Old 11-28-2013, 06:01 PM   #5041
noahr
noahr's Avatar
Oddometer: 326
Called the shop, it turns out it was the shifter shaft weld that broke internally. So WARRANTY.
Parts on order, should be done next week.
noahr is offline   Reply With Quote
Old 11-28-2013, 06:11 PM   #5042
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,168
Sounds like more than an isolated case.
Lest us know when you actually get the bike back. I am gathering info on dealer repair times.
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is offline   Reply With Quote
Old 11-28-2013, 06:17 PM   #5043
noahr
noahr's Avatar
Oddometer: 326
Yeah, they said next week but in my experience i've NEVER had a dealership finish a job on time.
The one thing that actually bugs me more is when they say they'll call you back to give you an update on what need fixing or when it's done and never do, I always have to call first. Needing more time is one thing not letting me know if you do or if my bike is done and just sitting there "really grinds my gears!"
Old 11-28-2013, 06:51 PM   #5044
BanhXeo
BanhXeo's Avatar
Oddometer: 334
Originally Posted by DirtWarrior View Post
Thanks for all of your replies. This is going to be a tough decision to make... selling my 690 and getting a 500! What are the typical ranges with an aftermarket fuel tank on the 500?
Nick
My ride partner gets 60mpg. Best mpg is 68 on a 300 mile day. 80% fireroad 20%pavement. Your looking at 5.3gallons x 60mpg = A TON of fun between gas stops
2013 KTM EXC-F SOLD
2013 BMW F8 GS FOR SALE
SmugMug: http://ktmrider.smugmug.com/
This is my WIFE, here are my BIKES, and these are my STORIES: http://www.advrider.com/forums/showthread.php?t=897188
BanhXeo is offline   Reply With Quote
Old 11-28-2013, 08:53 PM   #5045
GS eh!
Oddometer: 170
It will all be fine!
Hey Noah, nice to meet you and good to see it is something simple, as long as KTM has the parts they will take care of you!
Mine runs even better with the new map installed.
Richard
GS eh! is offline   Reply With Quote
Old 11-29-2013, 07:22 AM   #5046
barrier
Says who?
barrier's Avatar
Oddometer: 513
Originally Posted by AirRsq View Post
Just did the first valve check at 15 hrs on my 2014 500.
Exhaust were both within spec. Left intake was tight (0.08) and right was at limit (0.10). I re-shimmed both intakes.
What have others seen at first valve check?
2013 EXC 500. At one hour had to shim both inlets and one exhaust. All 3 were below minimum gap. Re checked at 15hrs and nothing has moved! Result.
"What could possibly go wrong"
CBVRacing. "The race (Dakar) is what it is, it is being offered to racers, if they chose to sign up they should know that there are only 5 outcomes at the end of the two weeks: Finish, Mechanical, Abandon, Injuries, Death."
barrier is online now   Reply With Quote
Old 11-29-2013, 07:37 AM   #5047
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,207
What gearing is being run to acquire 68Mpg?
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 11-29-2013, 08:44 AM   #5048
Hueychief
FNG
Hueychief's Avatar
Oddometer: 76
I'm running 14/48 and getting 52-58mpg on 80% singletrack and 20% logging roads.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 11-29-2013, 12:53 PM   #5049
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,561
Ahhhhh ratio we dream about!
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 11-29-2013, 07:05 PM   #5050
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
2014 350 exc
Set up and rode a new 350 EXC. WOW, the power is up over the 2012-2013 models.
Love my 2012 500 EXC, but if this new 350 was available I would have bought it instead. Don't over look this bike if you are doing less road and more single track.
"Son, you can't do both"
Old 12-01-2013, 07:58 PM   #5051
Bengt Phorks
Oddometer: 224
Originally Posted by rufus View Post
I read through that a couple of times.
It does not show you how to adjust the TPS.
There are some pics of someone adjusting their TPS.
But it is NOT instructional. It does give you a setting # and a part # for the tool. But no explanation of how to use the tool.
I have adjusted a TPS on other bikes. I hooked a meter to the wires and moved the TPS.
Why is this tool needed? What does it do?
Obviously there is something I don't know. ( actually there is a LOT of things I don't know).
You already know how to adjust the TPS.
The tool makes it easier to hook up the voltmeter. Plug the tool in between the TPS sensor and the TPS wire harness.
KTM recommended setting: .601 +/- 0.004v.
Picture of tool: http://advrider.com/forums/showpost....postcount=4690
Where to buy: http://advrider.com/forums/showpost....postcount=4172
TPS adjustment using different methods:
http://www.ktmforums.com/forums/offr...flame-out.html
http://www.advrider.com/forums/showp...postcount=4049
http://www.advrider.com/forums/showp...postcount=3528
Bengt Phorks is offline   Reply With Quote
Old 12-01-2013, 08:09 PM   #5052
SoilSampleDave
Oddometer: 1,901
Very interesting. Is this versus a desmogged and re-mapped 12/13? Was the 14 remapped? If there is a bona fide difference, I wonder if it is EFI, cam or ?
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is online now   Reply With Quote
Old 12-02-2013, 05:26 AM   #5053
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,009
Tps
So is it better to adjust the TPS or do the re-map from the dealer? Or do both?
I have done the desmog shit and have a stock pipe on it. It does not flame out but does backfire from time to time.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 12-02-2013, 05:37 AM   #5054
SoilSampleDave
Oddometer: 1,901
Both.
'14 690R
Old 12-02-2013, 04:48 PM   #5055
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
This was on a totally stock 2014 350 EXC with 2 minutes run time. Vs. the 2012-2013 models, EXC and XC-W. Most noticed from 2000-4000 rpm. Get on KTM's website and see what they claim the changes are. I know the cams are hollow and it has a plain bearing crank, but don't remember what else. The mapping is changed for sure.
Both the 500 and 350 have plain bearing cranks. Should make it hold up a long time. These need more oil flow and pressure, but can tolerate more dirt in the oil.
The H4 quartz-halogen is damn good.
Times are GMT -7.   It's 06:25 PM.
