Old 03-29-2013, 07:10 AM   #3631
MJG2
Oddometer: 53
Tires 13 500 EXC
I have no time on my new 500 yet but been reading some on tires
it comes with Maxxis cross SI 7311 on front -but doesnt use the mate which would be the 7312 for the rear?
instead it uses Maxx enduro 7314 on rear
its mate would be the 7313 for the front
WHy you think they did not use the matched tires ?
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
07 Ducati Multistrada 1100 S
MJG2 is offline   Reply With Quote
Old 03-29-2013, 07:24 AM   #3632
E-Ticket2
E-Ticket
E-Ticket2's Avatar
Oddometer: 116
Originally Posted by Enduro Outlaw View Post
I can confirm this works. I set my tps to .640 at the closed position and can now chug at low rpm without worrying about stalling. You can chug then pin it. I also use the jd tuner at recommended settings. Super easy adjustment.. only took 5 minutes. I have alot more confidence in the bike as I can now stay off the clutch.
If it is that easy/straight-forward of cure or improvement in rideability ... why doesn't it just come that way?
Emissions reasons ....?
- ET
"... AYHIN ...."
Mine: '12 KTM 350 EXC-F; '99 Honda VFR 800i Interceptor
Wife: '08 KTM 250 XCF-W; '04 Honda CBR600 F4i
E-Ticket2 is offline   Reply With Quote
Old 03-29-2013, 07:28 AM   #3633
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Originally Posted by boostracer View Post
Just leave the screen out & screw the nut in, tight! You're then legal, let him do the stick test, as mentioned the spark arrestor's inside.
Thanks for the idea boostracer. I think I will safety wire the ring down to an endcap screw also though.Anyone make a nice little end snorkel that directs that heat flow down away from my right turn signal?
buls4evr is offline   Reply With Quote
Old 03-29-2013, 07:40 AM   #3634
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Does the "FI" trouble light still stay off after you change the TPS position?
Old 03-29-2013, 05:40 PM   #3635
Dirty in all
Adrenaline Junkie
Dirty in all's Avatar
Oddometer: 168
Loctite wtf !!!
lol so as you can see Im a little freaked out about loctite. I know Ive seen some posts about it but cant seem to refine the search function enough and Ive been reading for way too long in too many places to not find an answer yet, so here I am.
In the manual my loctite shop supplies should include -
loctite 243
loctite 2701
loctite 648
If I look at any stores or online I cant get the numbers to match so I have -
loctite 27010
loctite 24010
these are both gel type which is really nice to work with, stays where I want, easy to deal with in general.
I think I read that theres differences between whats listed and what I can get is because its European numbers vs. US numbers. Does anyone want to rehash the loctite info for me again please? What Im most interested in here is what to use on the sprocket bolts for the rear wheel, counter shaft sprocket, brake rotors and caliper bracket. I plan on doing alot of swapping this year from supermoto to off road set ups and really looking to do whats in my best interest on keeping it quick. What is also sending me for a loop is the coloring and I guess what got me thinking I might be using the wrong stuff. The rear sprocket bolts came with what appears to be green, the rotor and caliper bolts appear to be blue. The 20710 that I was using for the listed 2701 is red and the 24010 used in place of the 243 is blue. Have some green in the toolbox but it said for use after the fact?
On another note, while looking through the manual, on page 13 there is a picture of where to locate the shock absorber part number. They show a sensor bunged into the exhaust. Does anyone have this? Ive asked somewhere before how exactly the EFI on these bikes performs its duties and Ive ALWAYS seen exhaust sensors on EFI, but not on my EXC. Is the system just a glorified carb where its not really sensing and doing all the functions it could be? I recently put the FMF mega bomb and 4.1 system on along with the twin air power flow kit. Reset my JD tuner back to how it came (suggested settings, not stock settings) and the bike is a complete monster now. Every and any issue with flame out or stalling while chugging at little to no throttle input has been eradicated. I did set the idle setting on the tuner up a bit until the idle smoothed out. So what Im getting at is on my SXV if you do anything like exhaust etc... you need to map or tune it in some way. Is it critical on the EXC? I just don't want to run it and burn a valve or something or run it in a bad fueling situation. I have a dyno tune scheduled in a few weeks so Ill report back on what we find out as far as tuner settings and F/A ratios across the board but in the mean time Im just looking for some input on the EFI and how its doing its job.
Thanks for reading, thanks in advance for any help.
Dirty in all is offline   Reply With Quote
Old 03-29-2013, 07:47 PM   #3636
mnsnowhawk
mnsnowhawk's Avatar
Oddometer: 28
The efi system is really not the best system on our bikes. It is not a closed loop system and won't compensate for altitude. It does some for temp but if running in too cold of temps it will overfuel and get gas in the oil. This is what the guys getting snowbike kits are dealing with. Currently a few guys are testing out a dobeck controller that uses an o2 sensor and will constantly adjust afr . Making it a closed loop system. Nice system and not too expensive. Not sure when it is going to be sold. I will also be switching out between dirt and supermoto. I would also like to know what locktite guys are using.
mnsnowhawk is offline   Reply With Quote
Old 03-29-2013, 09:05 PM   #3637
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Originally Posted by bill1960 View Post
Yeah, the x bushing. Its advertised as lowering the rear up to 7/8"/22mm
I did install it but only got around 14mm 5/8"inch lower.
