Old 08-23-2012, 02:03 PM   #2206
Stu
Buffo Maximus
Oddometer: 850
EU Map
Switch 500 topic to ignition curves.
Does anyone have the KM787EU12C0701 map file? This is the European map for the 500 EXC. If so, let me know. This format, the C0701, works with aftermarket mufflers. The EU allows us to use map switches on our handlebar to change mapping for changes in our racing environment.
These files map the ignition to the engine configuration (c.c.s, cam profile, etc.) so there are a pile of them for the various engines and configurations. If you want to fine tune your ignition for racing these are needed. Get the JT Tuner 6X to then refine your jetting. The nomenclature is not clear to me. I'm guessing that KM = KTM Map, 787 = 500 with exhaust changes (775 is for the 350s), EU = Euro map (US = maps for the XC-Ws, EXCs, etc. in this market), 12 = the year and the CXXXX = software version. Please chime in if you know what these various parts of the file name are. It would help so that someone with a 350 didn't try to load a map for a 250, for example, and screw their engine up.
It would be really great if someone would publish software to load on our laptops to change ignition mapping track side for whatever conditions we need. Car guys do this. Factory motorcycle teams do it. We need it as well.
Stu
Stu is offline   Reply With Quote
Old 08-23-2012, 06:18 PM   #2207
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 671
Originally Posted by Stu View Post
...It would be really great if someone would publish software to load on our laptops to change ignition mapping track side for whatever conditions we need. Car guys do this. Factory motorcycle teams do it. We need it as well.
Has anyone tried to see how far they can get with the TuneECU software? The 690 crowd can swap maps at will. I've lent my cable to an inmate so can't try it. Same KTM plug as for the 690.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 08-23-2012, 08:48 PM   #2208
bill1960
Oddometer: 273
Originally Posted by toddler View Post
This thread should help you in what I've done.
http://www.advrider.com/forums/showthread.php?t=740375
Thx, it was helpful.
I want to keep the cockpit minimalist.
The 500 XC-W has the headlight switch by the computer and starter and kill button mounted next to the clutch and brake perches respectively.
If I retain that, then I just need two switches for high beam and horn, preferably near the perches for easy access.
Wondering if the top perch double switch from HDB will fit the 500 XC-W brake perch of clutch perch ?
( I dont need turn indicators)
As for the center bar top clamp, just a ram ball mount and power outlet for gps is all I need there.
bill1960 screwed with this post 08-23-2012 at 09:24 PM Reason: re thought idea
bill1960 is offline   Reply With Quote
Old 08-24-2012, 04:42 PM   #2209
SteveO
Huh???
SteveO's Avatar
Oddometer: 979
Ok boys and girls the chessy Valve job video should be up soon....
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 08-24-2012, 06:02 PM   #2210
SteveO
Huh???
SteveO's Avatar
Oddometer: 979
Cheese ball video
EDIT
re-edit; watch the video in full screen mode, you can see more of what is going on....
SteveO screwed with this post 08-27-2012 at 09:14 AM
Old 08-24-2012, 07:02 PM   #2211
team ftb
Befuddled Adventurer
Oddometer: 1,210
I did not have an opportunity to try the new 500 out. I knew that the difference between my '09 300 XC-W and my '12 300 XC-W were simply light years apart in handling and feel. My friend's '11 300 XC felt so much lighter (same weight), turned so much better and tracked so much more accurately that I bought the '12 XC-W without riding it. Fabulous bike! I assumed the new '13 500 would probably be similarly better than my '07 565 and, wow, it does not disappoint at all! It is a little lighter than the 565 but it feels like it is in between the 300 and the 565 for weight (until I dump it and have to pick it up). I have not tried it on anything like your tight, muddy jungle trails so I cannot comment on that.
Once I get the motor sorted out ("jetting" basically) I think this thing would pull right along with the 565 partly because it gets better traction than the 565. It hooks and flies. I put in a 1.4 lb. Shorai battery (about 3.5 lbs saving of weight up high) and the Akrapovic muffler (another 2 lbs up high) and put on the Sicass sub fender / rear flush turn signals and front hand guard turn signals for another 3 lbs. of high up weight. That helped as well. With the Euro map and the Sicass map switch set to "Mild" this is the best street motorcycle I have ever had. Very smooth everywhere with zero glitches. With the map on "Wild" you can be a street badass.
If you try to turn your 250 into a multi day ride you will hate yourself. I don't think it even has a counter balancer. I would take the 300 over the 250 for that sort of ride any time. Lighter and better power.
I just now ordered the JD Jetting 6X Tuner. I should have it on and test it next week. I will let you know how that goes.
Stu
FTB,
I would add that living with the new 500 is much, much easier than with the 565. Oil changes are much easier with the relocated drain and filter locations. There is now only one cartridge filter. It now holds 1.5 liters of oil so you really do not need a cooler. Valve checks are probably a 20 minute job from the look of it, once you get the smog crap out of the way.
