Old 04-08-2013, 03:27 PM   #3751
YAHBO
Grip and rip since 1983
YAHBO's Avatar
Oddometer: 804
Prepare to overheat your credit card.
Right off the bat i need a skid plate. Anybody have any recommendations? I was looking for a hard plastic (i don't like the look of the metal ones). Anyone have the acerbis?[/QUOTE]
http://www.slavensracing.com/
I'm an asshole and I approve this message.
YAHBO is offline   Reply With Quote
Old 04-08-2013, 04:00 PM   #3752
ngads
Oddometer: 40
skid plate
thanks for the links
ngads is offline   Reply With Quote
Old 04-08-2013, 04:19 PM   #3753
Lulu7404
Oddometer: 278
aren't the little wheels cute!
Well I got the flat they were delivered with fixed and got them on again. Couple of laps around the neighborhood and ready for the commute. And maybe a private member day at the local track. Downside is in my haste to mount the sickass flush mount rear blinkers to their subfender, I cut one of the wires going to the tail light, so I had to put the crap original subfender back on until I can get the sickass subfender wires fixed.
Also got my Double Take mirrors today, but hadn't put them on for the pic.
14 Triumph Tiger 800
13 KTM 350XCF-W -- new hotness
13 KTM 250XCF-W -- hers
Lulu7404 is offline   Reply With Quote
Old 04-08-2013, 04:27 PM   #3754
Lulu7404
Oddometer: 278
computer code
ps, anyone running 17's tell me the wheel size code for the 17" rims. My manual only shows 2205 for 21" front.
Old 04-08-2013, 05:37 PM   #3755
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
Best is to mark the tire, push it two or three turns, mark it and measure.
"Son, you can't do both"
Old 04-08-2013, 07:24 PM   #3756
Bengt Phorks
Oddometer: 231
Originally Posted by SoilSampleDave View Post
I have the KTM Hardparts quick release plastic one and am very happy with it.
+2 for the skidplate . Easy on and off and protects well.
Bengt Phorks is offline   Reply With Quote
Old 04-08-2013, 11:38 PM   #3757
fasteddie23
Oddometer: 41
Wiring diagram for heated grips & powerlet
I am eagerly awaiting my HDB handguard and topclamp setup. I have ordered a powerlet socket and switch for heated grips in the clamp and will also relocate my ignition to there as well.
In anticipation of installing both can anyone tell me how they did this? Did you just go back to the battery? Did you tap into a switched wire? Did you install fuses?
Sorry I can do electrical work if I have a clear step by step but dont know where to start from scratch. Any assistance appreciated!
Thanks.
fasteddie23 is offline   Reply With Quote
Old 04-09-2013, 02:30 AM   #3758
ossa
Oddometer: 17
Generally it's considered a good idea to go straight off the battery. Be sure to used an automotive style fuse and have it physically close to the battery. The fuse protects you from over loading the circuit with too much current. This can be caused by two conditions: 1.) Excessive load from whatever you connect. 2.) The wire chafes through say due to rubbing, and a short is created. Without a fuse, either could lead to a fire condition. Also, if the fuse is too far from the battery, the short could be between the fuse and the battery and you could still have a fire.
You need to be careful of the draw you put on the charging system. If you exceed the available output of the stator, you'll be drawing down the battery as you ride, until dead. You'll need to calculate the load on your stator from your lighting setup, subtract that from the output (watts) of the stator. This is what's available for your accessory socket.
You also need to decide on a fuse size and wire gauge. Obviously, you'll want both to handle a bit more than your anticipated load on the socket. The fuse size and wire gauge should be correlated. Here's a nice chart to help you select:
http://www.offroaders.com/tech/12-volt-wiring-gauge-chart.htm
Your devices you put on your socket may have power or current (at 12 volts) specified for your calculations.
Volts (12) x Amps (current) = Watts (power)
Hope this helps.
ossa screwed with this post 04-09-2013 at 02:44 AM
ossa is offline   Reply With Quote
Old 04-09-2013, 09:32 AM   #3759
surferbum
surferbum's Avatar
Oddometer: 383
Question Your setup is looking great. Are you doing anything for subframe support?
Originally Posted by tricepilot View Post
Picked up my 2013 KTM 500 EXC from TJ's Cycle in Austin, and began the prep for a Tecate to Cabo run in September.
Pro Moto Billet Rack
Giant Loop Mojavi Bag
2014 KTM690 Enduro R; 2010 R1200GS & 2007 Versys sold
BT2012 ICT 2012 nOObs DV
BT2011.2 - This time only 1 NF ... BT2011 - Big Trip 2011 15 Days of Ridin' ...
BT2010 - Big Trip 2010 13 days and ...
My Spot WhereAmIriding
surferbum is offline   Reply With Quote
Old 04-10-2013, 02:47 AM   #3760
yzedf
Oddometer: 84
Originally Posted by buls4evr View Post
...make the FAN work once in a while with an on/off switch. I guess in 2012 they never shut off in hot weather, but my 2013 never TURNS ON so they went the other way with the sensor I guess.Sicass just has a switch so you decide....good. I would rather do this myself.
My bike brand new fan didn't come on. Bad sensor. Dealer installed new one before delivery. Fan does work just fine now. Think I'm going to ditch the thermostat setup.
Chris
2013 KTM 500 EXC
yzedf is offline   Reply With Quote
Old 04-10-2013, 04:39 AM   #3761
MJG2
Oddometer: 53
air temp sensor
Had air filter out of 13 - 500 exc other day and was looking forward into air boot
on top of the duct that runs to the throttle plate is a hole with a sensor coming in -I think its air temp sensor for the FI
It comes in at a hard angle- its not sticking down straight- I thought it looked bent to the side
Then looking out outside of duct/boot- you see it bolts on an angle
so I think thats just how it is
Next time you have airfilter out- look forward at little white sensor top inside duct -is your on a hard angle ?
13 KTM 500 EXC
09 KTM 250 SX
05 KTM 300 EXC
09 Kawasaki KLX250S
07 Ducati Multistrada 1100 S
MJG2 is offline   Reply With Quote
Old 04-10-2013, 07:28 AM   #3762
yzedf
Oddometer: 84
http://partsfinder.onlinemicrofiche....-THROTTLE-BODY
Which part are you looking at?
Chris
2013 KTM 500 EXC
Old 04-10-2013, 08:47 AM   #3763
Idle
Oddometer: 719
2226 mm new Avon rain front. 120/70-17
Idle is offline   Reply With Quote
Old 04-10-2013, 11:17 AM   #3764
oldx
oldx's Avatar
Oddometer: 1,094
Best source for 17" wheels for 2012 500 KTM? Should I consider buying used?
oldx is offline   Reply With Quote
Old 04-10-2013, 11:24 AM   #3765
tricepilot
El Gran Payaso
tricepilot's Avatar
Oddometer: 8,687
Yes - by testing the subframe on Tim Morton's Baja Bound Tecate to Cabo ride in September
To give you a serious answer - no
tricepilot is offline   Reply With Quote
Times are GMT -7.   It's 06:17 PM.
