Old 10-16-2012, 05:09 PM   #2581
the_babaji
the_babaji's Avatar
Oddometer: 237
Originally Posted by harcus View Post
Correct - The 1.75 was a brain-o. Sorry.
No Problem, buddy over at the auto parts store gave me the 1.75 bolt for free anyways
Thanks for the great article, it was a big help!
the_babaji is offline   Reply With Quote
Old 10-16-2012, 05:12 PM   #2582
SteveO
Huh???
SteveO's Avatar
Oddometer: 979
Additionally...The fan switch is mounted in the lower tank of the RH radiator. It is a 95 deg C switch. All good if is works. Mine failed during tight single track so some of the water / coolant boiled out.............
So, 95*C is equal to 203*F.
Most dirt-bike fluid boils around 220* to 250*........ depending on conditions.......
Originally Posted by buelless View Post
The following info is taken from this link:
http://www.engineeringtoolbox.com/oi...on-d_1492.html
Temperature limits of some commons lubricating oils are indicated below:
OilTemperature Limits
oFoC
Mineral300149
Petroleum300149
Petroleum, superrefined350149
Perfluorinated compounds600316
Polyphenolether500260
Silicones500260
Synthetic esters400204
Synthetic hydrocarbon400204
I remember a rot (rule of thumb), don't know from where, that essentially said don't exceed 250F with petroleum oil and 320F with synthetics.
Hope this helps SteveO.
Well based on this info, it seems our engines should be well within the range of provided oil....I know I've hit 220*F before, and the bike still seemed to run fine.
I'm going to be installing a second fan that will integrate with the existing fan, and have both fans integrate with a switch. If I know i'll be getting into some tight technical areas, I can throw the switch and have the fans kick on keeping the engine cool through the rough stuff. Then, I can flip the switch back to normal, and the thermostat will take over duties as normal.
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 10-16-2012, 06:02 PM   #2583
harcus
harcus's Avatar
Oddometer: 1,155
A point to ponder...
Looking at the schematic in the shop manual for this beast, you will note that there is a "B21 Engine coolant temperature sensor" with the symbol that appears to be a variable resistance as read by the ECU. Most probably, this is an input to the ECU for use in fuel calculation from the fuel map. Just like the Manifold Air Pressure, Intake air temp sensor & Throttle position sensor.
It is POSSIBLE that this temp info is used as a safety to avoid engine over heating. I say possible because I think none of us know the software enough to confirm such. But, it is certainly a typical safety feature to include at no cost.
This info can be used to...
a. increase fuel input to cool the engine when a temp limit is exceeded
b. shut the engine down when passing a limit point
The point is, it is EXTREMELY possible that the system has a built in over temp safety mechanism that will react faster than any human to prevent damage.
Only the shadow knows...
Want Creative Adventure Products? - See Globetrottin.com
Current rides - 03 ST1300 72k, 07 990Adv 33k, 12 500EXC 5k
harcus is offline   Reply With Quote
Old 10-16-2012, 06:16 PM   #2584
SteveO
Huh???
SteveO's Avatar
Oddometer: 979
hmmmmm...... points to ponder........
Old 10-16-2012, 06:20 PM   #2585
DirtToTar
Oddometer: 18
Originally Posted by unaweep View Post
I had one on my 500 EXC. It lasted about 2 hours before it melted through and spilled fuel all over the motor. They are junk. Also, you have to splice the electrical wires on the tank- meaning you have spliced wires sloshing around in gasoline. Finally, the entire fuel pump installation is an abortion. All the o-rings on the fuel pump were damaged in the installation. It leaked from the bottom of the tank, at the fuel pump mount, from the minute it was installed
Here's the tank with two motor hours on it:
This is supposed to be the new and improved version of the tank, too.
I've heard a lot of people say they had good luck and a lot like me say they suck. I've purchased my last Clockwork product. $250 down the drain.
I will second the "JUNK" statement. Mine did not melt but may have if I had the nerve to start it with a slow stream of fuel leaking from the fuel pump mount. After about 15 hours trying this and trying that to get the pos to stop leaking I put the stock tank back on and carried some extra fuel on a rear rack. That will be my last tank from Clockwork.
