Old 03-21-2013, 08:55 PM   #3571
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 431
Not only is that a nice seat on that Ronin, but who makes the rear rack?
WRW9751 is offline   Reply With Quote
Old 03-21-2013, 08:57 PM   #3572
SoilSampleDave
Oddometer: 1,985
Not my bike, but that is the ProMoto Billet rack.
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is offline   Reply With Quote
Old 03-21-2013, 09:20 PM   #3573
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 431
Thanks! I'll be looking a one of those.
Old 03-22-2013, 04:22 AM   #3574
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,597
Here is a bit more info on that PMB rack - For me (a day tripper) the rack is perfect. http://advrider.com/forums/showthrea...3#post20392703 I run a little Dirtbikegear bag on the back.
And I finished up my headlight on/off project last night and am pleased wit the results - we'll see how it does with the vibes. Spliced directly into the brown wire on the back of the light. Pull on/push off.
Much like when my bulb died, when the light is off the high beam indicator lights up (no matter the position of the high/low beam switch) - not a big deal. Easy way to tell if your light is on or off.
Guns keep society safe.
Colemanfu screwed with this post 03-22-2013 at 04:28 AM
Colemanfu is offline   Reply With Quote
Old 03-22-2013, 08:37 AM   #3575
Bungholio
Bungholio's Avatar
Oddometer: 706
Originally Posted by fasteddie23 View Post
Is that hi/lo switch for your headlight? Where did u get it and how did you wire it up?[/QUOTE]
Where is that stock instrument display protector from? I checked the HDB site and didn't see it.
Bungholio is online now   Reply With Quote
Old 03-22-2013, 11:37 AM   #3576
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Originally Posted by Nomad View Post
hey ronin, what handle is that on the side there?
That is the KTM hard part rear grab handle. I've got that on the rear and a Kreiga enduro haul loop on the front. It's really nice to have something you can grab onto when you need to lift / drag the bike.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 03-22-2013, 12:58 PM   #3577
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
oh ok cool thanks, I'm gonna look into that. I usually just grab the little lip that the plastic makes but it doesn't seem all that sturdy.
the strap on the front is a big plus too. I had the tugger straps on the front and back of my last bike and loved them.
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 03-22-2013, 03:34 PM   #3578
Hueychief
FNG
Hueychief's Avatar
Oddometer: 77
Mounted some supermoto wheels on the KTM today. Ready for the snow to be gone.
All components are KTM hard parts, wheels are tubeless w/cush drive.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 03-22-2013, 03:57 PM   #3579
MJG2
Oddometer: 53
sicass rear under fender
I installed one on 13 500 exc -looks great
but on right side most forward area it doesnt come out and cover the area where wires run forward as much as stock
Anyone notice?
I have a small opening -I can seal it up
But I also notice in same area of the under fender two very small holes facing sideways on the underfender -what are they there for ?could you bolt something on
Anyone have same -look and advise
I'll try post up some pics
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
07 Ducati Multistrada 1100 S
MJG2 is offline   Reply With Quote
Old 03-22-2013, 04:29 PM   #3580
MJG2
Oddometer: 53
Anyone notice?
here you go
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
Old 03-22-2013, 08:13 PM   #3581
Hueychief
FNG
Hueychief's Avatar
Oddometer: 77
MJG2,
I checked mine and have the same. Not sure about the small holes.
Waterboarding Works
KTM 500EXC
Old 03-22-2013, 08:34 PM   #3582
fasteddie23
Oddometer: 41
I am just guessing. But the hi/low is most often used for heated grips
So what have folks done for heated grips? What kit did you buy and how did you wire it in?
fasteddie23 is offline   Reply With Quote
Old 03-22-2013, 09:16 PM   #3583
Unkgd
Oddometer: 345
Sicass fender
Originally Posted by Hueychief View Post
MJG2,
On mine - the two hole have a tye wrap running through them that holds the wiring harness in place.
As to the gap - I will have to take a look when I get home in two weeks and check.
Unkgd is offline   Reply With Quote
Old 03-22-2013, 09:22 PM   #3584
Unkgd
Oddometer: 345
Where is that stock instrument display protector from? I checked the HDB site and didn't see it.[/QUOTE]
That is an HDB 4 hole computer protector. Send Paul at HDB a picture of the unit and have him give you current pricing. Hopefully I should have one in black waiting for me when I get home
Old 03-23-2013, 10:18 AM   #3585
FZcruzer
Oddometer: 517
I have installed a squadron LED light and a smaller light/horn/signal switch. Thought I had it all set but have lost my tail light. Signals and break light work but tail light will not. Does anybody know where the tail light gets power from? The stock headlight/signal/horn switch had a grey wire spliced into a green/red hot lead. I think that might be the issue.
FZcruzer is offline   Reply With Quote
Times are GMT -7.   It's 09:55 AM.
