Old 02-07-2013, 04:07 PM   #3286
Dirty in all
Adrenaline Junkie
Dirty in all's Avatar
Oddometer: 168
Originally Posted by Vico1 View Post
I am not sure why, maybe I am not demanding enough, but I love my 5 hunny and I have had ZERO issues after desmog replacing 10M filter and installing JD turner. Starts perfectly, runs strong and very crisp. I came off a well set up 530 and there is no comparrison. This bike is wicked!
However, I live in Florida so super cold is not a problen nor is elevation nor for that matter water. I just do normal maintenance and ride the shit out of it...
If you are thinking about a 5hunny as your new ride you will not be disappointed. IMHO.
I agree 100%. Same exact set up but I did/do tweak the JD Tuner. I have mine mounted up on the frame close to the headlight so I can adjust it while riding. I deal with altitude from 0 - 500ft or so and temps from 10 - 95F. There's a small hiccup that shows its face once every few months so it does require a bump up or down, mostly in the mid range. Recently I put a supermoto setup on it and the bike is a screamer. I have an Aprilia SXV 550 that is also supermoto setup and sees alot of dirt roads and the occaisional trail. On the pavement I swear the EXC is faster and it does it with less violence, if youve been on an SXV then you know what I mean. The EXC surpases it hands down in all other areas. Ive been on WR250s, Husky 610s, DRZ 400s, KTM 690s and I wouldnt trade the EXC for any of them. In dirt trim is where the EXC really shines. The bike has made me a better rider in every way and the confidence it inspires for me is unmatched by any bike or time in my life with the bikes Ive owned and been on. I was getting a lot of flame outs in the begining when the bike was only desmogged and I found that just bumping the idle up a click at a time until it went away was good enough. Im also a very clutchy rider, I dont mind using it and Im very mindful of it so maybe thats part of my fix or lessened issue with it. Since the tuner Ive not had a flame out, the bike lugs in low rpm very well.
Dirty in all is offline   Reply With Quote
Old 02-08-2013, 06:32 AM   #3287
avconnect
Oddometer: 111
I have had zero issues and did not have to install a JD tuner or like device. I simply desmogged and re-mapped and the bike has absolutely no issues. Runs strong and snappy. Added an FMF 4.1 titanium exhaust system, including the PowerBomb header and that added a noticeable boost but was not necessary, just lots of fun and lightweight. No flame outs, no hesitation, no stalling. Just hard snappy acceleration. I did turn the idle up considerably, removed the filter at the throttle body and added a Golan filter plus a fuel sock in the tank.
avconnect is offline   Reply With Quote
Old 02-08-2013, 09:05 AM   #3288
djhartm
Oddometer: 9
EU map fixed the stalling & excessive p\backfiring for me.
djhartm is offline   Reply With Quote
Old 02-08-2013, 04:14 PM   #3289
AussieClay
AussieClay's Avatar
Oddometer: 59
Tps
Originally Posted by Bengt Phorks View Post
Go back about 10 pages in this thread to post 3091 and 1203 page 81.http://advrider.com/forums/showpost....postcount=1203
The Throttle Position Sensor TPS may be set wrong and causes the motor to flame out.
My bike will lug down to about 2 rpm and yours should too.
Already checked TPS and it's fine... also running tank sock and additional inline filter... replace injector filter routinely so I don't think there is any fuel issues.
AussieClay screwed with this post 02-08-2013 at 06:03 PM
AussieClay is offline   Reply With Quote
Old 02-08-2013, 04:16 PM   #3290
AussieClay
AussieClay's Avatar
Oddometer: 59
Originally Posted by Mudguts View Post
Sorry but you cant compair a mx bike to an enduro bike tha t has to meet emissions specs . Two different ball parks.
No kidding.... regardless of the type of bike, is it too much to expect no flame outs, backfiring etc. from a US$11K + bike? With all the emissions crap removed and the unrestricted maps installed it's 90% better but still not 100%.....
AussieClay screwed with this post 02-08-2013 at 05:07 PM
Old 02-09-2013, 06:59 PM   #3291
jtmajors
OCD with motorcycles
jtmajors's Avatar
Oddometer: 301
Anyone have an extra set of wheels they want to sell?
