11-30-2012, 07:09 AM
#2881 | |
Oddometer: 336
Garrett
I like bikes... |
11-30-2012, 08:41 AM
#2882 | |
beat up ex flat tracker
Oddometer: 6,774
[QUOTE=avconnect;20148327]
They both bend,the plastic bends easily. Its physics. Disc gaurds are great for keeping brush out of the hub/disc area and they keep the disc from getting the air it should so brakes can run hotter if used hard. Ive never bent a disc yet in many years of trailriding but I know it happens.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
11-30-2012, 10:34 AM
#2883 | |
Unpronouncible
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,398
[QUOTE=Foot dragger;20149014]
I do not run a guard on the front as it is a hassle. I do run a rear fin guard as rear disks are very easy to bend without falling. |
12-01-2012, 09:38 AM
#2884 |
Zoob
Oddometer: 989
I've had branches get into the front caliper and push the brake pucks back. Then you have nothing. I run the Accerbis/KTM guard. Cheap, easy install.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
12-01-2012, 04:17 PM
#2885 |
High Speed Low Drag
Oddometer: 224
well long story short, my rear break line got snapped at the bend right before it bolts into the caliper. since I have to replace it anyway...can anyone recommend a good upgrade? i'm thinking somebody makes a braided line for these.
2012 KTM 500 EXC NON SEMPER ERIT AESTAS |
12-02-2012, 12:19 AM
#2886 | |
lost in the 690 mega
Oddometer: 318
12-02-2012, 02:50 AM
#2887 |
Oddometer: 274
Seat mod 500xcw
I ordered the seat concepts standard height/density foam and cover for my '13 500xcw.
Its a nice product but only 7 1/2" wide at the widest point, the same width as the oem seat pan. ![]() I liked it for short rides when standing most of the time but for joining trails with hwy stints of 50km + it wasn't comfortable enough for me Since I'm in Cambodia it wasn't viable to send it back so luckily the labor to modify it is cheap here. Browsing around I came across http://www.fishersaddlebags.com and decided I liked the design of their 9" wide seat using the OEM base and adding to the OEM foam ![]() So the next step was to wander down to the local motorbike upholsterers and see what they could do. Cant buy good quality foam here so we cut up the oem foam to add to the seat concepts foam Coming together ![]() They made a new (larger) cover from scratch and copied the lines of the seat concepts cover ![]() Stretched nice and tight and well secured ![]() Finished product ![]() Spot on 9" ![]() ![]() Cost was $15 for 3 hours labor and materials, plus a tip Very comfortable. |
12-02-2012, 04:40 PM
#2888 |
Oddometer: 134
Wonder what happened during your install?....just measured mine and it is at 8 1/2".
Hands down the best seat right out of the box. I have them on three of my bikes...a must have upgrade same as a stabalizer in my opinion. Sent from my ADR6350 using Tapatalk 2
08' KTM 690 Enduro (Black Rally) 06' CRF450X Plated |
12-02-2012, 05:36 PM
#2889 | |
Oddometer: 274
If so, I have to disagree. My last post shows it measuring 7 1/2" at its widest point. |
12-02-2012, 05:48 PM
#2890 |
oot & aboot
Oddometer: 25,818
I ordered a pre-built seat concepts last week.. I'll measure it and show a pic when it arrives for reference (the ready-to-go version they build).
www.motogeek.com |
12-02-2012, 06:12 PM
#2891 |
Oddometer: 183
I put my prebuilt seat on a month ago and love it, best thing I put on my bike by far.
12-02-2012, 06:16 PM
#2892 |
Huh???
Oddometer: 979
Powerlett and HDB
I may have posted this before....can't recall..... but, some folks asked for some more info on this setup, so I took some more pics to post up.....
I went with Powerlet due to their reliability and quality products for motorcycles. Here is a listing of what I've put on my KTM 500 EXC Low-Profile Powerlet Socket ![]() PowerLet Fuse Block Assembly ![]() Rigid Powerlet to Cigarette Socket Adapter ![]() Micro USB Short Powerlet Charging Cable ![]() Here is an image of the Fuse Block installed next to the Battery and next to the stock Fuse Block. This Fuse Block interfaces between the battery and the following: Hard-wired GPS Trickle Charger - That can double as a heater for a vest PowerLet Plug - mounted on the HDB bar AdvMonstor LED lights - To be setup ![]() ![]() ![]() Here are some more pics of the full setup ![]() ![]() ![]() ![]() Of course, you don't want to be in motion with you ipod charging...... ![]() As far as power drain, it's really a non-issue. Generally any USB device (iPod, cell phone) pulls 5V, which is nothing compared to the 200W the system pumps out. To get a rough estimate of your available power... 200 Watts divided by available voltage (12), allows for roughly 16.5 amps. 16.5amps is a lot of juice, plenty for any accessories you can slap on a dirt bike. Anyhow, this is the current setup....soon, I'll be adding the AdvMonster lights....should be awesome.....
.................................................. .................................... NMOHVA.ORG - Help to keep your trails open! Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
12-02-2012, 06:21 PM
#2893 |
Oddometer: 987
Sweet ride,will have to check out your bike if/when I can make it to another ride. I think I was on one of those where I saw that bike?
12-02-2012, 06:23 PM
#2894 |
Huh???
Oddometer: 979
I'd say both!
Although I don't see this incident as a precursor to him sitting in a garage with his car running, just to get a wiff of the fumes...... Although, I do see him getting a bike in the future......
12-02-2012, 06:25 PM
#2895 | |
Oddometer: 134
One of the best upgrades I have installed. A ....."Must Have" Just installed the BD Squadron headlight. Holy Shite that baby is bright! Looks like I am going to need to order the dimmer as well. Sent from my ADR6350 using Tapatalk 2