Did not know it was an open-loop FI system on these bikes.
jesusgatos is offline   Reply With Quote
Old 03-30-2013, 01:13 AM   #3638
team ftb
Befuddled Adventurer
Oddometer: 1,759
Installed the X bushing and also got the same. About 1/2" lower seat height where i sit. I'm guessing Synergy Seals are measuring the change at the rear of the seat for marketing reasons.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 03-30-2013, 08:24 AM   #3639
YAHBO
Grip and rip since 1983
YAHBO's Avatar
Oddometer: 805
Bars?
What are peeps running for handlebars? I bent the stockers and would like something with a little higher rise. Any hot tips?
I'm an asshole and I approve this message.
YAHBO is offline   Reply With Quote
Old 03-30-2013, 09:48 AM   #3640
Bengt Phorks
Oddometer: 252
Try moving the handlebars to the forward position before doing anything else. Ride the bike for at least a day to get used to it before you change to something different . It made a big difference for me on steep downhills.
Bengt Phorks is offline   Reply With Quote
Old 03-30-2013, 10:04 AM   #3641
SoilSampleDave
Oddometer: 2,075
What Bengt said, position 4 plus Pro Taper Pastrana Freestyle bend. Those are great tall bars.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is online now   Reply With Quote
Old 03-30-2013, 11:00 AM   #3642
Bengt Phorks
Oddometer: 252
The KTM efi does adjust for altitude, it has a Manifold Absolute Pressure Sensor.
The KTM repair manual electrical schematics shows that the EU EXC & the EXC Six Days have a Lambda (oxygen) sensor that the USA EXC / all XCW units don't.
The Emissions Requirements in Europe are much more strict than the USA, even worse than Kookoofornia.
This website has some info about problems with the Lambda sensor when modifying the exhaust.
http://www.magnumtuning.com/en/detai...0-exc-six-days
Quote from website advertisement;
If you want your 500 EXC Six Days to work better, no matter where you are, then you need to install our KTM Oxygen sensor simulator /is aimed to resolve O2 sensor related check engine light issues/. This Oxygen sensor harness is fully compatible with your Motorcycle and give you the opportunity to make it better. As an upgrade manufacturer we offer the best deals on the market. Full warranty coverage and tech support. If you want to add some instant engine power /because O2 sensor eliminator is supposed to cure O2 sensor related MIL, CEL error codes resulted by modified or aftermarket exhaust and headers/ to your custom project, check out the new KTM 500 EXC Six Days Oxygen sensor simulator /is aimed to resolve O2 sensor related check engine light issues/. Magnum has a full line of KTM upgrades for your Motorcycle. Enhance your HP /while sorting out of MIL, CEL trouble codes/ and fuel efficiency /after Oxygen Sensor MIL, CEL issues treated/ from now on. Specs are warranted by the producer. To produce better engine power /because O2 sensor eliminator is supposed to cure O2 sensor related MIL, CEL error codes resulted by modified or aftermarket exhaust and headers/ and HP /while sorting out of MIL, CEL trouble codes/ has never been an easy job, but the revolutionary KTM Bike O2 Sensor Simulator does this instantly...........
The KTM efi is set up for using the stock exhaust system and modifying it will change the A/F ratio. The factory efi is not adjustable. A JD tuner can modify the A/F ratio to fix a lean or rich problem.
Checking the spark plug will show if the engine is running lean or rich. A white color on the insulator = lean, Light tan = perfect, and black = rich.
Taking out the thermostat will give you the cold weather problems that you mentioned. Do snowmobiles have the same issues?
I use Grade C Loctite for everything.
http://www.woodcentral.com/woodworki...octite-grades/
Old 03-30-2013, 11:54 AM   #3643
Enduro Outlaw
Enduro Outlaw's Avatar
Oddometer: 27
- ET
Who knows.. All I know is i can chug in 2nd and pin it and it will not stall anymore. This is a must do mod. Set your TPS to .640 volts and lock it there.
Enduro Outlaw screwed with this post 03-30-2013 at 12:04 PM
Enduro Outlaw is offline   Reply With Quote
Old 03-30-2013, 11:55 AM   #3644
Enduro Outlaw
Oddometer: 27
Yes the FI lamp will stay off. I am not getting any FI codes at all only a bike that will go from almost stall speed to full throttle without stalling. Feels stronger all the way up the power curve.
Old 03-30-2013, 11:59 AM   #3645
Dirty in all
Adrenaline Junkie
Oddometer: 168
I saw the intake sensor but wasn't sure if was actually doing anything so I still have no comment about it. Would like to think Im not just running a map with constant values but I don't know.
I mentioned to the guy thats going to be doing my dyno tune that the pipe was really coated in black which was pushing me towards thinking I was running rich. He went on to tell me that it used to be the case where you could pretty much tell what was going on by looking at the plug and exhaust colors but in his experience with the new dyno and sensing equipment its not always the case. He's stopped trying to "read" colors because he was finding it to be wrong much too much of the time.
I appreciate the loctite link but Im really looking for product numbers. I soiled my mind with too much research and Im almost positive Ive read that the coloring can vary with many things. Using blue in one part of the world can change in another or even change with manufacturing requests, like if KTM wants their 2701 to be green, loctite will accommodate that, kind of throws any "I use this color for this" theory out the window for me anyways. Going with a little trial and error for now. I put the blue 24010 on the rotor bolts and Ill be watching that closely. I found that on some of the bolts where I used 27010, red, it was just too much effort to get it apart. I even broke the head off of one bolt that I slotted the remaining stud and used a torch to remove. Wrong or right I really don't want to bust the torch out anymore.
Times are GMT -7.   It's 05:22 AM.
