Old 08-29-2012, 12:29 AM   #2251
thedesertdalton
www.desertdaltons.nl
Oddometer: 19
Finished....now headed to the paintshop, it's gonna look like an angry bird...we head for Dakar in 30 days...
thedesertdalton is offline   Reply With Quote
Old 08-29-2012, 05:59 AM   #2252
teambft
teambft
teambft's Avatar
Oddometer: 1,204
SWEEET!!! Good luck!
11 KTM 300 XC-W,10 KTM 530 XCW Six Days, and more
teambft is online now   Reply With Quote
Old 08-29-2012, 09:25 AM   #2253
harcus
harcus's Avatar
Oddometer: 1,333
That is one beautiful aux tank.
Want Creative Adventure Products? - See Globetrottin.com
Current rides - '14 KTM 1190 R Adv <2k, '07 990Adv 39k, '12 500EXC 7k, '09 GasGas 300 Raga
harcus is offline   Reply With Quote
Old 08-29-2012, 10:53 AM   #2254
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,680
Looking forward to seeing the paint job!
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 08-29-2012, 11:12 AM   #2255
bill1960
Oddometer: 369
We keep it cool, fit's now with the 20ltr. acerbis tank, extra fan and Twin Air oil cooler..
Is it the one shown in the following link or a custom made oil pump cover.
http://shops.hookit.com/dominus/View...-KTM/7465.aspx
bill1960 is online now   Reply With Quote
Old 08-29-2012, 11:59 AM   #2256
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,404
Is that a Dirttricks computer fan kit mounted on the frontside of the radiator? Can't imagine that's going to last long...
jesusgatos is offline   Reply With Quote
Old 08-29-2012, 08:40 PM   #2257
SoilSampleDave
Oddometer: 2,143
I know this is the 500EXC thread, but I'm sure this group is the right knowledge base for my question. Does the 350XC-F have the same transmission ratios as the 350XCF-W and 350EXC? Thinking about plating an XC-F and wanted to now about the trans ratios. TIA.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 08-29-2012, 09:41 PM   #2258
Gryphon12
Gryphon12's Avatar
Oddometer: 1,345
I thought the "-W" meant wide-ratio. Hence, why would you assume that the ratios would be the same? I believe the answer is "of course not".
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 08-30-2012, 04:31 AM   #2259
thedesertdalton
Oddometer: 19
Hi Bill,
No, we made it together with Twin Air Netherlands, there's a guy who has a workshop at his house with CNC machinery, he makes the oil coolers and oil pump covers for Twin Air.
We found out this idea Twin Air found out with this oil cooler and contacted them, so we got in touch with this workshop, brought our spare engine and after a week of measuring the program for the cnc machinery was ready, the original brackets that hold the cooler on the radiator would also fit with the original tank from the 450 and 500 but as we installed the 20ltr. Acerbis tank we had to make new brackets so the cooler would move about 1 cm closer to the frame.
We found out that the 2012 450 and 500 engine do need different oil pump covers, the connection inside the engine is different, just by 1mm but it's different, also the original oil filter needs some mods buit it can be used.
Since we build our rally bike ourselfs we had to do allot of inventing, it turned out to be a good looking and well performing bike so far..
Old 08-30-2012, 04:50 AM   #2260
thedesertdalton
Oddometer: 19
Hi Jesus,
That's correct, it's the one from dirt tricks!
It's protected on the side with the big fuel tank and we mounted it as high as possible on the radiator, we turned everything around to make it work since this blower normally is mounted on the back of the radiator.
When riding, the air speed catches the fan and since we turned everything around it will rotate the same way as when the power is turned on so that couldnt do much damage, then there's rocks, dust, water etc.etc. we don't know if it will last but we will know soon...
We leave the power switch on and connected the fan to the original fan, also fused it, they will turn on at the same time, and since the turn singals are not on the bike anymore we connected a wire to the green control lamp so that we know when the fans are spinning, just a little indication that tells us something about the engine heat, an oil temperature gauge will be mounted also, we replace the oil drain plug by a sensor M12X1,5 and put a digital counter in the cockpit.
Old 08-30-2012, 04:56 AM   #2261
thedesertdalton
Oddometer: 19
Hi Harcus,
We will start selling the parts after we return.
Complete Faring
Rear 5L Tank
Skid plate with 1700cc water reservoir and big toolbox compartment.
So keep an eye on it!
Old 08-30-2012, 05:28 AM   #2262
SoilSampleDave
Oddometer: 2,143
In theory, yes. But KTM used to be notorious for mixing and matching stuff out of the parts bin and it didn't always follow the naming rules. I know the W's have softer engine mapping, open chamber forks, and softer suspension settings.
'08 530EXC
Old 08-30-2012, 05:50 AM   #2263
cross-country
cross-country's Avatar
Oddometer: 1,679
I was looking at this the other day, it looks like the xc-f and xcf-w have the same 6th gear ratio, different 1st gear ratio. I don't know about the rest.
cross-country is offline   Reply With Quote
Old 08-30-2012, 06:35 AM   #2264
ram350
Oddometer: 19
fan thermo switch
Just had my fan switch quit working and had to hard wire the fan to get out of the woods. I tried searching and can't find the info on a different switch that comes on at a lower temp that I know some guys have used. Anyone have a source or part #
ram350 is offline   Reply With Quote
Old 08-30-2012, 06:39 AM   #2265
bill1960
Oddometer: 369
Hi Bill,
Thedesertdalton
Great info, appreciate the detailed reply.
Times are GMT -7.   It's 01:57 PM.
