Old 09-11-2012, 10:22 AM   #2356
Hukamosh
Oddometer: 29
Originally Posted by jesusgatos View Post
Jeezus, that sounds violent. Can see how that might be fun and all, but not what I'm looking for in a trailbike. Guess that's the nice thing about being able to tune these bikes to suit different riders.
Just ride it like a 2-stroke and use the clutch .
My 500 isn't like that but it's stock except for the euro/xcw remap & desmog...I have no stumbles, flame outs etc and cost me $20 at the dealer. The bike runs richer/better across the range.
If anyone is interested I know of a 2012 500 exc being sold. Close to stock w/ 25 hrs or so. It may be in the classifieds here but not sure. Owner busted his knee and wont be able to ride for a while.
Hukamosh is offline   Reply With Quote
Old 09-11-2012, 10:25 AM   #2357
Zuber
Zoob
Zuber's Avatar
Oddometer: 986
Originally Posted by Stu View Post
I purchased a cushioned rear hub from Woody's Wheel Works. It is a RAD billet hub so it it both lighter and stronger than the LC4 equivalent. I will use it for extended travel that has a mix of hard road surfaces and off road (southern Utah coming up). Initially I had a problem with the hub which Chris at WWW took care of immediately with just a phone call and exact dimensions describing the issue. A big 1+ to Woody's WW!!
Stu
Hey Stu, have you ridden with the cush hub yet? Notice any difference on/off road, vibs, traction?
I built an LC4 cush wheel, but haven't mounted it yet. Hard to believe that the RAD hub would be lighter.
"Son, you can't do both"
Old 09-11-2012, 10:25 AM   #2358
teambft
teambft
teambft's Avatar
Oddometer: 945
Please PM me info on that 500 for sale. Got a friend searching. He found a stock one in Fla he might be buying.
2006 KTM 450 EXC, 2007 KTM 250 XC-F,
1996 CR500, 01 Aprilia Fut, 07 GasGas EC300
2012 KTM 500 EXC - sold, 950 SER-sold (regret)
Prior: BMW XC, TE610, KLR 650, 07 KTM 990 Adv, and many more ...BMWs, Ducs, KTMs, Harleys
teambft is online now   Reply With Quote
Old 09-11-2012, 11:03 AM   #2359
Hukamosh
Oddometer: 29
teambft-PM sent
Old 09-12-2012, 01:32 AM   #2360
LukasM
Oddometer: 4,912
I don't think the RAD hub is lighter than stock, might even be a bit heavier. And while it is probably stronger I have never heard about a single OEM cush hub breaking. Plenty of non-cush ones, but never a cush.
That being said, the billet hubs sure look good, and they don't cost much more than OEM. I personally prefer the Haan ones over the others as they are lighter with a lot more complex machining done while still being strong enough (plenty of Dakar rally guys run them).
Haan Wheels 640 carrier on the left (622 grams) and RAD Mfg 950/990 carrier on the right (930 grams):
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 09-12-2012, 04:27 AM   #2361
Stu
Buffo Maximus
Oddometer: 850
Cush Hub
Lukas,
Thanks for the info on the Haan hub. Did not know about it. I'm pretty happy with the RAD unit. I think it was built for bikes with a lot of power -- overbuilt if anything. I have not weighed the stock LC4 unit but it is very heavy and this unit does feel lighter. I have seen webs cracked on one LC4 hub. It may have just been a bad casting but seeing that was not encouraging so I went with the RAD.
I have not noticed any difference on or off road with the cushioned hub. The 500 has so much power that it is seemingly indifferent to what is mounted. What is important is that it will help make the 500 a worry free long distance bike. I will not have to be concerned about transmission needle bearings or counter shaft splines. I would note that on the highway at 45~65 MPH the 500 with the cushioned hub feels smoother than my 950. That is with the Kenda stock tires. It is not any easier to find neutral when stopped though.
The flame outs seem to be a rich condition. I am leaning out the "needle taper" jetting range (using carburetor terms) today to see if that will solve the problem. Cutting back on fuel in the "accelerator pump / leak jet" range helped. I had that set too high.
Stu
Stu is offline   Reply With Quote
Old 09-12-2012, 07:22 AM   #2362
ABYSS
KTM
Oddometer: 1,196
Couple thngs...
