Old 10-08-2012, 04:40 AM   #2536
AussieClay
AussieClay's Avatar
Oddometer: 59
Bullet Proof Designs
Originally Posted by LukasM View Post
Bullet Proof Designs, best radiator guards by a mile, I have them on 3 bikes. Swingarm and rear disc protectors are really good too.
http://bulletproofdesigns.com/
Some nice looking gear on the website. Thanks.
AussieClay is offline   Reply With Quote
Old 10-08-2012, 10:12 AM   #2537
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
i really like the orange headlight masks found on the 530s, the part #s seem to be different between those and the new 500s though.
does anyone know where to get an orange one for the 500 or if one from a 530 will work? I just don't see them changing much from the 530 to the 500.
EDIT: ok i see now...the different part numbers I was seeing were just the different color codes (duh! ) and the old masks are the same as the new white ones.
if anyone else was wondering the same, the part numbers are:
7800800100028 - white
7800800100030 - black
7800800100004 - orange
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad screwed with this post 10-08-2012 at 10:27 AM
Nomad is offline   Reply With Quote
Old 10-08-2012, 11:04 AM   #2538
EVELKNIEVEL
EVELKNIEVEL's Avatar
Oddometer: 49
kool video
http://www.youtube.com/watch?v=1fbDU...yer_detailpage
EFI Injector Cleaning
HAPPY LANDINGS
EVEL KNIEVEL
EVELKNIEVEL is offline   Reply With Quote
Old 10-08-2012, 05:33 PM   #2539
Jbay
Jbay's Avatar
Oddometer: 41
fuel line broke on new 500 exc, pin hole leak started spraying gasoline, got a boot full
thanks for the fix here, still this should be embarrassing for KTM for them to something proactive
luckily was only on a trail ride and had the 350 exc at the truck
Jbay is offline   Reply With Quote
Old 10-08-2012, 06:59 PM   #2540
Hueychief
FNG
Hueychief's Avatar
Oddometer: 77
I'm on my 3rd one with 2.8hrs on the bike, completely unacceptable considering where I will be taking this bike in the future. I made a new one from fuel-injector hose from my local auto parts store and have large looping bends in so as not to kink the hose. I will carry a spare with me.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 10-08-2012, 07:17 PM   #2541
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,212
So, after putting the Acerbis 5.3 gallon tank on, I've noticed that the bike gets up to the 220* temp much faster.
I've ordered a radiator fan kit and I'll get it installed on the left radiator
two fans running, with a switch to engage when I want them to engage. Having the TrailTech gauge lets me know the temp at any given time.....
I'll have a write up when i'm done.
edit: Arrggghhh, darned fan is way too big, can't fit it on the left side behind the radiator. Need to come up with something else.
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO screwed with this post 11-22-2013 at 11:59 AM
SteveO is offline   Reply With Quote
Old 10-08-2012, 10:53 PM   #2542
Bengt Phorks
Oddometer: 247
To stop the fuel line from kinking stick a 1/4 inch diameter spring inside the fuel line.
You can bend it as tight as you like.
http://www.mcmaster.com
9664K15 Spring STL Cut-to-Length Extension Spring 36.0" Length, .250" Outside Diameter, .028" Wire
Stainless Steel:
9665K39 Type 302SS Cut-to-Length Extension Spring 20.0" Length, .25" Outside Diameter, .028" Wire
While you are ordering:
pack of 100 Metric Buna-N Orings 2.4 mm width, 7.6 mm ID online at Mcmaster-Carr. Part number is 9262K217
They are the same size as the original one.
$5.62 + shipping.
You can get the fuel line there too.
54605K33 Low Pressure Sae Fuel Hose, 5/16" Id, 9/16" Od, 50 Psi, Black (250 psi burst pressure).
Clamps: 53175K26 Miniature Bolt Hose & Tube Clamp, 304 Ss, 31/64" To 35/64" Clamp Dia Range.
If you want OEM clamps:
52545K54 Gap-free Pinch Hose And Tube Clamp, 33/64" To 5/8" Clamp Dia Range, 9/32" Band Width
Bengt Phorks is offline   Reply With Quote
Old 10-11-2012, 09:12 PM   #2543
Wentjo
Wentjo's Avatar
Oddometer: 420
Clockwork Tank
Originally Posted by gmtcm View Post
I'm impressed! Where can I sign up for one?
gmtcm
Does anybody have the Clockwork KTM 3.1 gal tank? I was just curious how people are liking them. I just put one on my bike 2013 EXC.
Wentjo is offline   Reply With Quote
Old 10-12-2012, 06:40 AM   #2544
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,645
For this FF that could be the perfect size.
Anyone?
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 10-12-2012, 08:42 AM   #2545
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 143
I have the clockwork tank and have had it on for about 1000 miles and have had no issues. I went with the clockwork tank so I could still use my shrouds and graphics kits, I still get the range I wanted 160-170 mpt depending on terrain I can get into the 200 range with a couple primus bottles straped to bike with wolfman holders.
No Matter Where You Go, There You Are.
Stifdickerson2006 is offline   Reply With Quote
Old 10-12-2012, 09:18 AM   #2546
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
Originally Posted by Stifdickerson2006 View Post
what tires are those? i've been thinking about getting an extra set of wheels setup for sumo and just trying to get some opinions.
2012 KTM 500 EXC
www.motoex.net
Old 10-12-2012, 09:41 AM   #2547
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by SoilSampleDave View Post
I have a '13 on order; I didn't realize the rims weren't going to be black. Bummer, I much prefer the black rims.
I like the switch - after riding her good n' hard and a few tire changes, black rims don't look so nice.
modeselector is offline   Reply With Quote
Old 10-12-2012, 10:04 AM   #2548
Stifdickerson2006
Oddometer: 143
Those are the Shinko 705's, they work great on the road and very good offroad (firebreaks,gravel roads) I've actually done some hill climbs that I did not think I was gonna make, but wanted to see what the tires could do and they pulled me up. Of course steep down hills are another story but capable with both feet out and some tricky brake work. The tires suprised me offroad, of course you cant bang berms and stuff but they work well for summer riding the streets and national forest routes. and the price is great, under $150.00 for a set. We just got our first rain so the knobbies are gonna be on here as soon as I get my bike back
Old 10-12-2012, 10:29 AM   #2549
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,645
That's a sharp set up and perhaps the best tire combo for an extra set that I have seen. I have a pure street set on my extra wheels. Fun but not as dirt road friendly as yours.
Any custom holes in your fork protectors yet? My front is so wide I go without .
Stiff D - love the Jager stickers. Reminds me of this... ha
Not a big sticker guy (as you can see by my bike) so have never seen the Jager set - looks good!
Old 10-12-2012, 11:29 AM   #2550
Stifdickerson2006
Oddometer: 143
Thanks for the compliment.My fork protecotrs did not fit either the frt tire is a 120, I just marked and cut out a oblonged hole where the tire hit. And bought another set of protectors for the dirt set up. I usually use graphics kits,but I had never seen this Jaeger sticker kit before and had to buy it from a dealer in Great Britain as it was one of the best looking kits I had seen. The fit was not great and I had to do some stretching and trimming to make it fit rite but it came out good. The bike is so much faster and handles better with it too. Glad I got some pictures of the bike before I destroy them. I try to only use stickers of products I use and Jaeger is definitely a product I use.
That trike is out of control. makes me thirsty(TGIF).
I like the black plastics. Are you using the acerbis 3 gallon tank? what kind of range do you get per tank?
Times are GMT -7.   It's 01:06 PM.
