01-11-2013, 09:24 AM
#3121 |
Mama, I'm goin fast!
Oddometer: 10
I have the same iPhone case. It's pretty cool other than the proximity sensor not working worth a damn now! They're developing (developed) a holder for it but I don't think I would trust it to hold on a dirtbike.
Oh, just to keep the the post on topic... I have a 500EXC and I put the HDB handguards on...what's up with the clutch lever? Nothing fits! I can't rotate my clutch lever! Aaaahhh! Seriously, though, it's a problem. A problem that is solved completely with the sicass racing multi-switch.
I miss Hostess Donette's (TAPS playing softly in the background) |
01-11-2013, 10:17 AM
#3122 | |
High Speed Low Drag
Oddometer: 224
yeah! i was looking for that holder because i remember them posting pictures about it on kickstarter but i never could find it for sale anywhere. plus i think the only way to mount it would be on the bars and with cut down bars, i can't give up much real estate! i like the ram mount phone holder though, it seems like it's gonna be able to handle the abuse.
2012 KTM 500 EXC NON SEMPER ERIT AESTAS |
01-11-2013, 11:52 AM
#3123 |
Oddometer: 34
looks sick! I like the rim stickers. I wrapped my pipe too but used the black wrap.
45 acp; Turning human garbage into useful fertilizer since 1911 |
01-11-2013, 12:28 PM
#3124 | |
Oddometer: 67
http://www.slipgripcarmounts.com/ ![]() It does not look like much but holds very tight and releases easlily. heres a picture of the slim switch and mountain engineering lever. you can see there is still some room left over. I will put out another pic once I put on my LHRB.
No Matter Where You Go, There You Are. |
01-11-2013, 01:57 PM
#3125 |
Oddometer: 34
![]() ![]() pics with the wrap.
01-11-2013, 02:54 PM
#3126 |
High Speed Low Drag
Oddometer: 224
hey joby what did you use to secure the wrap and did you get the silicone spray too?
01-11-2013, 03:13 PM
#3127 |
Oddometer: 34
I just used tie wire like you would do on grips, and no i didn't use the sealer spray. I might still put it on before spring just not sure the pros and cons just yet. I think it will dry fine without but I wonder if the spray would help keep the dirt out, water in. just not sure:) more pondering in order. what you think?
01-11-2013, 04:15 PM
#3128 | |
Oddometer: 67
01-11-2013, 04:18 PM
#3129 | |
Oddometer: 34
01-11-2013, 05:15 PM
#3130 | |
High Speed Low Drag
Oddometer: 224
01-11-2013, 08:26 PM
#3131 | |
Oddometer: 5
But what happens when you ride with the light off?? I cant remember if the stocker stays on all the time or not, the BD light is off or full power, no high or low beam. |
01-11-2013, 09:48 PM
#3132 |
Zoob
Oddometer: 984
The stock EXC light is on always. Easy to turn off, just pull the brown ground plug off the bulb holder.
The XCW light is switched, so no reason you can't turn it off.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
01-13-2013, 09:19 AM
#3133 |
Oddometer: 975
Does anyone have the specs for the height and pull back (sweep) of the stock 2013 bars? I have given up up trying to mount traditional barkbusters to my go-to bars, shortened Pastrana FMX high. With the shortened bars, the hose from the clutch master cylinder is just too much in the way. God knows why KTM had to specify a straight run out of the reservoir. I am going to go with a HDB setup, and get some addition rise on the mounts so I can use the stock KTM bars. I need to pic up some height in the HDB mounts and I would like to compare the height difference between these two bars, because the Pastrana FMX in the 4th position is perfect.
More than twice as many Americans died in British concentration camps during the Revolutionary War as died in combat. Don't believe it? Google prison ship martyrs monument. 350EXC-F |
01-13-2013, 10:16 AM
#3134 | |
fishing with dynamite
Oddometer: 2,029
01-13-2013, 03:44 PM
#3135 |
ex-broadwayron
Oddometer: 527
The 500 EXC is my next choice for a bike (although I'm happy with my FE450- I'd like to have more oil capacity and a long-range tank). Been looking on craigslist... why are all the used EXC's on the west coast? Seriously, there are a lot out west, and none on the east coast. Is there a reason for that?
2010 520RR 1982 KE100 2010 Scrambler |