You have good points above but serviously, Are we that concerned about 300 grams, hell I can skip a dontu and get that back. Dpont get me wrong I have nothing against Haan but come on all this over 4300 grams. I have been a woodys customer for years and have runt he RAD setup on my SE as well as my 500 XCW. I never really new what I missed until I didnt have one. I personally can tell a substancial difference between having a cush hub installed and not and prefer having one. In regards ot weight I too beleive it is over built but for a very minimal weight gain. I like over built
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS screwed with this post 09-12-2012 at 07:42 AM
ABYSS is offline   Reply With Quote
Old 09-12-2012, 07:45 AM   #2363
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,774
Originally Posted by ABYSS View Post
You have godo points above but serviously, Are we that concerned about 300 grams, hell I can skip a dontu and get that back. Dpont get me wrong I have nothing against Haan but come on all this over 4300 grams. I have been a woodys customer for years and have runt he RAD setup on my SE as well as my 500 XCW. I never really new what I missed until I didnt have one. I personally can tell a substancial difference between having a cush hub installed and not and prefer having one. In regards ot weight I too beleive it is over built but for a very minimal weight gain. I like over built
Cush hubs........ considering the bike has a cush hub built into the clutch hub that does the same thing as a cush hub on the wheel hub,the extra expense/weight is really worth it to add on to the bike?
Do guys really use these things as street bikes?
Surely dont need it for dirt riding as the dirt is all the slip a bike needs. I guess the fancy hubs look neat though.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W.
Foot dragger is offline   Reply With Quote
Old 09-12-2012, 07:50 AM   #2364
Foot dragger
Oddometer: 6,774
Cush hubs are a streetbike thing,not a performance thing for off road in any way. Dirt lets the tire slip all it needs so the trans doesnt get hammered. They dont help shifting or make for less vibration. KTM went to great expense to put a cush hub in the clutch hub so a cush hub isnt needed out at the wheel.
But then,what do I know.
Old 09-12-2012, 07:57 AM   #2365
LukasM
Oddometer: 4,912
I agree that the weight difference between either hub is not a big deal, I just said if I can choose I'll take the Haan, even if I like and own RAD products.
Either way I do however consider the cush assembly - whether OEM, Haan, or RAD - a necessity for a dual sported bike that is seeing more than casual use. And the clutch damping mechanism is NOT sufficient.
Posted by another member, 11k dual sport use (XC4 engine with the same clutch damper):
Old 09-12-2012, 08:08 AM   #2366
ABYSS
KTM
Oddometer: 1,196
Sorry
footdrager but I think you are missing the mechanical aspect of these a bit. I dont care what something is purposed for if it has a functional purpose else where than that is all the better for the MFG and the people smart enough to take advantage of it.
The dampening of the clutch is for clutch to engine connection "One side fo the coin" BUT not for output to wheel they are two competely different anmials, location and stress points. Lukas put in a good pic here and there are hundreds more out there I am sure. People have learned from experience I guess you experienced this yet. I dont recall saying they add performance My reason is reducing wear/stress points and i can feel a difference after being with one for so long Not better just different.
Maybe = NO
Old 09-12-2012, 11:00 AM   #2367
Foot dragger
Oddometer: 6,774
That looks like the bolt holding the countershaft sprocket on was run loose. How else would it do that?If the sprocket is let run loose then it hammers the shaft,for sure.
The clutch is between the trans and the engine,the clutch cush hub wouldnt damp drive forces to the trans?
How have the many thousands of DRZ 400's got by with no cush hub at the wheel?
Im just wondering and am no expert on any of this,but Ive had many big bore dirt bikes with no cush hub with no problems.
Old 09-12-2012, 11:15 AM   #2368
LukasM
Oddometer: 4,912
Your theory does not quite work, if the bolt was left so loose as to allow lateral play on the shaft it would be pissing out so much oil that you'd need to fill it up 100 times in the 11k.
DRZ are slow turds compared to the KTMs, and maybe their shaft is more appropriately sized for their power.
Fact is that the EXCs and SXCs wear out the countershafts and often break the solid hubs (I have seen both OEM and billet Talon ones broken) if no cush drive is used in high traction applications where a lot of shock is transmitted. Obviously this is gradual so you need to rack up enough miles for this to be noticeable - which excludes most riders on these higher performance/maintenance machines.
Old 09-12-2012, 11:24 AM   #2369
HeadintheClouds
HeadintheClouds's Avatar
Oddometer: 18
single tracking with a pair of orange 2 strokes
http://www.youtube.com/watch?v=zvQwDohsj7k&feature=plcp
Great riding around West Carolina. Any other 500s in the area?
HeadintheClouds is offline   Reply With Quote
Old 09-12-2012, 11:55 AM   #2370
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,034
I've been riding my 450XCW almost exclusively on-road, with a set of 19/17 Woodys wheels (Rad front & OEM rear) and goddamn does that cush hub make a difference. Agree with you about performance off-road, but even when I've got dirt wheels on my bike, I do a lot of dualsport riding. You know, to and from trails, etc. Trailers are for boats! Anyway, have just found that the cush-hub really smoothes-out the power-transfer and helps a lot with settling the bike down, especially downshifting into corners. Picked up another OEM cush-hub to lace-up for my dirt wheelset. Heard that some of the aftermarket cush-hubs were having problems with the rubber bumpers not holding up very well.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is online now   Reply With Quote
Times are GMT -7.   It's 07:53 PM.
