did everything from hard pack to sugar sand to single track to flooded jeep trails. Real hot this time of year. The bike did great, About done with the stock knobbie. Starting to think about what I want to replace it with?
No pix of the action till the GoPro guys do thier thing. I did take a "dirty" pix in the back yard before the bath.
Guns keep society safe.
Colemanfu is online now   Reply With Quote
Old 07-30-2012, 09:48 AM   #2005
ABYSS
KTM
Oddometer: 1,198
replacement tire
My vote woudl be for a michellin Ac-10 rear and a michellin Desert front. I really liek this combo and they hold up pretty well.
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 07-30-2012, 11:35 AM   #2006
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
i know i'm not much help on the tires but...
what rear rack is that? anybody else know of any good rear racks that they've had some experience with?
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 07-30-2012, 11:52 AM   #2007
ABYSS
KTM
Oddometer: 1,198
promoto Billet
They are the best on the market,"For there size" calll Brett at PMB his number is 208-466-4762
Maybe = NO
Old 07-30-2012, 12:51 PM   #2008
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
I hope the rack is designed better than their kick-stand....
Old 07-30-2012, 01:06 PM   #2009
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,391
You're the only person who seems to have any problems with them? Mine works great.
jesusgatos is offline   Reply With Quote
Old 07-30-2012, 01:20 PM   #2010
jar944
jar944's Avatar
Oddometer: 696
I have 3 of the stands.. no issues with them, in fact I think they are fantastic.
jar944 is offline   Reply With Quote
Times are GMT -7.   It's 03:36 AM.
