Old 10-29-2012, 09:41 AM   #2671
teambft
teambft
teambft's Avatar
Oddometer: 1,183
Originally Posted by WHYNOWTHEN View Post
I'm thinking about buying one of these fancy 500exc. Do any of you guys ride them, or are they just for tinkering? Is anybody using them on slow technical single track? Is it too much power for crawling around slowly?
Tinkering?? Heck yeah....ALWAYS tinkering
But seriously, this bike is amazing. I lucked out and found mine off the orig owner who had it spec'd out already....and for my weight (susp mods).
But its geared 14/50 and I have both the FI tuner and the switchable ign map. You can lower the hit using the switch - better for muddy/single track stuff.
I've run it on crazy two track and some really intense single track. Not to mention, here in Tenn., we see a ton of mud. I can hook up in the mud better than anyone. They will crawl as good as anything I've had. The last single track we ran was in
West Point, TN where they run some national enduros. I did wrestle with it a little in some of that stuff.....but that was primarily due to not having a damper. Seems the 500 will dance a little when running tight stuff with a lot of rocks and roots. But I popped on a damper last week and we rode some real gnarly stuff Saturday and the bike was amazing.
These rocks look a lot easier on the vid - not single track, but the bike tracked well over sections like this:
2011 KTM 300 XC-W, 2001 Aprilia Falco, 2010 KTM 530 XCW Six Days, others
2012 KTM 500 EXC - sold, 950 SER-sold (regret)
Prior: BMW XC, TE610, KLR 650, 07 KTM 990 Adv, and many more ...BMWs, Ducs, KTMs, Harleys
teambft is offline   Reply With Quote
Old 10-29-2012, 01:09 PM   #2672
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,276
Originally Posted by teambft View Post
Shame you dont have any pretty scenery where you live.!
Looks like great riding.
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is online now   Reply With Quote
Old 10-29-2012, 03:56 PM   #2673
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,602
Yea stunning stuff.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 10-29-2012, 06:53 PM   #2674
EVELKNIEVEL
EVELKNIEVEL's Avatar
Oddometer: 49
Cool2 chilly day
went riding today brrrrrrr the high was 70 in fl
got the dt1 filter kit fits great ..bike sounds great
i love this bike
happy landings
evel knievel
EVELKNIEVEL is offline   Reply With Quote
Old 10-29-2012, 06:57 PM   #2675
teambft
teambft
teambft's Avatar
Oddometer: 1,183
Where did you get that filter kit?
Old 10-29-2012, 09:21 PM   #2676
avconnect
Oddometer: 114
Originally Posted by hoss314 View Post
I keep blowing the fuse for the headlight in my '12.
Anybody else have the same problem?
Sent from my ADR6350 using Tapatalk 2
Seen it elsewhere in the report. Part of your bulb is bad and is shorting out. Replace it. I popped for the Baja Designs Squadron LED insert for my stock shroud. Expensive but worth every penny.
avconnect is offline   Reply With Quote
Old 10-30-2012, 03:29 AM   #2677
bill1960
Oddometer: 364
clutch noise ?
A few days ago I took delivery of my new 500 xcw.
The bike runs well. I've done the first oil change and at this stage the bike has 5 hours on it.
When I changed the oil, there was almost no steel filings on the magnetic drain plug, none on the gearbox oil screen, and a few flecks on the engine oil screen
Its my first KTM after running two DRZ's and an XR .
There's a clunking noise I'd like some opinions on. It seems to be coming from the clutch when the bike is idling, in neutral, clutch out.
If the revs are increased or the clutch is pulled in, the noise goes away. This noise was there from zero hours.
Idle is set correctly at around 1800rpm.
Is this normal ?
bill1960 is offline   Reply With Quote
Old 10-30-2012, 05:07 AM   #2678
hoss314
hoss314's Avatar
Oddometer: 135
Thanks....is the Squadron "plug and play" or are there modifications needed such as stator.
08' KTM 690 Enduro (Black Rally)
06' CRF450X Plated
hoss314 is offline   Reply With Quote
Old 10-30-2012, 06:09 AM   #2679
avconnect
Oddometer: 114
Plug and play. Plenty of power on board already. No need for a stator upgrade. It is not street legal but Baja Designs makes a dimmer switch that allows you to control the brightness and theoretically get around the street legal issue. The kit provides spacers that push the stock shroud forward to provide clearance for the backside of the light assembly. It actually helps solve clearance issues if you have a HDB setup.
Old 10-30-2012, 06:47 AM   #2680
LukasM
Oddometer: 5,418
Squadron is awesome, but IMO I would skip the BD dimmer with the clumsy remote and get a Skene or ADVmonster dimmer instead.
Old 10-30-2012, 08:46 AM   #2681
Lolodesiles
Lolodesiles's Avatar
Oddometer: 29
Is this normal ?
mine does it since early hours too, and most of my bikes too, it' s some "freeplay" on the clutch cage
don't worry about that and ride it ;)
Lolodesiles is offline   Reply With Quote
Old 10-30-2012, 06:12 PM   #2682
garrett
garrett's Avatar
Oddometer: 458
What's the clearance issue with the HDB setup?
Garrett
I like bikes...
garrett is offline   Reply With Quote
Old 10-30-2012, 06:26 PM   #2683
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 637
Put my squadron on the 500 today and a quick zip tonight to check it out. Wow! I was street riding and felt like I was doing something wrong (more than illegal!). Sweet color of light, and it only pulls 3.2 amps
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 10-30-2012, 08:15 PM   #2684
Bengt Phorks
Oddometer: 231
Take a look at these lights before you jump for the Squadron lights. http://stores.intuitwebsites.com/hst...012/Detail.bok . Plug and play. Dimmer too.
I have some on order. $170 plus shipping.
There is a thread in the vendors section that covers lighting.http://advrider.com/forums/showthrea...07184&page=188
Bengt Phorks is offline   Reply With Quote
Old 10-30-2012, 08:23 PM   #2685
Bengt Phorks
Oddometer: 231
Is this normal ?
At 180 hours it still makes the same clunking sound. It sounds worse with the stock muffler because the bike is so quiet.
Later on you will hear a ticking noise at idle. Its the decompression mechanism rattling.
Times are GMT -7.   It's 03:03 PM.
