Old 01-14-2013, 03:09 AM   #3136
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,288
Originally Posted by Nice_Rumble View Post
Winter on the East coast is not the time to sell an off-road machine.
Good point. I guess since I pay $150-$200 per bike (per month) to park mine, I have a different viewpoint. Obviously, I'm in the minority. (Man, the crap you need to put up with to live in NYC!)
2010 Beta 520RR
Baja crash Report
JustRon is offline   Reply With Quote
Old 01-14-2013, 08:28 AM   #3137
Cyberg
Cyberg's Avatar
Oddometer: 37
$150-$200 a month each!
MOVE...MOVE...MOVE
Cyberg is offline   Reply With Quote
Old 01-14-2013, 09:13 AM   #3138
J.Johnson
J.Johnson's Avatar
Oddometer: 85
Originally Posted by garrett View Post
I have a full set of LED signals on my EXC and yesterday wired up the rears. When I tried them the front signals worked properly but BOTH rear signals came on and blinked. Yes, I do have an LED flasher installed. I did some reading and noticed SteveO's post regarding the Trailtech instrument lights, so I removed the Dash turn signal indicator and the signals operate normally now. I'm not particularly a savvy electrical guy so maybe there's another way to fix the problem, however I took the easy way out.
Garrett
Here is a fast drawing on installing diodes into the two wires that run into the turn signal indicator. Run both wires into tier own diode. I used 3 amp radio shack diodes. Cost 1.75. Then connect both diodes to one side of the turn signal indicator lamp. Ground the other side of the lamp. The colors may not be the same on you bike. But you get the idea. The diode has a stripe on one side of it. That side goes towards the indicator lamp. ( I refer to the indicator lamp as the one at the dash. Hope this helps
Sent with mind control...
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 01-14-2013, 09:24 AM   #3139
djhartm
Oddometer: 9
Deccel Popping problems - cannot resolve!
I have a 2013 500 EXC & followed the desog instructions verbatim yet am still getting popping & backfiring on deccel. I have placed bolts in both openings & used high-temp RV sealant and Locktite. I have removed, inspected, and reinserted numerous times and still cannot get rid of that confounded popping! I've also had a competent mechanic friend double-check everything.
I do have the stock/mild/wild map switch installed (pops under all modes) and an FMF MegaBomb/RCT4.1 combo. Bike also stalls a lot in first gear despite moving the idle-adjust knob several clicks counter-clockwise.
I am pretty frustrated. :(
On a side note, I ordered the KTM billet check-valve for the gas cap, and noticed that it was missing during a ride yesterday. I am assuming that the tank pressurized during use & blew the valve off (the small hose was still connected). Since the valve only allows are to enter the tank, not exit, how would this not happen again? I don't believe there are any other vents on the tank to allow vapors to escape.
Help!!!
djhartm is offline   Reply With Quote
Old 01-14-2013, 09:27 AM   #3140
SoilSampleDave
Oddometer: 2,140
Help!!!
If you still have the stock ECU map in your bike, it will ignore the map switch; correct? Get the unrestricted "Euro" map installed by the dealer.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 01-14-2013, 09:28 AM   #3141
Capp
Resident
Oddometer: 88
You still running the stock map or did you have the ECU remapped? If not, get the XCW or the EU map loaded.
Help!!!
2013 KTM 350 EXC-F
Capp is offline   Reply With Quote
Old 01-14-2013, 09:49 AM   #3142
djhartm
Oddometer: 9
I am still running the stock US map.
I emailed my local dealer about getting the Euro map installed but never received a reply; guess I will have to call them.
Old 01-14-2013, 10:09 AM   #3143
Hueychief
FNG
Hueychief's Avatar
Oddometer: 77
djhartm,
My dealer isn't readily accessible so I installed the JD Tuner and problem with decel popping and stalling were solved. In the future, when the opportunity presents itself, I will have the ecu remapped and the JD Tuner should be redundant at that time.
My bike is also desmogged with the FMF pipe.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 01-14-2013, 10:14 AM   #3144
djhartm
Oddometer: 9
I thought about the JD Tuner but there seemed to be a dearth of info regarding its effectiveness. If my local dealer balks, I will go the JDT route.
Thanks.
Old 01-14-2013, 11:50 AM   #3145
Joby Rebel
Joby Rebel's Avatar
Oddometer: 35
Thanks.
I have the JD ttuner and it works awesome. No problems at all bike runs like a raped ape:) desmogged, stock exhaust:)
Better throttle response and it pulls all through RPM range now. And very easy to tune.
Joby Rebel is offline   Reply With Quote
Old 01-14-2013, 12:21 PM   #3146
The Wolf
Among The Living
Oddometer: 345
i have a 2013 xcw and it continues to pop. i did filter othe stock gas out and found bits of plastic(a lot). so i then i blew out the hoses and filter as well. the bike runs better but still pops on decel.
im in cali and CANT FIND ANYBODY TO GIVE ME THE EU MAP. does anybody on here have the EU map and a tuneecu cable? if somebody could just load the EU map onto tuneecu everybody could have access to the goddamn thing..
The Wolf is offline   Reply With Quote
Old 01-14-2013, 12:28 PM   #3147
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
I've got the stock US tune with a FMF pipe and TT map switch. ever since I installed the pipe, the bike is much easier to stall at low RPM with the switch set to stock. if the switch is on "wild" it helps but I like to run the stock tune a lot while in the woods.
would the EU map help with this?!
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 01-14-2013, 12:32 PM   #3148
The Wolf
Among The Living
Oddometer: 345
without the eu mp, that switch doesnt work, thus why its still stalls on the wild setting. the eu isnt necessarily "more power", its just unrestricted and puts the bike at the AFR and ignition timing the bike was designed to run at. with it unrestricted, youll have access to the three setting in the ecu.
Old 01-14-2013, 12:44 PM   #3149
djhartm
Oddometer: 9
I'm guessing the JD Tuner will not support the tri-map switch feature (stock/mild/wild); essentially it obviates the need I would think.
I wish the dealer told me I needed a different map to enable it, but they seemed kind of clueless about the whole thing.
The bike would be 100% awesome without the popping & stalling. OK, the headshake at speeds >70 is a bit unnerving as well. :)
Old 01-14-2013, 02:37 PM   #3150
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
well damn I could swear there is a difference in the low end between the stock and wild setting but if what you say is true then I guess it's all in my head.
the scotts damper works wonders! pick one up and you'll be able to run 90+ on the highway with one hand. head shake is a problem of the past with this thing.
2012 KTM 500 EXC
www.motoex.net
Times are GMT -7.   It's 02:04 PM.