My bike came without the two bolts for the SAS system. The drain plug and washer work for the exhaust side. Just Dremel off the magnet. The other one I found in my junk box. When you pull the spigot out of the intake just make certain that the bolt you put in is no longer than the spigot's threaded length since you don't want to push aluminum from the hole into the intake tract, if there is any there. A copper washer left over from one of your 570's valve cover bolts completes this. I also put teflon tape on the threads of this screw since I do not want leaks on the intake side.
If you have a cushioned hub just keep it and slide it on the 500. Used ones seem to go within minutes of being posted.
How will KTM top this? They probably will. Can't wait to see what they do.
Stu
Stu and i have exchanged PM's and emails for quite a bit now, discussing bits and bikes, and always seem to be attracted to the same bikes. Glad we don't live near each other or we'd be eyeing each others gals I'm sure. Stu your inputs are useful beyond belief in assisting potential buyers like myself that have no access to.the damn bike for riding. Again thank you for all the efforts you put into responses.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 08-25-2012, 05:51 AM   #2212
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 2,689
Steve0 - Masterfull piece of KTM porn. Well played .
And a dirty bike pix just cause.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 08-25-2012, 11:20 AM   #2213
EVELKNIEVEL
EVELKNIEVEL's Avatar
Oddometer: 49
Cool2 vote for pedro
Originally Posted by SteveO View Post
Cheese ball video
EDIT
I really need to get the text fixed so that one can really follow the vid
let me get it edited again......sorry for the delay
lookin good steveo this will save me time and money...i have the dvd shop manual but with this video im ready to skip the 3hr round trip to dealer...
PEACE
EVELKNIEVEL is offline   Reply With Quote
Old 08-25-2012, 02:56 PM   #2214
ejtv
anarchocapitalist
ejtv's Avatar
Oddometer: 964
From Giant Loop re attaching GL to 500EXC
I wrote Giant Loop about the difficulty of attaching securely GL products to the 500EXC's rear fender (hook does not fit). Here's his answer, for now:
"...I'm jealous - the new 500EXC is on my wish list!
On some bikes, making notches in the plastic with a Dremel tool enables the hook to fit. I'll run over to our local KTM shop and see if I can take some pictures of the fitment on the new machines.
We don't recommend running the strap under the fender - when the shock fully compresses it can hit the fender and the knobbies are going to damage the strap and/or bag. The tugger strap is probably an OK option, but we can do better . . . Let me see what I can find out.
It would be terrific if you can share the info in that thread, too . . . I'll get back to you ASAP.
Thanks for riding Giant Loop,
Harold"
I will keep you all posted. Thanks.
Government is the negation of liberty--Ludwig von Mises
Road Reports by ejtv click here
ejtv is offline   Reply With Quote
Old 08-25-2012, 03:29 PM   #2215
Lulu7404
Oddometer: 216
sicass bulb problem???
Has anyone else had a problem with using the halogen KTM replacement bulb? I went with the 40/45w bulb for more light. I have used it for several hours then friday morning i went out to start bike for commute and the headlight wouldn't work and the high beam indicator light wouldn't turn off, no matter what position the switch was in... had some time today to look and found this... once i got it all cleaned and separated, the bulb is fine and so are the contacts. Just the weather cover is not going to stop water anymore. Looking at it, should the bulb have been sticking out below the plastic base as far as it is??? Too close to rubber dust cover? Any ideas are appreciated, I don't usually ride it at night, just have to have light for street use.
12 KTM 500EXC
Lulu7404 is offline   Reply With Quote
Old 08-25-2012, 03:33 PM   #2216
Lulu7404
Oddometer: 216
and here's a dirty bike pic
12 KTM 500EXC
Old 08-26-2012, 08:39 AM   #2217
Geek
oot & aboot
Geek's Avatar
Oddometer: 25,763
Toddler: throw away that 1980's vhs recorder you have duct taped to your chin and go pick up a gopro or something you cheap bastard
www.motogeek.com
Old 08-26-2012, 02:07 PM   #2218
JonU
Oddometer: 38
Cheese ball video
EDIT
Just curious if you had managed to finish the editing for your video. I'm considering the KTM at the moment and it would be cool to see just how easy the valve check/adjustment is.
JonU is offline   Reply With Quote
Old 08-26-2012, 03:26 PM   #2219
shinysideup
Oddometer: 218
Help!
Hi, I love my EXC and the forum has been very helpful. Sadly I crashed pretty hard yesterday, and crushed the computer and broke some wires. There is a plug behind the headlight with two wires, a grey and a white. Can someone tell me what these used to go to? Or perhaps even send a pic? I would be grateful.
Thanks\
shinysideup is offline   Reply With Quote
Old 08-26-2012, 05:45 PM   #2220
oldx
oldx's Avatar
Oddometer: 1,045
Thanks\
The grey and white goes to 2 black wires that go to the shut off switch above the starter on mine.
oldx is offline   Reply With Quote
Times are GMT -7.   It's 11:10 PM.
