11-01-2012, 07:22 AM
#2701 | |
Uses lotsa band-aids
Oddometer: 9,033
11-01-2012, 07:28 AM
#2702 | |
Huh???
Oddometer: 979
TrailTech mounting bracket extensions....
Yeah...I can definitely see the advantages of having an LED light as the primary light. But.....I already purchased the TrailTech, and since the money was already spent, well.....to keep peace in the marriage, I stuck with that. I've since picked up a couple of AdvMonsoter LED lights that will be going on each side of the TrailTech light for additional light at night. Finally located some of the correct pictures: My GPS and phone setup. The Actual GPS mount is a TourTech Heavy Duty mount. The bar that the Tourtech is mounted to is a custom fabrication that i slapped together. ![]() Here is a good shot of the TrailTech backside..... much larger than the stock light backside ![]() And here is my solution for little extensions, cut from an old plastic oil-pan ![]() ![]() ![]() Here is the bottom portion of the TrailTech mounting plate. I drilled a couple of holes in the fender and used this adjustable mounting plate to fine tune the angle of the headlight. Thus far, it has been solid, despite crash after crash...
.................................................. .................................... NMOHVA.ORG - Help to keep your trails open! Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO screwed with this post 11-03-2012 at 06:14 AM |
11-01-2012, 08:21 AM
#2703 |
Oddometer: 335
Thanks Steve. Thats quite the setup! Great info. I tried the TrailTech X2 on the 500 last night and it's a PITA. I'll probably stock up on bulbs and leave the stock light on for now.
That ram ball mount uses the top clamp bolt-where did you get the ballmount with a screwhole in the middle? Garrett
I like bikes... |
11-01-2012, 08:42 AM
#2704 | |
Huh???
Oddometer: 979
These are really nice little mounts that can be picked up for cheap from GPS City The picture is linked......
11-01-2012, 08:59 AM
#2705 |
King of all manfu
Oddometer: 2,689
Steve0 - that's some dash. Me, I try to keep it simple
![]() ![]() You running the TT in Eglin this weekend?
Guns keep society safe. Colemanfu screwed with this post 11-01-2012 at 09:04 AM |
11-01-2012, 09:39 AM
#2706 | |
Huh???
Oddometer: 979
Thanks. Since I ride solo most of the time, I like to have options. When on a multi-day ride, I'll mount up my Droid X2 phone so that I can send messages to my Spot Connect and keep in touch with Da-boss. This way she feels better knowing I'm doing ok. ![]() I often like to plan routes using the GPS, makes for a more adventures Adventure. Plus, having the GPS up front where I can see where while standing and riding across the desert fast is a plus. The above picture shows my first version of the mount. I've since made a mount that pushes the GPS further forward for better viewing when I'm standing or sitting. Having tunes on the road is really nice. The Scosche Ipod Remote is super cool! I tuck the Ipod into my shirt pocket and don't have to touch it at all to control it. Having some great tunes when your carving up some single track is really nice. ![]() And of course, you want to be sure you have juice for your electronics. The Low-Profile Powerlet Socket ensures that I'll always have juice for the cell phone, ipod or using an adapter any device that requires a 12 volt power socket... ![]() One thing the Military and the 1st Gulf War taught me....... Be prepared.... What's the "TT in Eglin"?
11-01-2012, 10:49 AM
#2707 |
King of all manfu
Oddometer: 2,689
My mistake Steve0
- I was thinking you were on far left of FL. Eglin AFB. There is a ride out there this weekend. I know there are a few 500's around that side of town and was thinking you were one of em. http://advrider.com/forums/showthread.php?t=821589
Guns keep society safe. |
11-01-2012, 03:12 PM
#2708 |
Oddometer: 5,050
11-01-2012, 04:57 PM
#2709 | |
Oddometer: 273
http://burnsmoto.com/deluxe-powerlet...ug-ppl-002.php |
11-01-2012, 05:42 PM
#2710 | |
Huh???
Oddometer: 979
yup, thats the one ![]() if you have this kind of socket, you definitely want to get an adapter too ![]() then you can use a 12v usb charger to repower ipods or phones or whatever
11-01-2012, 06:00 PM
#2711 |
Oddometer: 273
11-01-2012, 08:01 PM
#2712 |
Oddometer: 9,033
Anyone find a good spot on the bike to mount a coolant overflow tank?
11-01-2012, 09:30 PM
#2713 |
Oddometer: 273
HDB Top Clamp and Sicass XCW Key Switch ?
Will it fit ?
I note on the HDB website, they show a top clamp example with a hole for a keyed switch http://www.highwaydirtbikes.com/HDB_...KTM_Top_Clamps Will the Sicass XCW keyed switch fit in the HDB top clamp without hitting the Nexen Bars ? http://sicassracing.com/store/index....roducts_id=423 |
11-02-2012, 07:30 AM
#2714 | |
Oddometer: 9,033
11-02-2012, 07:49 AM
#2715 |
Oddometer: 52
Picked up my 500 last night
![]() re-geared to 14/48 and de-smogged. Can't wait to take her out for 1 hr. break in tonight! In the Blias kit is says to not remove end screen without adding JD Tuner as it will make the bike run too lean. Is this true? My screen was in the suit case and I don't get how it goes in the pipe. Does the end cap star looking deal unscrew? If so it's tight as a motherfu....!