DirtToTar is offline   Reply With Quote
Old 10-16-2012, 09:49 PM   #2586
avconnect
Oddometer: 71
Originally Posted by Atomic Wedgie View Post
First off, this is a sweet looking bike! Where did you get the ignition key eliminator? And I went on Sicass Racing's web page but couldn't find the top bar mount that raises the odometer up...where did you find that?
TIA
The key eliminator switch is from the KTM hard parts catalog. Looks like someone answered up or question about the top clamp. HighwayDirtBikes.
avconnect is offline   Reply With Quote
Old 10-16-2012, 10:55 PM   #2587
the_babaji
the_babaji's Avatar
Oddometer: 237
Is there an after market diagnostics/ scan tool for the 500, or the KTM's in general? For my Triumph, I have something called 'dealer tool'. It was not too expensive and was well worth the money.
Mine seems to idle quite fast, not sure if it is idling at the 1,850 rpm or not. It would be nice to see where it's set now.
Old 10-17-2012, 07:15 AM   #2588
Wentjo
Wentjo's Avatar
Oddometer: 179
I just put a clockwork tank on my bike, so far I'm not impressed. Didn't go together very good, think I might try the KTM tank instead.
Wentjo is offline   Reply With Quote
Old 10-17-2012, 07:44 AM   #2589
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 8,987
The Acerbis 3.2 tank is totally plug and play. 20 minutes to install. Like DirtToTar, I spent an incredible amount of time f'ing around trying to get that Clockwork POS to come together- around 10 hours total, and it still sucked. Shit, I can replace the entire top end in less than 10 hours. Infuriating does not adequately describe dealing with the Clockwork tank.
I compare the Clockwork tank to aftermarket parts we used to get in the 70's- nothing fit quite right, the instructions sucked, and it was just an inferior product on every level.
Also, many folks have stated they had good luck with dealing with Clockwork on warranty work. Not me. When one of their tanks leaks and catches on fire they are going to have a very serious liability problem on their hands.
unaweep is online now   Reply With Quote
Old 10-17-2012, 12:20 PM   #2590
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 523
SAS plug...the correct one!
Finally got the SAS port plugged. Definately a M12x1.5 thread.
Used a nice stainless Parker plug...
http://www.parker.com/portal/site/PA...D&vgnextfmt=EN
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 10-17-2012, 12:41 PM   #2591
FZcruzer
Oddometer: 85
Hello all,
Okay I know that the stock headlights on these are not optimal but I have a hard time believing that mine is working as it should. On low beam the small light (tiny) light bulb is on and when set to high beam the larger bulb is on.
When on low beam at night the beam does not even hit the ground and I need to put my hand in front of it to even tell it is on. When on high beam the light is not in any kind of beam and is scattered all over the place.
I have checked connections and looked to see if the light was way out of adjustment but no luck. Are they really this bad?
Rob,
FZcruzer is online now   Reply With Quote
Old 10-17-2012, 01:26 PM   #2592
KrustyKustom
Lets Go....
Oddometer: 523
3.4 gallons?
Originally Posted by Magile View Post
Part Number says 13 liter, anyone checked the capacity actually filling it up?
Krusty Kustom,
Houston Texas
2013 KTM 500exc
Old 10-17-2012, 03:07 PM   #2593
Saltydog86
village idiot
Saltydog86's Avatar
Oddometer: 831
Originally Posted by FZcruzer View Post
Hello all,
Rob,
Your low beam part of the bulb is just burned out, it happens on most of them. I like mine this way, no headlight unless I hit high beam. I dont ride at night ever, unless I am caught out late in the afternoon and the sun sets quicker then I thought I could get home.
12 KTM 350 EXC-F
09 KLR 650
12 Genuine Stella
05 Yamaha XT225
03 Honda Goldwing GL1800
Saltydog86 is offline   Reply With Quote
Old 10-17-2012, 04:19 PM   #2594
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 2,689
Ya know you can manually adjust the idle. It's just tucked up so far ya can't see it and you need chick hands to adjust it ,
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 10-17-2012, 05:39 PM   #2595
the_babaji
the_babaji's Avatar
Oddometer: 237
Yeah I know. Still it would be nice to know what the rpm is and to have some sort of diagnostics tool. Does Tuneecu do any of that or just load maps?
Times are GMT -7.   It's 08:35 AM.
