10-30-2012, 08:23 PM
#2686 | |
Oddometer: 67
Later on you will hear a ticking noise at idle. Its the decompression mechanism rattling. |
10-31-2012, 12:17 AM
#2687 | |
High Speed Low Drag
Oddometer: 224
2012 KTM 500 EXC NON SEMPER ERIT AESTAS |
10-31-2012, 01:59 AM
#2688 |
Oddometer: 4,923
Sure, you can use any switch with it. But it doesn't have a high and low function, for that you need to buy a dimmer.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
10-31-2012, 06:14 AM
#2689 |
Oddometer: 73
The HDB top clamp plus the stock computer mounted in an HDB billett protector requires moving the headlight forward to make room. The Squadron comes with extenders to make space between the triple clamps and the backside of the shroud and headlight assembly. You will see elsewhere in this thread where people made their own extenders.
10-31-2012, 06:40 AM
#2690 | |
Huh???
Oddometer: 980
.................................................. .................................... NMOHVA.ORG - Help to keep your trails open! Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
10-31-2012, 07:21 AM
#2691 |
Oddometer: 52
What KTM parts supplier are you guys using for these bikes? I see a lot of the places don't even list the 500. Are most of the parts interchangeable with the 450?
10-31-2012, 07:46 AM
#2692 | |
(formerly GSNorCal)
Oddometer: 833
Dave
Rally Management Services is the source for Dakar-proven rally parts, bike builds, assistance, and training. Rally Navigator - Roadbook Navigation powered by Google Earth. Create. Print. Share. |
10-31-2012, 08:33 AM
#2693 | |
Oddometer: 336
Thanks Garrett
I like bikes... |
10-31-2012, 08:36 AM
#2694 | |
Oddometer: 336
I have the HDB setup on my 690, which I am moving over to the 500. I also have the TrailTech X2 that I am going to try and swap to the 500. With an HDB gauge protector mounted up high on the top clamp will the light still need to be shimmed forward? Garrett
I like bikes... |
10-31-2012, 09:17 AM
#2695 | |
Huh???
Oddometer: 980
Yup. The root of the problem is the TrailTech light. It's pretty deep, and interferes with the wires behind it. Being the cheapo that I am, I used an old Oil-pan, and cut sections to fit what I needed. Here is my current setup ![]() Here you can see just how deep the TrailTech backing plate is.... ![]() Unfortunately.....being the knot-head that I am, I can't seem to find any pictures at this time of my TrailTech upgrade and the extensions I made..... I would contact HDB about those little extensions...... I believe he even put up a picture of a prototype.....
10-31-2012, 10:58 AM
#2696 | |
Oddometer: 336
![]() Whats the other switch for? I like the ramball mount too. Great ideers. Garrett
I like bikes... |
10-31-2012, 11:12 AM
#2697 | |
Huh???
Oddometer: 980
The other switch is a ON-OFF-ON switch that interfaces with the kill-switch button. If the switch is not in the correct position, it opens up line to the kill-switch button; effectively creating a second kill switch button that would deter a thief who may be trying to start the bike......I know, simple and maybe silly, but dangit, if a thief wants to steal it, they are going to have to work for it. I'm also going to use the same switch to activate my second and primary cooling fan. After the bike is started, the switch can be moved to any position without killing the engine. The second position will be used to manually engage the primary cooling fan, and a second waterproof fan that I'll be mounting on the second radiator. With the larger Acerbis tank, air flow is somewhat reduced, and another fan would really help things out. The Ram ball mount is for my cell phone mount. I have used DualSportMaps in the past, and having a phone up front helps when taking milder rides. I have done single track with the Droid X2 and it has stayed in place. I have a larger Garmin 276C that sits in a custom mount further forward of the TrailTech display. This ensures that I can still see the screen when I'm standing and riding across the desert at high speed, and keeps my helmet from hitting the screen when going over some nasty bumps.... works pretty well..
10-31-2012, 05:28 PM
#2698 | |
Oddometer: 274
http://www.youtube.com/watch?feature...&v=CbXmYh3XMRs My 2013 500 xcw clutch is as loud from new as the 450 SXF in the vid. This 500 exc ? thread has been running for a while and no one seems bothered with any clutch noise. If mine is a problem, perhaps its something new with 13's, hence not many reports yet. |
10-31-2012, 06:30 PM
#2699 |
Oddometer: 237
By chance, the other day I noticed a difference in sound between clutch on clutch off. However it was not THAT pronounced!
Sent from my GT-I9000 using Tapatalk 2 |
11-01-2012, 07:08 AM
#2700 | |
Oddometer: 73
