01-14-2013, 02:37 PM
#3151 | |
High Speed Low Drag
Oddometer: 228
the scotts damper works wonders! pick one up and you'll be able to run 90+ on the highway with one hand. head shake is a problem of the past with this thing.
2012 KTM 500 EXC NON SEMPER ERIT AESTAS |
01-14-2013, 07:06 PM
#3152 |
Oddometer: 1,013
I swear that I read this entire thread before finally buying my EXC. I truly regret not making notes on what information was hidden where. Some kind of an index would rock...how to do it? Anyway, I plan on using the power wire for the radiator fan to power my heated grips. Before I pull the tank to access the connector, I am trying to find out if it is some specialized multi wire connector or as simple as two spade connectors. Can someone please advise? I would like to order a specialty connector ahead of time if needed. TIA.
More than twice as many Americans died in British concentration camps during the Revolutionary War as died in combat. Don't believe it? Google prison ship martyrs monument. '13 350EXC-F |
01-14-2013, 07:47 PM
#3153 | |
Oddometer: 338
Garrett
I like bikes... |
01-14-2013, 08:19 PM
#3154 | |
Oddometer: 1,169
http://sicassracing.com/store/produc...h=105_35_2216& If they won't install the EU map, make them refund the money on the switch since they are stupid. The JD tuner works like all of the programmable tuner on the market by modifying the time that the injector is squirting fuel. It is a nice simple system that works. It is particularly nice because you can trail test the bike & if you feel that it might benefit from more fuel (or less) in a given rpm range, you just stop & push a few buttons & wa la, it is changed. Pretty much infinitely adjustable electronic jetting! It works!
Want Creative Adventure Products? - See Globetrottin.com Current rides - 03 ST1300 72k, 07 990Adv 33k, 12 500EXC 5k |
01-14-2013, 08:47 PM
#3155 |
Oddometer: 17
01-14-2013, 08:59 PM
#3156 | |
Oddometer: 29
There is a 2 circuit .093 molex connector for the power to the fan. I bought the molex connectors at a frys electronics store and made a y pigtail so the power comes into the y and leaves with 2 connectors. One connector supplies power to the fan and the other connector goes to the grip heaters. The power is only available when the key is on so you wont leave the grip heaters on accidentally. http://www.frys.com/product/1651278?...H:MAIN_RSLT_PG |
01-14-2013, 09:22 PM
#3157 |
Oddometer: 17
This thread needs ALOT more Pictures!
01-14-2013, 09:37 PM
#3158 | |
Oddometer: 1,013
01-15-2013, 04:20 AM
#3159 |
King of all manfu
Oddometer: 2,724
Bling!
![]() Stupid setting for the cam, but the other day when it was kind of nasty out I hit the bike with some of my Harley polish.
Guns keep society safe. |
01-15-2013, 05:38 AM
#3160 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
01-15-2013, 11:42 AM
#3161 |
High Speed Low Drag
Oddometer: 228
does anyone know for sure if the ECU has to be installed in the bike for the EU map to loaded? if not I'm looking to just send my ECU off to my dealer back home.
01-15-2013, 01:34 PM
#3162 | |
Oddometer: 74
No Matter Where You Go, There You Are. |
01-15-2013, 09:49 PM
#3163 | |
Oddometer: 77
Removing the ECU is described here: http://www.omraoffroad.com/forum/vie...11373&start=45 This a good primer for working on your bike even if he has a 350. 2012 KTM 350 EXC-F: Building the perfect "Wee Beasty" |
01-15-2013, 10:06 PM
#3164 | |
High Speed Low Drag
Oddometer: 228
01-16-2013, 05:10 AM
#3165 |
Oddometer: 76
Yep, Carson Motorsports knows what to do. Carsonktm.com
Stock exc ECU modules just get reflashed to EU spec. Then mapping switches work no problem and bike runs awesome. On 500 anyway.
13' KTM 500 exc 06' Suzuki DR 650 09' Genuine Blackjack 08' KTM 300 xcw |
