12-04-2012, 06:31 PM
#2911 | |
Oddometer: 71
12-04-2012, 09:17 PM
#2912 | |
Oddometer: 67
The standard setting seems to have a more rounded power band snappy low end, a strong mid range and good top end. More throttle equals more speed. The wild setting shifts the power to the mid range and top end. Less low end torque and more top end power is the feeling I get from it. To change the map setting, flip the switch to the setting you want, kill the motor with the ignition switch,restart and the new setting will be active. The Euro manual says that the setting can also be changed by letting the engine go to idle. I keep meaning to try this but I am having so much fun that I forget I even have the switch. I end up leaving the bike in standard mode since it feels the most versatile. This bike will pull from idle to 10000 rpm. When I picked it up at the dealer he said "Watch out, it goes faster than you think it does." |
12-05-2012, 07:40 AM
#2913 | |
Oddometer: 334
Thanks for the pics and explanation. I've got the HDB setup on my 500, 2 other bikes too (love it). How did you re-route the front brake line so it's not over top the gauge protector? Does the low profile PowerLet socket come with wire to reach the fuse block assembly or did you splice between the fuse block and socket? I'm not experienced in electrical matter so if it ain't plug and play I'm sitting there staring at it thinking, "now what?". ![]() Thanks Garrett
I like bikes... |
12-05-2012, 10:00 AM
#2914 | |
Oddometer: 1
First problem is that the very sturdy powder coat on the rack makes the rack cylinders too big to fit into the frame cylinders. After much filing and sanding, I got the cylinders to "mate" but not perfectly. I installed Loctited bolts as tight as I dared. First rocky ride with a few tools on the rack and it worked itself loose enough to snap off the tab. The real problem with this model is the lack of a real 3rd mounting point. If you look at the other Nomadic models they all have some other bracket or tab that is several inches away from the other mounts, providing a sturdy mount. This model is essentially cantilevered from the two cylinders which aren't very secure to begin with. After the failure, emails to Justin Neimeyer of Nomadic got no response at all. It was after the 90 day warranty period (I had not got around to installing it for awhile after purchase) but you'd think there would at least be some response. As I mentioned, the rack seems well made, especially for the price, but the design on this particular model is crap. Bit the $billet$ and went w/Pro-Moto. Now that"s bullet-proof. |
12-05-2012, 10:17 AM
#2915 | |
Oddometer: 30
Great thanks for the info !
http://www.youtube.com/user/trav1sbickle?feature=guide |
12-05-2012, 12:40 PM
#2916 | |
Oddometer: 71
12-05-2012, 06:24 PM
#2917 |
Oddometer: 272
powerlet for gps ?
In the past I've used the gps hardwire cable to power my gps direct from the battery via inline fuse.
I'll be installing the HDB setup soon which will include a low profile powerlet socket in the top clamp. Rather than running the gps hardwire cable to the battery, I'm thinking of hardwiring the powerlet socket direct to the battery with inline fuse, then attach the low profile right angle powerlet plug to the end of the gps hardwire cable. That way I dont have a cable dangling around when the gps is not on the bike. The only other use for the powerlet will be stationary use such as tyre pump or usb phone charger. Question Will the right angle powerlet plug to powerlet socket be a secure enough connection to provide uninterrupted power to the gps when riding over rough terrain ? |
12-05-2012, 07:01 PM
#2918 |
Oddometer: 134
Just installed the BD dimmer switch for my Squadron. Works awesome! A plug and play set up...low beam is adjustable and uses the stock switch. Mounts on back side of headlight shroud.
Sent from my ADR6350 using Tapatalk 2
08' KTM 690 Enduro (Black Rally) 06' CRF450X Plated |
12-05-2012, 07:23 PM
#2919 | |
Oddometer: 334
Have you seen the cable hooking on the protector at all? Mine seems like it should be OK but it is at the end of it's travel. I've got a tall riser from HDB so I may have to order a shorter unit if it's problematic. Don't have my studs on yet so I haven't ridden the thing since I brought it home. :( Garrett
I like bikes... |
12-05-2012, 07:30 PM
#2920 |
Oddometer: 3
I installed the BD light with dimmer last night and went for a short ride. At full power it is absolutely incredible. Is it normal to have a 2-3 second delay when switching from full power to "low beam"?
12-05-2012, 07:34 PM
#2921 | |
Oddometer: 71
12-05-2012, 07:35 PM
#2922 |
Oddometer: 71
Can you post a picture or two? Has anyone used the SAR switch with the dimmer?
12-05-2012, 09:33 PM
#2923 | |
Oddometer: 237
Sent from my GT-I9000 using Tapatalk 2 |
12-06-2012, 09:59 AM
#2924 |
High Speed Low Drag
Oddometer: 224
anybody out there using the BD ignition switch? if so which way do you turn the key for power on? mine powers on when it turns to the left which is opposite the factory switch. did I do something wrong?
2012 KTM 500 EXC NON SEMPER ERIT AESTAS |
12-06-2012, 10:39 AM
#2925 | |
King of all manfu
Oddometer: 2,688
Guns keep society safe. |
