Old 11-15-2013, 03:26 PM   #4936
1224R
Oddometer: 2,041
Can anyone explain how to adjust the TPS and what to adjust it to??
Thanks in advance
Mine is a 2014
Originally Posted by DiVango View Post
Same here. TPS adjustmentade a night difference.
Sent from my SCH-I605 using Tapatalk
I thought YOU had the map......
1224R is offline   Reply With Quote
Old 11-15-2013, 09:25 PM   #4937
Bengt Phorks
Oddometer: 224
Originally Posted by SteveO View Post
ditto.
Mine had a large crack across the screen for a long time. I think the only thing keeping the moisture from getting past the crack was a protective see-through plastic stuck to the screen. I've since ordered a replacement screen, internal clock battery from a guy in Russia, via ebay. It took a while, but they are hear, and my unit will once again be back in top-notch condition.
Maybe you will want one of these: 2GB data card
http://advrider.com/forums/showthread.php?t=762001
I got one and it works great.
Here is a memory backup battery for the 276c:
http://www.csobeech.com/Garmin-Internal-Battery.html
The Garmin 276C shows up often in the Advrider Flea market:
Search for Garmin.
http://www.advrider.com/forums/forumdisplay.php?f=53
Bengt Phorks is offline   Reply With Quote
Old 11-15-2013, 09:42 PM   #4938
Bengt Phorks
Oddometer: 224
Thanks in advance
Mine is a 2014
All about TPS adjustment and where to get the connector is on pages 278-279 in this thread. Start with post 4156.
Old 11-15-2013, 10:17 PM   #4939
Drew01
Oddometer: 12
Originally Posted by noahr View Post
I've found a deal on some supermoto wheels.
They are RAD 17" - 3.5 fronts and 5 back. Anyone know if they will fit my 2014?
I am running a 5" rear rim with no issues or modifications. Just make sure you get a narrow tire such as continental attack supermoto.
Drew01 is offline   Reply With Quote
Old 11-16-2013, 12:39 PM   #4940
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,187
I GOT ONE!!!
Very excited!
2014 EXC, Mapped to KM787EU12C0701 Unrestricted and desmogged..
I just bought a 2014. Can you explain what you did to unrestrict it?
rufus is offline   Reply With Quote
Old 11-17-2013, 09:40 AM   #4941
noahr
noahr's Avatar
Oddometer: 326
It means I got it mapped to the Euro version. It a process that your dealer can do where they hook up a computer to the bike and load it with the Euro mapping, the Euro version has no smog restrictions so more power but less fuel economy.
noahr is offline   Reply With Quote
Old 11-17-2013, 07:02 PM   #4942
rufus
rufus's Avatar
Oddometer: 4,187
Does this work OK with the stock exhaust or did you change or modify the exhaust?
Thanks for the reply.
Old 11-17-2013, 08:57 PM   #4943
rufus
rufus's Avatar
Oddometer: 4,187
I been reading through this whole thread.
In order to save time I am asking ..........How anyone here done the BestDualSport magic mod. Any other mods from BDS.
Mine sure seems to run hot. But I only have about 5 miles on it.
Old 11-17-2013, 09:06 PM   #4944
SoilSampleDave
Oddometer: 1,908
Stock exhaust is fine, but you will need to remove the screen at the end. It is NOT the spark arrestor.
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is online now   Reply With Quote
Old 11-17-2013, 09:08 PM   #4945
SoilSampleDave
Oddometer: 1,908
It was a good solution at first when the dealers couldn't load the unrestricted map on the ECU. Now that they can, the ECU remap is the best way to go.
'14 690R
Old 11-17-2013, 10:17 PM   #4946
1224R
Oddometer: 2,041
The motor is new it will run a little hot as it breaks in....
Also the fan on the 14's comes on more as the thermo switch has been optimized
Old 11-18-2013, 05:49 AM   #4947
rufus
rufus's Avatar
Oddometer: 4,187
This is all new to me. My only other FI bike is a Goldwing.
Withe the remap is there anything else that needs to be done?
The "Big bottom kit" from best dualsport looks interesting. Anyone here tried that?
It will be nice to put away all those little bottles of jets I have collected over the decades.
Old 11-18-2013, 07:50 AM   #4948
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,210
Just to be clear,
your saying that the dealers can now update the EXC models with the XC* programming?
AND, by doing this, the engine will run richer, and thus not so hot?
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 11-18-2013, 07:58 AM   #4949
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,183
3 cents
I have a 2012 500EXC. Went thru all the desmog - filter changes - added JD Tuner etc. The Best and Final mod to Superior running (it always ran real god) was to simply change the TPS to around .6 volts. Awesome difference and much needed. My gas mileage dropped down to about 50MPG but who cares!
I have NOT fooled with any mapping changes...
Good luck to all.
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is online now   Reply With Quote
Old 11-18-2013, 08:19 AM   #4950
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,210
Good luck to all.
I suppose the next question is, what is your definition of "Superior running". Are we talking about more power, more snap to the throttle, running cooler......
Times are GMT -7.   It's 10:22 AM.
