Old 03-13-2013, 09:27 AM   #3481
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
Originally Posted by Bungholio View Post
Do you really ride with your iPhone in that position?
yeah it rides right there if i'm commuting and need the gps. why not?
iPhone goes in a backpack pocket when i leave the blacktop though.
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 03-13-2013, 06:37 PM   #3482
bill1960
Oddometer: 365
Originally Posted by bill1960 View Post
Ok, 12mm should be enough if/when the need arises.
Re the switch clearances, I'll email Paul and see if he can confirm.
Paul from HDB reckons the keyed switch probably wont clear the BRP rubber submount, but he hasnt actually tried it yet.
We can see from Stiffy's post that the powerlet clears.
I assume he has the same low profile powerlet as me.
Following pic is my topclamp setup
The BD keyed switch protrudes ~38mm from the bottom of the top clamp, compared to 35mm for the powerlet.
The BD switch has a diameter of 26mm.
Cable from the BD switch goes straight down whereas the powerlet cable goes to the side.
To me, it looks like the depth (not diameter) of the BD switch could be the problem with clearing the BRP rubber submount.
Following pic of BRP rubber submount is off the net
Stiffdickerson, what do you reckon going by my pics ?
Can you tell me the measurement between the bottom of the top clamp and the top of the BRP front rubber mount ?
bill1960 is online now   Reply With Quote
Old 03-13-2013, 06:48 PM   #3483
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
I don't have the rubber mount (but the standard submount) and if it helps at all, I had to trim the outside of the BD switch to clear the submount. it was tight.
2012 KTM 500 EXC
www.motoex.net
Old 03-14-2013, 01:04 AM   #3484
bill1960
Oddometer: 365
The lower bar clamps of the BRP submount look quite narrow, so I don't think they'll be an issue going by the pics.
The front rubber mounts are the worry re clearance for the BD keyed switch
The angle of the pics make it a bit hard to tell. In the above pic you'd think even the powerlet wouldnt have clearance because of the front rubber mounts. However Stiff's powerlet setup seems to clear ok
Old 03-14-2013, 08:48 AM   #3485
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 141
I just put a higher bend bar on last night and took my mount assy apart and cleaned it. After having a closer look, the HDB top mount with the ignition switch is not going to work with the rubber mount set up. There is not enough room, if you want to move the ignition, and use one of Pauls(HDB) ignition switch brkts it will work but not with the stock ignition switch you would have to get the slimmer designed one from Sicass. I have the ignition brkt from HDB and looked into it last night on my bike and it is a no go unless I get the slimmer switch.
No Matter Where You Go, There You Are.
Stifdickerson2006 is offline   Reply With Quote
Old 03-14-2013, 01:28 PM   #3486
bill1960
Oddometer: 365
Thx for the info.
Is that the low profile powerlet fitted to your topclamp ?
How much clearance does that have in relation to the BRP rubber submount ?
Old 03-14-2013, 09:23 PM   #3487
Stifdickerson2006
Oddometer: 141
Thx for the info.
The low pro powerlet socket fits no problem and no clearence issues. You could use both holes for powerlets with no issues.
Old 03-14-2013, 10:54 PM   #3488
FZcruzer
Oddometer: 550
I don't get it, my bike eats the low beam in the headlight in about 10 miles of street. Have gone through the original bulb and two after markets, vibration, voltage spikes, don't know. Kind of sucks to need to buy a $400 squadron to have a reliable light.
FZcruzer is offline   Reply With Quote
Old 03-14-2013, 11:54 PM   #3489
bill1960
Oddometer: 365
Cushioning and Anti vibration
I recently did a 2200km dualsport ride on the 500, highway/offroad 50/50, between 300 and 500km per day.
I found by the end of each day my throttle hand was numb from vibration and both hands were a bit sore in places.
Wheels are balanced. Using pillowtop grips.
Thats why I'm interested in the BRP rubber submount, plus I can add a scotts stabiliser later.
Would be interested to hear from those using the BRP rubber submount.
How well does it work in reducing vibration and/or provide cushioning ?
Old 03-15-2013, 05:14 AM   #3490
SoilSampleDave
Oddometer: 2,047
Gearing
My 350EXC as stock had 14/45 gearing. I put a 13 on the front as a start, but I need to go up on the rear for the tight stuff. I am trying to stick with the stock length chain because my plan is to get a second set of wheels for street use and I don't want to have to swap chains as well. Just for fun, I tried a 52T rear with the axle adjuster blocks flipped to give me more forward adjustment, but the chain was way short. Seat of the pants estimate seems to me a 48T would would work. But, I would sure like to hear from someone who knows for sure before I drop any more cash. Yes, I bought a brand new 52T KTM stealth (Supersprox) sprocket just to see if it would fit, since the XC-W has 13/52 stock. No, I am not very smart
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is online now   Reply With Quote
Old 03-15-2013, 06:40 AM   #3491
Saltydog86
village idiot
Saltydog86's Avatar
Oddometer: 1,043
I run a 13/48 on a 350 and it works great. You will be happy with that combo.
12 KTM 350 EXC-F
09 KLR 650
12 Genuine Stella w/Cozy Sidecar
05 Yamaha XT225
03 Honda Goldwing GL1800
Saltydog86 is offline   Reply With Quote
Old 03-15-2013, 06:46 AM   #3492
SoilSampleDave
Oddometer: 2,047
Just to be clear, that is with the stock chain, right? Thanks!
'08 530EXC
Old 03-15-2013, 07:14 AM   #3493
Saltydog86
village idiot
Saltydog86's Avatar
Oddometer: 1,043
Yes, stock chain.
12 KTM 350 EXC-F
09 KLR 650
05 Yamaha XT225
Old 03-15-2013, 07:27 AM   #3494
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
interested in selling that 52T stealth?
2012 KTM 500 EXC
www.motoex.net
Old 03-15-2013, 08:26 AM   #3495
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,317
I have a 2012 500EXC with no lighting issues - however - a fellow rider has a 2013 450 xc-w (str legal) and he has the same problem. Burns out bulbs all the time? He is looking for answer also.
Anyone else know the answer or have the same problem.
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is offline   Reply With Quote
Times are GMT -7.   It's 10:17 PM.