2012 triumph tiger 800xc, 2012 ktm 500 xcw plated, 2010 wr 250x (sold), 2009 Crf 450r (sold), 2007 Crf 250r (sold), 2006 Triumph Daytona 675 (sold), 2001 yz 125 (sold), 2000 yz 250 (sold), 1997 yzf 600 (sold), 1996 cr250r (sold), 1992 rm 125 (sold), 1988 Yamaha Virago (sold), 1986 XR 200 (sold), 1984 cr 80r (sold), 1982 xr 80 (sold)
jtmajors is offline   Reply With Quote
Old 02-09-2013, 09:36 PM   #3292
PatrickM
Oddometer: 363
For the stock exhaust, what's the proper way to remove the noise screen in the end of the exhaust? Does it screw off? Do you just drill it? Does the cap pop off (allowing you to pop it back on later)?
Went down to the San Francisco area and got into riding talk at a local shop... Boy, I am glad I don't have the asinine California rules on how/where to ride! But if I remove that noise restrictor/suppressors, is anyone in California (with a badge) going to notice? I understand the spark arrestor is further down so if they check, life should be fine there...
They were even like "Sorry, we can't even remap the ECUs for our customers due to CARB"
NFS, BLM, state parks and that doesn't even include the miles of dirt available here!
But I did get the 500EXC because it does open up the resale market if I ever do decide to sell.
"what do you mean I have to pay to ride my bike there..."
PatrickM is offline   Reply With Quote
Old 02-09-2013, 09:46 PM   #3293
avconnect
Oddometer: 111
The screen screws off.
Old 02-10-2013, 12:17 PM   #3294
Chris6_85
Chris6_85's Avatar
Oddometer: 300
I just installed a rekluse Exp. And installed the correct install gap according to the rubber band check. However when riding there was a lot of slipping in the clutch at higher speeds so I backed out the adjustment on the external adjustable slave cylinder to get rid of the slipping in the clutch. Now at idle the bike slightly creeps forward and the tolerance with the rubber and method is way off. It seems to run good and I don't mind the creeping. But is this normal? Any suggestions?
Chris6_85 is offline   Reply With Quote
Old 02-10-2013, 03:19 PM   #3295
SJktmRider
USMC Veteran
Oddometer: 13
with it set up to creep like you have it will it stall if you slam on the brakes? or if you stay still while its in gear will it stall?
I am about to get a rekluse exp as well. just curious if you have engine breaking at all
SJktmRider is offline   Reply With Quote
Old 02-10-2013, 04:01 PM   #3296
Chris6_85
Chris6_85's Avatar
Oddometer: 300
i did not stall the bike once. with about 25 miles of single track locking up the rear all the time and never stalled it. it just creeps a little. i can start the bike no problem in gear and it does not stall when i put it in gear. engine breaking is different, it will take me and you a little bit to get use to. i found just blip the throttle a little and it will kick in.
also i noticed on the highway 25-45mph with a steady hand on the throttle there was a ever so slight bit of lunging or something around that. i am trying to find the right word to describe what i am talking about. forward and back feeling.
it might do it at all speeds i dont know i that was just my range of speed on the road. how ever on the mile long drive way i can go from 0-80 all 6 gears and i dont feel nothing but the pull from the beastie 500
anyone with the rekluse have that?
Old 02-11-2013, 07:59 AM   #3297
SJktmRider
USMC Veteran
Oddometer: 13
Thanks man. 3 of the people I ride with have rekluses in their bikes. 250 xc, 250xcw and 350 exc.. I like it but knowing this about the 500 I'm sold. I have a 500 xcw and ride strictly single track.. Also race harescrambles so starts are crucial
Old 02-11-2013, 02:16 PM   #3298
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,597
Ya know I was thinking about it. I wanted a dirt bike but it came with the supermoto setup as well as a unused set of wheels and knobs.. Before this weekend, I hadn't had the little wheels on since September so was thinking about putting em up but..............
It's only a 30 min swap and so much more fun on the road (than with knobies) that I've decided to keep em.
I do need to program the spedo computer with the correct size front tire cause it's way off now. Not the best cause I know I going about 15 over. .As you can imagine the wheelies are amazing
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 02-11-2013, 06:53 PM   #3299
Chris6_85
Chris6_85's Avatar
Oddometer: 300
ya i just got off the phone with rekluse and the guy i talked to was great. told him my concern and he said there are 3 settings on the pressure plate. and mine was set to 2 which was where it was at for oem seetings. i will try that and see out it does to perfect this nice weapon.
Old 02-11-2013, 07:31 PM   #3300
SJktmRider
USMC Veteran
Oddometer: 13
Keep us posted
Times are GMT -7.   It's 09:42 AM.
