Old 07-25-2013, 06:07 AM   #4306
Upsandowns
Oddometer: 24
Oil Changes on 500EXC
Many thanks to Trailjammer, Colemanfu and the others for the advice on oil changes during my forthcoming trip to the Rockies. As suggested by several of you, I think I'll focus on keeping the oil level in check while also keeping a close eye on the hours and miles, not to mention the work I ask the bike to do, and will try to get thru the 700 - 800 miles I anticipate without a complete oil change. I've just finished mapping a number of daily routes on BaseCamp and it looks like none of them will exceed 85 miles, so even if we ride 7 full days, mileage ought to total less than 600 miles and none of them will be ridden under "race" conditions ! After breaking my leg in the hills above Almont last year on my BMW GSA, survival is a primary objective !!! Thanks, again
Upsandowns is offline   Reply With Quote
Old 07-26-2013, 08:45 AM   #4307
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,317
Originally Posted by harcus View Post
The keyed switch on an EXC actually controls the "power relay". Folow the wires from the switch back to find that relay. It is on the top triple clamp. Probe the wires with a DVM to find the switched wire that you can pick power from.
The switched power should be yelo-red. The white-red wire is unswitched from the battery via a fuse block at the starter relay.
Check it out. Always good to protect the new wire with a fuse or circuit breaker.
Thanks - just the info I was looking for. I have it direct wired with fuse but would rather it be keyed...and fused...
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is offline   Reply With Quote
Old 07-26-2013, 08:57 AM   #4308
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,249
I installed one of these to give me more options down the road. No cutting into the OEM wiring harness. You have your choice of switched or always on protected by a fuse. Plenty of room in the air box next to the battery.
http://www.easternbeaver.com/Main/Wi...3_circuit.html
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 07-26-2013, 09:12 AM   #4309
HeadinSouth
vroom!
HeadinSouth's Avatar
Oddometer: 96
Quick question...
Ive had my 500 for about 3 weeks now and am having a problem with my chain wearing on my upper chain guide. It is from the chain moving side to side and wearing the inside of the guard. (Dangit I shoulda taken a pic)
I figure its due to my chain being too loose and have adjusted it several times.
Any tips to setting it up?
Also it likely started to happen after I put on my 14T front. I am running the stock 45 rear.
Thanks in advance.
HeadinSouth is offline   Reply With Quote
Old 07-26-2013, 11:52 AM   #4310
Bengt Phorks
Oddometer: 241
Originally Posted by Vico1 View Post
Can anyone direct me to where I can hook up switched power to my GPS?
I have no manual or wiring diagram...
According to the EXC wiring diagram you can get switched or unswitched power from the GT/6 plug behind the headlight. Follow the wires from the ignition switch to find it.
The GT/6 plug has 5 wires going into it and the other end is sealed off. The wires for power are the white/orange for switched and the red for unswitched. The other 3 wires are connected together under the shrink tubing. If you get some connector pins then you can modify the existing connector or else just splice into the wires.
Refer to these posts in this thread for pictures, wiring diagrams, and where to get connectors.
http://advrider.com/forums/showpost....postcount=2630
The GT/6 plug is shown in 2 pages of the wiring diagram but there is only one plug.
http://www.advrider.com/forums/showp...postcount=4274
The power relay is by the battery on the right side of the bike. Don't ask me why I know this.
Bengt Phorks is offline   Reply With Quote
Old 07-27-2013, 07:48 AM   #4311
HeadinSouth
vroom!
Oddometer: 96
Originally Posted by HeadinSouth View Post
Quick question...
Thanks in advance.
Old 07-27-2013, 11:48 AM   #4312
vintageveloce
Oddometer: 72
Check your sprocket alignment. BUT... the XCF-W doesn't even come with this guard. And the guard doesn't fit with a TM design works lower chain guide. So I just took mine off.
Carl
Quick question...
Thanks in advance.
vintageveloce is offline   Reply With Quote
Old 07-27-2013, 01:57 PM   #4313
SoilSampleDave
Oddometer: 2,047
Quick question...
Thanks in advance.
How old is the chain? The side to side play goes up a lot as it wears. The OEM chain on my DRZ stretched side to side like a rubber band after a few thousand miles.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 07-27-2013, 02:11 PM   #4314
ecarnell
ecarnell's Avatar
Oddometer: 394
Deposit down on a 2014 500 EXC!
Time to drink the orange kool-aid.....
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell is offline   Reply With Quote
Old 07-27-2013, 03:58 PM   #4315
DiVango
DiVango's Avatar
Oddometer: 54
You won't regret it! My favorite bike for sure... perma grin ;-)
Sent from my SCH-I605 using Tapatalk 2
'13 Tiger 800XC
'03 KDX 220
'13 Can Am Maverick
"There is no traffic Jam on the Extra Mile" Zig Ziglar
DiVango is offline   Reply With Quote
Old 07-27-2013, 05:00 PM   #4316
vintageveloce
Oddometer: 72
Quick question...
Thanks in advance.
Also, 3 weeks and several adjustments? Maybe you have alot of hours but you may be overtightening it. PDS KTMs run a chain that looks pretty slack. Make sure you are setting it to the manual's spec and not too tight!
C
vintageveloce screwed with this post 07-27-2013 at 06:30 PM
Old 07-27-2013, 05:25 PM   #4317
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,092
Man....wanting a 500.....Must stay away from this thread!.....
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 07-27-2013, 09:56 PM   #4318
Bengt Phorks
Oddometer: 241
On the inside of your air filter cover there should be a diagram for setting the chain tension. If not, then with the tire off the ground, the chain should just touch the chain guide when you pull up the chain right where your picture shows its wearing.
Old 07-29-2013, 08:11 AM   #4319
HeadinSouth
vroom!
Oddometer: 96
Thanks guys. I wonder if its because I have the 14-45 setup and the wheel is set so far back?
Old 07-29-2013, 09:27 AM   #4320
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,634
Hodakaguy
That's a good idea if ya don't want a bike that will do everything from MX to Brecktreck.
This 12 replaced my 99 LC4 640e that I bashed for 12 years. I have no doubt it will serve me just as well.
In the proper hands you can do it all!
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Times are GMT -7.   It's 09:40 PM.
